#1 Mon 30 May 2016 16:06
asma_kadjoudj
kmllayer
Bonjour. Lorsque vous exécutez ce programme mais map affiche pas???????
http://jsfiddle.net/nz78nk80/2/?utm_sou … n=nz78nk80
<!DOCTYPE html>
<html>
<head>
    <title>
asma
    </title>
      <style>
    html, body, #map-canvas {
    height: 100%;
    width: 100%;
    margin: 0px;
    padding: 0px
    </style>
</head>
   <body>
    <script>
        var map;
        var watershedLayer = new google.maps.KmlLayer({
            url: 'http://mvihes.bc.ca/mapping/watersheds.kmz'
        var ere1949Layer = new google.maps.KmlLayer({
            url: 'http://mvihes.bc.ca/mapping/ere1949.kmz'
        function initialize() {
            var parksville = new google.maps.LatLng(49.316786, -124.308768);
            var mapOptions = {
                zoom: 9,
                center: parksville
            map = new google.maps.Map(document.getElementById('map-canvas'), mapOptions);
            check();
        function check() {
            if (document.getElementById('watersheds').checked)
            { if (!watershedLayer.getMap()) watershedLayer.setMap(map); }
            else
            { watershedLayer.setMap(null); }
            if (document.getElementById('ere1949').checked)
            { if (!ere1949Layer.getMap()) ere1949Layer.setMap(map); }
            else
            { ere1949Layer.setMap(null); }
        google.maps.event.addDomListener(window, 'load', initialize);
    </script>
 <label>watersheds</label><input type="checkbox" id="watersheds" onclick="check();" onchange="check();"/><label>ere1949</label><input type="checkbox" id="ere1949" onclick="    check();" onchange="check();" />
<div id="map-canvas" style="border: 2px solid #3872ac;"></div>
    </body>
        </html>
#2 Mon 30 May 2016 16:11
PA
Lieu: Paris
Re: kmllayer
Vous ne faites pas appel à la librairie Google Maps.
Vous devez quelque part dans votre code inclure un appel JS vers l'API.
    <script src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY&callback=initMap"
        async defer></script>
Pierre-André Le Ny
Modérateur QGIS, Données, Coin de l'OpenSource
Aidez l'association GeoRezo !
