#1 Thu 01 September 2016 16:51
- kalmy
[MAP & CIVIL] Export KML plug-in
Nous avons créé un plug-in avancée pour exporter KML Map3D / Civil3D (2013 - 2017) .
Les applications peuvent trouver le magasin à Autodesk pour qui cela peut concerner
https://apps.autodesk.com/CIV3D/en/Deta … s=Win32_64
Nous espérons être utile!
Merci a vous , Albert
#2 Thu 01 September 2016 20:59
- Patrice
- JeSuisCharlie
Re: [MAP & CIVIL] Export KML plug-in
Hello Albert
1) Thks for sharing !
2) SAME features on CIVIL & MAP ?
Regards, Patrice
(Autodesk Expert Elite Team)
En ligne
#3 Sat 03 September 2016 09:26
- kalmy
Hello Patrice,
2. Yes,
The target of plug-in is for Map for FDO and Acad objects, but because Autodesk don't want to create app store for Map (long, long story with them, now I know why ) we need to publish under Civil apps, but works also under Civil. We not test with "Civil Object" like Alignment, parcel points and s.o. .
Best regards,
Albert
