#1 Tue 22 July 2014 10:11
joel cyrille
Lieu: Douala Cameroun
Messages d'erreurs
Salut à tous
j'ai un problème qui me casse la tête depuis 2 jours
Voici mon code :
INCLUDE "C:\Program Files (x86)\MapInfo\MapBasic\MAPBASIC.DEF"
Declare Sub Main
Sub Main
open table "C:\Users\JOEL CYRILLE\Documents\ND1\eclipse.TAB" as eclipse
open table "C:\Users\JOEL CYRILLE\Documents\ND1\9508MPR.TAB" as 9508MPR
open table "C:\Users\JOEL CYRILLE\Documents\ND1\9513MPR.TAB" as 9513MPR
open table "C:\Users\JOEL CYRILLE\Documents\ND1\9513MXC.TAB" as 9513MXC
open table "C:\Users\JOEL CYRILLE\Documents\ND1\9515MPR.TAB" as 9515MPR
open table "C:\Users\JOEL CYRILLE\Documents\ND1\ND.TAB" as ND
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\clients1.TAB" as clients
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\dual band1.TAB" as dualband
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\dualband POP wimax1.TAB" as dualband_wimax
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\Single Band1.TAB" as singleband
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\Singleband POP wimax1.TAB" as singleband_wimax
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\transmission FH1.TAB" as transmission
open table "C:\Users\JOEL CYRILLE\Documents\fichier BD excel\new\VSAT1.TAB" as vsat
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\Front_Sea.TAB" as vect
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\Highways.TAB" as vect1
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\Other_Roads.TAB" as vect2
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\Railways.TAB" as vect3
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\Streets.TAB" as vect4
open table "C:\Users\JOEL CYRILLE\Documents\ND1\All Vectors\CM_2014.TAB" as vect5
Set CoordSys Table eclipse
Set style pen makepen(2,2,RED)
Map from eclipse, 9508MPR, 9513MPR, 9513MXC, 9515MPR, ND, clients, dualband, dualband_wimax, singleband, singleband_wimax, transmission, vsat, vect, vect1, vect2, vect3, vect4, vect5
Fetch First From eclipse
Do While Not EOT(eclipse)
update  eclipse set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From eclipse
Loop
Set style pen makepen(2,2,YELLOW)
Fetch First From 9508MPR
Do While Not EOT(9508MPR)
update  9508MPR set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From 9508MPR
Loop
Set style pen makepen(4,2,GREEN)
Fetch First From 9513MPR
Do While Not EOT(9513MPR)
update  9513MPR set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From 9513MPR
Loop
Set style pen makepen(4,2,BLACK)
Fetch First From 9513MXC
Do While Not EOT(9513MXC)
update  9513MXC set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From 9513MXC
Loop
Set style pen makepen(2,2,RGB(128,0,255))
Fetch First From 9515MPR
Do While Not EOT(9515MPR)
update  9515MPR set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From 9515MPR
Loop
Set style pen makepen(2,2,RGB(255,0,128))
Fetch First From ND
Do While Not EOT(ND)
update  ND set obj=CreateLine(long1,lat1,long2,lat2)
Fetch Next From ND
Loop
end sub
Quand je compile ce code MapBasic, des messages d'erreurs s'affichent me disant :
(progrès.mb:10) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:11) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:12) Unrecognized command: MXC. Too many errors. Error information has been lost.
(progrès.mb:14) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:36) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:47) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:47) Found [MPR] while searching for [)]. Too many errors. Error information has been lost.
(progrès.mb:48) Invalid or missing argument list. Too many errors. Error information has been lost.
(progrès.mb:48) Found [MPR] while searching for [set]. Too many errors. Error information has been lost.
(progrès.mb:48) Invalid clause [obj] in [set]. Too many errors. Error information has been lost.
(progrès.mb:48) Variable obj not defined. Too many errors. Error information has been lost.
(progrès.mb:51) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:56) Unrecognized command: MPR. Too many errors. Error information has been lost.
(progrès.mb:56) Found [MPR] while searching for [)]. Too many errors. Error information has been lost.
(progrès.mb:57) Invalid or missing argument list. Too many errors. Error information has been lost.
Vraiment toutes mes tables ont étés créees et peuvent être projetées donc je ne comprends rien. Si quelqu'un a déja eu affaire à ce type de messages j'aimerais qu(il me vienne en aide parceque c'est urgent!!!
#2 Tue 22 July 2014 10:29
Spacejo
Lieu: Nancy
Re: Messages d'erreurs
As tu essayé comme ceci pour éliminer les premières sources d'erreur.
open table "C:\Users\JOEL CYRILLE\Documents\ND1\9508MPR.TAB" as _9508MPR
Joël
Dernière modification par Spacejo (Tue 22 July 2014 10:29)
#3 Tue 22 July 2014 13:11
joel cyrille
Merci Joël, j'ai essayé ce que tu m'as donné et ca marche.
Mon problème était également au niveau du nom de mes tables alias. Je donnais des noms avec des espaces.
Encore Merci.
