GEODATA DAYS 2024
#1 Fri 14 June 2024 16:55
jf_fuchs
[CDD] Ingenieur Geometre experimente au CERN-Geneve, Suisse)
La section ASG au sin du groupe GM ( https://be-dep-gm.web.cern.ch/ ) recherche un ingénieur Géomètre expérimenté (entre 2 et 6 ans).
Description
As a Survey Engineer you will join the Geodetic Metrology group at CERN, where you will take part in the metrology and alignment of a wide variety of components used in the particle accelerators. You will be using state-of-the-art surveying tools and software to achieve the sub-millimetre accuracy necessary to achieve our goals.
This position offers a unique opportunity to collaborate on two major projects and contribute to the efforts of the Geodetic Metrology team in the North Area.
The SPS (Super Proton Synchrotron) complex is being prepared for a significant upgrade through the North Area Consolidation (NA-CONS) and High Intensity ECN3 (HI-ECN3) projects.
The NA-CONS project will continue with the extension of the geodetic network and the synchronization of beam trajectory across the survey database, layout database, and the definitions provided by the beam physicists. One of the milestones of the project is the installation phase planned for the long shutdown (LS3) starting early 2026.
In this role, you will:
- take part in the preparation, planning and survey work related to the long shutdown;
- Develop and validate measurement for a target that will become increasingly radioactive over time for a new Beam Dump Facility (BDF) for the Search for Hidden Particles (SHiP) experiment;
- Integrate your solutions into the Technical Design Report (TDR) of the facility, which is scheduled for completion by the end of 2025.
Eligibility criteria:
- You are a national of a CERN Member or Associate Member State https://home.cern/about/who-we-are/our- … ber-states
- You have a professional background in Survey Engineer (or a related field) and have either:
  a Master's degree with 2 to 6 years of post-graduation professional experience;
  or a PhD with no more than 3 years of post-graduation professional experience.
- You have never had a CERN fellow or graduate contract before.
Additional Information
- Job closing date: 08.08.2024 at 23:59h (midnight) CEST.
- Job reference: BE-GM-ASG-2024-120-GRAP
- Contract duration: 24 months, with a possible extension up to 36 months maximum.
Target start date: 01-October-2024
>>>> https://jobs.smartrecruiters.com/CERN/7 … -120-grap-
Si vous êtes éligible, motivé et curieux de découvrir le CERN : ne pas hésiter à me contacter ou directement Camille Vendeuvre
Plusieurs offres au CERN en ce moment en plus de celle-ci, merci de les partager !
- [CDD] Ingenieur Geometre au CERN (Geneve, Suisse) : https://georezo.net/forum/viewtopic.php?id=133605
- [CDD] Technicien Geometre au CERN (Geneve, Suisse) : https://georezo.net/forum/viewtopic.php?id=133607
