GeoDataDays 2025
#1 Mon 30 June 2025 12:36
QGIS/Plugin Terminus: ModuleNotFoundError: No module named 'skimage'
Je me permets d'écrire un message. j'ai installé le plugin Terminus.
Mais lorsque j'essaie de l'activer via le manager d'extensions, j'ai un message d'erreur. Si une personne pense pouvoir m'aider ? Merci.
Je travaille avec
Version de Python : 3.12.7 (main, Oct 25 2024, 11:18:09) [MSC v.1938 64 bit (AMD64)]
Version de QGIS : 3.34.13-Prizren Prizren, 222b5995
Je joins ci dessous le message d'erreur :
Impossible de charger l'extension 'terminus_processing' provoque une erreur lors de l'appel à sa méthode classFactory()
  File "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 423, in _startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\__init__.py", line 38, in classFactory
    from .terminus_processing import TerminusPlugin
  File "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 892, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\terminus_processing.py", line 42, in
    from .terminus_processing_provider import TerminusProvider
  File "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\terminus_processing_provider.py", line 39, in
    from .image_segmentation_processing_felzenszwalb import Imagesegmentationfelzenszwalb
  File "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\image_segmentation_processing_felzenszwalb.py", line 41, in
    from skimage import io
#2 Mon 30 June 2025 14:01
SANTANNA
Lieu: Angers
Re: QGIS/Plugin Terminus: ModuleNotFoundError: No module named 'skimage'
Issu de la présentation du plugin
A plugin to perform Image Segmentation. It requires the installation of Scikit-image Python library. For more information please visit https://github.com/ikotarid/Terminus.
L'avez-vous installé?
