State Of The Map 2024
#1 Fri 01 May 2020 08:24
kane1000
assistance
je dois construire un rectangle oblique à partir de 3 points mais ca donne pas!
aidez please
Include "MAPBASIC.DEF"
Include "ICONS.DEF"
Declare Sub Main
Declare Sub drawPLine
Sub Main
Alter ButtonPad ID 2
    Add Separator
    Add ToolButton
        Icon MI_ICON_MISC_12
        ID 103
        Cursor MI_CURSOR_FINGER_LEFT
        DrawMode DM_CUSTOM_POLYLINE
        Calling drawPLine
        HelpMsg "Draw the axis of  the road Axis of the road"
        Enable
    Show
end sub
Sub drawPLine
    dim nNode, nNode2, nNode3, nSegment, i as Integer
    dim X3,Y3, X1,Y1,X2,Y2,fX,fY as Float
    dim objPLine,pto4  as Object
    dim LName as string
    'Define the name of the topmost(non-cosmetic) layer
            'It is assumend that the layer is vector
          LName=LayerInfo(FrontWindow(), 1, LAYER_INFO_NAME)
                'Define an object-polyline
          objPLine = CommandInfo(CMD_INFO_CUSTOM_OBJ)
    For nSegment = 1 To ObjectInfo(objPLine , OBJ_INFO_NPOLYGONS)
        For i = 1 To 3
            If i = 1 Then
                nNode = 1
                X1= ObjectNodeX(objPLine, nSegment, nNode)
                   Y1=    ObjectNodeY(objPLine, nSegment, nNode)
            end if
           If i=2 then
                nNode2 = 1+ nNode
                X2= ObjectNodeX(objPLine, nSegment, nNode2)
                   Y2=    ObjectNodeY(objPLine, nSegment, nNode2)
            else
               nNode3 = ObjectInfo(objPLine , OBJ_INFO_NPOLYGONS + nSegment)
                X3= CentroidX(Offset( objPLine , 90, 5, "km"))
                   Y3=    CentroidY(Offset( objPLine , 90, 5, "km" ))
            End If
        Next
    Next
             pto4= CreatePoint(X1,Y3)
              nSegment = 1
              nNode = 1
            Alter Object objPLine
        Node Add Position nSegment, nNode (CentroidX(pto4),CentroidY(pto4))
            Insert Into LName (X, Y,  Obj) Values  (X, Y, CreateLine(X1,Y1,X2,Y1))
            Insert Into LName (X, Y,  Obj) Values  (X, Y, CreateLine(X2,Y1,X3,Y3))
            Insert Into LName (X, Y,  Obj) Values  (X, Y, CreateLine(CentroidX(pto4),CentroidY(pto4),X1,Y1))
            Insert Into LName (X, Y,  Obj) Values  (X, Y, CreateLine(CentroidX(pto4),CentroidY(pto4),X3,Y3))
end sub
