#1 Mon 19 October 2020 13:54
- Patrice
- JeSuisCharlie
[ACAD MAP/CIVIL 20XX] Bug avec certains SHP, DBF, SHX !
Objet: [ACAD MAP/CIVIL 20XX] Bug avec certains SHP, DBF, SHX !
Hello
https://forums.autodesk.com/t5/autocad- … lse#M57923
So the solution is : remove or rename the .SHX file !
which is "not correct" for MAPIMPORT AND for the FDO SHP Driver !
The .SHX will recreated automatically by MAP and after MAP can use the SHP, DBF, etc ...
LA SANTE, GeoBye, Pat
(Autodesk Expert Elite Team)
