GEODATA DAYS 2024
#1 Tue 05 July 2016 14:25
Ricola62
Iterer un script python dans un répertoire
voici le code
    #!/usr/bin/env python
# -*- coding: UTF-8 -*-
Description: Imports and merges polylines
             from one workspace into a single feature class
Author: NP
http://desktop.arcgis.com/fr/desktop/latest/manage-data/cad/using-python-to-load-cad-data.htm
# Import system modules
import arcpy
# MAIN
def main():
    Main du module : importe un calque de plusiuers DWG
                    dans une classe d'entites d'une FGDB (elle doit exister)
    # Ecrase la classe d'entites cible si elle existe
    arcpy.env.overwriteOutput = True
    # Espace de travail ou sont les fichiers DWG
    arcpy.env.workspace = r'G:\Expert\03_DGST\Poubelle\DAOP1'
    # Create a value table that will hold the input feature classes for Merge
    vtab = arcpy.ValueTable()
    # WhereClause : calque DWG que l'on veut importer
    whereclause = "\"Layer\" = 'R-EPIC-CANA'"
    # Choix des champs que l'on veux garder : Layer, Color, DocName et DocType
    champsaconsever = ["Layer", "Color", "DocName"]
    #compteur des fichiers DWG
    nbfiledwg = 0
    # Step through each dataset in the list
    for fdataset in arcpy.ListDatasets('*.dwg'):
        layername = u'{0}'.format(fdataset)
        layername = layername.replace(u'É', 'E')
        layername = layername.replace(' +', 'plus')
        layername = layername.replace(' -', 'moins')
        layername = layername.replace(' ', '_')
        print u'_{0}_'.format(layername)
        # Get the fields from the input
        fields = arcpy.ListFields(fdataset)
        # Create a fieldinfo object
        fieldinfo = arcpy.FieldInfo()
        # Iterate through the fields and set them to fieldinfo
        for field in fields:
            if field.name in champsaconsever:
                fieldinfo.addField(field.name, field.name, "VISIBLE", "")
            else:
                fieldinfo.addField(field.name, field.name, "HIDDEN", "")
        # Select only the Polyine features on the drawing layer (whereclause)
        arcpy.MakeFeatureLayer_management(u'{0}\Polyline'.format(fdataset)
                                          , layername
                                          , whereclause
                                          , fieldinfo)
        # Creation ajout de la couches dans la liste des couches a fusionner
        try:
            vtab.addRow(layername)
            nbfiledwg = nbfiledwg +1
        except Exception, errordesc:
            print arcpy.GetMessages()
            errmesg = 'PYTHON ERRORS: {0}'.format(errordesc)
            print errmesg
            print "Echec de l'ajout de la couche {0} ({1})".format(layername, fdataset)
    # Merge the CAD features into one feature class
    mergefc = r'G:\Expert\03_DGST\Poubelle\DAO.gdb\EPIC4'
    try:
        arcpy.Merge_management(vtab, mergefc)
        print errmesg
    # Fin
    print u'{0} fichiers DWG importes et fusionnes'.format(nbfiledwg)
    return True
if __name__ == '__main__':
    STATUS = main()
le répertoire contient 120 dwg et suite à beaucoup de manipulation : impossible de de traiter les 120 dwg en même temps.
donc j'ai lancer le script sur trois répertoire différents de environ 40 dwg et ça a fonctionné.
Afin d'automatisé cela je me posé la question, est il possible d'inclure dans le script trois traitements d'une serie de fichiers  à la suite?
afin d'éviter de créer des répertoires.
#2 Thu 07 July 2016 01:00
tomsigeomatique
Re: Iterer un script python dans un répertoire
si j'ai bien compris:
- vous ne pouvez pas lancer le script sur un dossier de 120 dwg
- vous lancez 3 fois donc le script sur un dossier de 40 dwg
Et si vous créez un nouveau script qui parcourt une liste/tableau de dossier et qui exécute votre premier script, est ce que cela fonctionne?
#3 Thu 07 July 2016 09:01
Ricola62
tomsigeomatique a écrit:
- Oui
- Je lance le script trois fois,sur chaques dossiers de 40 dwg
je voudrais pouvoir insérer dans mon script la possibilité d'effectuer le boulot en trois fois donc créer trois listes de 40 dwg environ
#4 Thu 07 July 2016 11:37
nitram
Lieu: Brest
Je ne sais pas si c'est la solution, mais vous pouvez intégrer votre script dans un outil de script.
-> http://desktop.arcgis.com/fr/arcmap/10. … t-tool.htm
Vous renseignez le répertoire en entrée comme variable, ensuite vous pourrez le lancer en batch.
-> http://desktop.arcgis.com/fr/arcmap/10. … essing.htm
à voir...
Martin
#5 Fri 08 July 2016 00:45
tomsigeomatique
d'accord. Le plus convivial est d'intégrer en effet le script dans un outil/script ArcGIS, avec la possibilité de traiter en batch (par lot).
Mais si vous souhaitez travailler qu'avec du code.
Deux solutions possibles:
-créer un nouveau script contenant:
def importCADtoGDB(repertoire):
   **renommer/copie de la fonction main avec utilisation du paramètre repertoire**
mesRep=[r'G:\Expert\03_DGST\Poubelle\DAOP2',r'G:\Expert\03_DGST\Poubelle\DAOP1',r'G:\Expert\03_DGST\Poubelle\DAOP3']
for ele in mesRep:
   importCADtoGDB(ele)
Ou regrouper les 3 répertoires dans un répertoire principal et créer un autre nouveau script ou outil:
import os
import arcpy
repertoirePrincipale=r"G:\Expert\03_DGST\Poubelle"
#ou
#repertoirePrincipale=arcpy.GetParameterAsText(0)
for dirName, subdirList, fileList in os.walk(repertoirePrincipale):
   if dirName != repertoirePrincipale:
      importCADtoGDB(dirName)
attention walk parcours de manière itérative tous les dossiers et leurs sous-dossiers
Dernière modification par tomsigeomatique (Fri 08 July 2016 00:56)
