Printemps des cartes 2024
#1 Tue 21 May 2019 21:40
avel
pb osm2pgsql
Bonjour à tous
Je suis en train d'importer ds postgresql/postgis un fichier osm.pbf. J'ai l'erreur suivante qui apparait:
C:UsersFERON PAPEL Avel>osm2pgsql -U postgres -W -m -d osmBis -p osmBis -E 3857 -S "C:ms4wtoolsosm2pgsqldefault.style" C:ms4wappsosmfrance-latest.osm.pbf
osm2pgsql version 0.96.0 (64 bit id space)
!! You are running this on 32bit system, so at most
!! 3GB of RAM can be used. If you encounter unexpected
!! exceptions during import, you should try running in slim
!! mode using parameter -s.
Password:
Allocating memory for sparse node cache
Node-cache: cache=800MB, maxblocks=12800*65536, allocation method=1
Using built-in tag processing pipeline
Using projection SRS 3857 (Spherical Mercator)
Setting up table: osmBis_point
node cache: stored: 0(-nan(ind)%), storage efficiency: -nan(ind)% (dense blocks: 0, sparse nodes: 0), hit rate: -nan(ind)%
Osm2pgsql failed due to ERROR: CREATE UNLOGGED TABLE osmBis_point (osm_id int8,"access" text,"addr:housename" text,"addr:housenumber" text,"addr:interpolation" text,"admin_level" text,"aerialway" text,"aeroway" text,"amenity" text,"area" text,"barrier" text,"bicycle" text,"brand" text,"bridge" text,"boundary" text,"building" text,"capital" text,"construction" text,"covered" text,"culvert" text,"cutting" text,"denomination" text,"disused" text,"ele" text,"embankment" text,"foot" text,"generator:source" text,"harbour" text,"highway" text,"historic" text,"horse" text,"intermittent" text,"junction" text,"landuse" text,"layer" text,"leisure" text,"lock" text,"man_made" text,"military" text,"motorcar" text,"name" text,"natural" text,"office" text,"oneway" text,"operator" text,"place" text,"population" text,"power" text,"power_source" text,"public_transport" text,"railway" text,"ref" text,"religion" text,"route" text,"service" text,"shop" text,"sport" text,"surface" text,"toll" text,"tourism" text,"tower:type" text,"tunnel" text,"water" text,"waterway" text,"wetland" text,"width" text,"wood" text,"z_order" int4,"population" text,way geometry(POINT,3857) ) WITH ( autovacuum_enabled = FALSE ) failed: ERREUR:  la colonne ┬½ population ┬╗ est sp├®cifi├®e plus d'une fois
Queslqu'un a til eu déjà un pb similaire?
Merci beaucoup
#2 Mon 02 December 2019 18:58
Emgeo
Re: pb osm2pgsql
Bonsoir.
Il semble qu'il y ait une erreur dans le code au niveau de la colonne "population",
peut-être que c'est au niveau du fichier de style ? Il peut y avoir une redondance d'information à l'intérieur sur l'intitulé de champs.
