Printemps des cartes 2024
#1 Fri 02 January 2009 21:24
alidiaby
Compilation Proj 4, map server sur un serveur web Unix
Bonjour a tous
J'ai un espace chez un hébergeur web. Je voulais installer mapserveur sur ce serveur.
Je dispose d'un compte d'access au ssh, mais je suis pas le superutilisateur.
Dans l'étape d'installation de Mapserveur, je doit installer leslibrairie GDAl, PROj etc...
j'ai donc décompresser et tenter de compiler premierement PROJ4.1.6
je vous montre ci desous le code de debugage
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by PROJ.4 Projections configure 4.6.1, which was
generated by GNU Autoconf 2.61.  Invocation command line was
  $ ./configure --prefix=/home1/assismed/module
## Platform. ##
hostname = box462.bluehost.com
uname -m = x86_64
uname -r = 2.6.27-6_1.intel.BHsmp
uname -s = Linux
uname -v = #1 SMP Thu Nov 13 15:27:29 MST 2008
/usr/bin/uname -p = x86_64
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = x86_64
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe
le message d'erreur est :
configure:4693: gcc -E  conftest.c
configure:4699: $? = 0
configure:4730: gcc -E  conftest.c
conftest.c:10:28: ac_nonexistent.h: No such file or directory
configure:4736: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME "PROJ.4 Projections"
| #define PACKAGE_TARNAME "proj"
| #define PACKAGE_VERSION "4.6.1"
| #define PACKAGE_STRING "PROJ.4 Projections 4.6.1"
| #define PACKAGE_BUGREPORT "warmerdam@texte-a-enlever.pobox.com"
| #define PACKAGE "proj"
| #define VERSION "4.6.1"
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:4769: result: gcc -E
configure:4798: gcc -E  conftest.c
configure:4804: $? = 0
configure:4835: gcc -E  conftest.c
configure:4841: $? = 1
| /* confdefs.h.  */
configure:4879: checking for ANSI C header files
configure:4909: gcc -c -g -O2  conftest.c >&5
configure:4915: $? = 0
configure:5014:
Je suis débutant et je comprend pas grand choses
aidez moi j'en ai grandement besoin.
je joint le fichier de dubugage
#2 Sat 03 January 2009 12:57
Yves
Lieu: Aix-les-Bains
Re: Compilation Proj 4, map server sur un serveur web Unix
Vous n'avez pas de compilateur C++ d'installé (gcc -E  conftest.c échoue). Cela est très certainement normal, seul les hébergements dédiés vous permettent de compiler vos programmes, vous avez sans aucun doute un hébergement mutualisé.
Y.
#3 Sat 03 January 2009 17:40
alidiaby
Bonjour Yves
Merci beaucoup, je vais donc rechercher un hébergement dédié pour mon projet. Pouvez vous m'en conseiller un a bon prix?
Je me demandait si c'est possible d'utiliser FWtools pour installer mapserver sur mon serveur mutualisé?
merci pour votre réponse
Merci beaucoup
Dernière modification par alidiaby (Sat 03 January 2009 20:45)
#4 Sat 03 January 2009 20:56
Guillaume Sueur
Lieu: Toulouse
va voir du côté d'Alwaysdata, même en mutualisé tu pourras faire ce que tu veux !
#5 Tue 06 January 2009 20:58
alidiaby
bsr
finalement j'ai opté pour FWtools, je suis parvenu à l'installer sur le serveur avec le ssh.
j'ai donc déplacé le fichier mapserv contenu dans le dossier bin vers le dossier cgi-bin de mon serveur.
losque je tape l'adresse http://monrepertoire/cgi-bin/mapserv?
il génère un erreur: "The server encountered an internal error or misconfiguration and was unable to complete your request."
j'ai consulté le fichier error_log. voici le log:
[Tue Jan 06 12:01:29 2009] [warn] RewriteCond: NoCase option for non-regex pattern '-f' is .
j'ai besoin de votre aide merci.
#6 Tue 20 January 2009 09:17
Laurent Jégou
Lieu: Toulouse
Cette erreur est liée à mod_rewrite d'apache, donc à priori rien à voir avec MapServer mais plutôt avec le site web hébergé.
