State Of The Map 2024
#1 Mon 11 May 2009 15:23
gg3109
Problème création de projet webcarto
Je suis en pleine création de projet mais je n'arrive pas à afficher un fichier shape.
Voila le message d'erreur.
Failure
CartoWeb version: 3.5.0 [$Revision: 1.9 $]
class:   SoapFaultWrapper
message:   Object to unserialize has no className attribute, and no class name was given:
Backtrace:
file: 215 - C:\ms4w\apps\cartoweb3\common\CwSerializable.php
call: CwSerializable::guessClassName(Null)
file: 255 - C:\ms4w\apps\cartoweb3\common\CwSerializable.php
call: CwSerializable::unserializeObject(Object(stdClass), Null, Null)
file: 636 - C:\ms4w\apps\cartoweb3\coreplugins\layers\common\Layers.php
call: CwSerializable::unserializeObjectMap(Object(stdClass), "layers")
file: 430 - C:\ms4w\apps\cartoweb3\coreplugins\layers\server\LayersInitProvider.php
call: LayersInit->unserialize(Object(stdClass))
file: 355 - C:\ms4w\apps\cartoweb3\coreplugins\layers\server\ServerLayers.php
call: LayersInitProvider->getInit()
file: 167 - C:\ms4w\apps\cartoweb3\server\ServerPluginHelper.php
call: ServerLayers->getInit()
file: UNKNOWN - UNKNOWN
call: InitProviderHelper->getInitHelper(Object(ServerLayers))
file: 267 - C:\ms4w\apps\cartoweb3\common\PluginManager.php
call: call_user_func_array(Array(2), Array(1))
file: 285 - C:\ms4w\apps\cartoweb3\common\PluginManager.php
call: PluginManager->callPluginImplementing(Object(ServerLayers), "InitProvider", "getInit", Array(0))
file: 166 - C:\ms4w\apps\cartoweb3\server\MapInfoHandler.php
call: PluginManager->callPluginsImplementing("InitProvider", "getInit")
file: 49 - C:\ms4w\apps\cartoweb3\server\ServerMapInfoCache.php
call: MapInfoHandler->loadMapInfo()
file: 163 - C:\ms4w\apps\cartoweb3\common\MapInfoCache.php
call: ServerMapInfoCache->computeMapInfo()
file: 177 - C:\ms4w\apps\cartoweb3\server\MapInfoHandler.php
call: MapInfoCache->getMapInfo()
file: 396 - C:\ms4w\apps\cartoweb3\server\ServerContext.php
call: MapInfoHandler->getMapInfo()
file: 191 - C:\ms4w\apps\cartoweb3\server\Cartoserver.php
call: ServerContext->getMapInfo()
file: 349 - C:\ms4w\apps\cartoweb3\server\Cartoserver.php
call: Cartoserver->doGetMapInfo("SMDEA.SMDEA")
file: 389 - C:\ms4w\apps\cartoweb3\server\Cartoserver.php
call: Cartoserver->callWithExceptionCheck("doGetMapInfo", "SMDEA.SMDEA")
file: 104 - C:\ms4w\apps\cartoweb3\client\CartoserverService.php
call: Cartoserver->getMapInfo("SMDEA.SMDEA")
file: 165 - C:\ms4w\apps\cartoweb3\client\CartoserverService.php
call: CartoserverService->callDirect("getMapInfo", "SMDEA.SMDEA")
file: 224 - C:\ms4w\apps\cartoweb3\client\CartoserverService.php
call: CartoserverService->callFunction("getMapInfo", "SMDEA.SMDEA")
file: 60 - C:\ms4w\apps\cartoweb3\client\ClientMapInfoCache.php
call: CartoserverService->getMapInfo("SMDEA.SMDEA")
call: ClientMapInfoCache->computeMapInfo()
file: 790 - C:\ms4w\apps\cartoweb3\client\Cartoclient.php
call: MapInfoCache->getMapInfo("SMDEA.SMDEA")
file: 427 - C:\ms4w\apps\cartoweb3\client\Cartoclient.php
call: Cartoclient->getMapInfo()
file: 31 - C:\ms4w\apps\cartoweb3\htdocs\client.php
call: Cartoclient->__construct()
Back to initial map.
Hint: you should customize this template (failure.tpl) in your project.
#2 Mon 11 May 2009 15:30
Yves
Lieu: Aix-les-Bains
Re: Problème création de projet webcarto
Généralement le message d'erreur donne des indications quant à l'erreur :
Il manque le paramètre NAME à l'objet CLASS.
Y.
#3 Mon 11 May 2009 15:34
gg3109
Pourtant il me semble que le fichier est bon.
MAP
  NAME "SMDEA"
  EXTENT 470000.00000 176000.000000 590000.000000 1740000.000000
  IMAGETYPE PNG
  IMAGECOLOR 255 255 255
  STATUS ON
  UNITS METERS
  FONTSET "fonts.txt"
  SYMBOLSET "symbols.txt"
  SHAPEPATH "data"
  OUTPUTFORMAT
    NAME png
    DRIVER "GD/PNG"
    MIMETYPE "image/png"
    IMAGEMODE PC256
    EXTENSION "png"
    FORMATOPTION "INTERLACE=OFF"
    TRANSPARENT OFF
  END
  OUTPUTFORMAT
    NAME jpeg
    DRIVER "GD/JPEG"
    MIMETYPE "image/jpeg"
    IMAGEMODE RGB
    EXTENSION "jpg"
    FORMATOPTION "QUALITY=80"
  END
  REFERENCE
    IMAGE images/keymap_france.png
    EXTENT -168827.05 1620431 1414509.05 2677441
    STATUS ON
    COLOR -1 -1 -1
    OUTLINECOLOR 200 0 0
    SIZE 224 150
  END
  SCALEBAR
    POSTLABELCACHE TRUE
    STYLE 0
    UNITS meters
    SIZE 350 3
    TRANSPARENT TRUE
    COLOR 77 77 88
    IMAGECOLOR 242 255 195
    BACKGROUNDCOLOR 222 222 222
    LABEL
      TYPE BITMAP
      SIZE SMALL
      COLOR 0 0 0
      POSITION UR
      BUFFER 10
    END
  END
  LEGEND
    KEYSIZE 20 15
  END
      LAYER
        NAME                    "Zonage"
        TYPE                    POLYGON
        DATA                    "Zonage"
        CLASS
            NAME                "Zonage"
            STYLE
                COLOR            240 240 240
                OUTLINECOLOR    0 0 0
            END
        END
    END
END
et pour ce qui est du layer.ini
; whether to generate class icons automatically
autoClassLegend = true
; layers
;layers.root.className = LayerGroup
;layers.root.children =  Zonage
;layers.root.rendering = block
layers.Zonage.ClassName = Layer
layers.Zonage.label = Zonage
layers.Zonage.mslayer = Zonage
mon Zonage.zhp se situe ds le dossier data avec le shx et le dbf.
voila je suis un peu perdu.
#4 Mon 11 May 2009 15:44
Yves
Lieu: Aix-les-Bains
le symbol ; indique des les 3 lignes de l'objet root dans ton fichier layers.ini sont commenté.
Y.
#5 Mon 11 May 2009 15:52
gg3109
Je viens d'enlever les ; mais cela ne change rien, en fait je viens de remarquer que le problème viens de :    layers.Zonage.ClassName = Layer
en effet qd je met ces lignes en commentaire j'arrive à ouvrir cartoweb mais sinon apparait le message failure. Je pense que je n'est pas biens compris la manière de mettre en place le classname, le label et le mslayer.
#6 Mon 11 May 2009 16:07
Yves
Lieu: Aix-les-Bains
La doc indique bien
layers.Zonage.className = Layer
et pas
Y.
#7 Mon 11 May 2009 16:14
gg3109
Je vous remercie pour vos réponses, mon problème se basé simplement sur une histoire de majuscule.
Mon nouveau problème concerne l'affichage puisque la carte ne propose aucune données elles est désespérement vide.
Ci joint l'impression du module cartogrâphique
Dernière modification par gg3109 (Mon 11 May 2009 17:09)
#8 Tue 16 June 2009 13:47
gg3109
je pense que mon projet est désormais terminé, je tiens à vous remercier pour toute l'aide que
vous avez pu m'apportez. Bonne continuation à tous.
#9 Tue 16 June 2009 13:50
Yves
Lieu: Aix-les-Bains
Bonne continuation !
Y.
