Pour sécuriser votre compte sur les forums du GeoRezo, nous demandons de changer votre mot de passe.
#1 Thu 13 January 2011 10:57
- Pierre
- DesCartesPourUnMondeMeilleur
Calage Raster : Erreur en lecture pour des jpg
Aloha
J'obtiens ce message d'erreur lorsque j'ouvre un jpg dans le viewer et visiblement le calage n'est pas conservé :
The OGC definition of the FME coordinate system 'IGN-RGF93' is 'CoordSys Earth Projection 3, 33, "m", 3, 46.5, 44, 49, 700000, 6600000' JPEG reader: Successfully read TAB file 'Y:\DIVERS\Brouillon\EM\planford_72.TAB' JPEG reader: The source dataset contains GCPs but no projection information. If GCPs are applied the coordinates will be converted but no coordinate system will be set Resampler: Resampling raster from a cell size of (1, 1) to a cell size of (14.1430231365946, 14.1430231365946) Resampler: This operation does not preserve Ground Control Points (GCPs). All existing GCPs will be discarded Resampler: Recalculating raster dimensions from '4032' row(s) and '4166' column(s) to '285' row(s) and '295' column(s) Using source sampling
Mon .TAB est défini comme suit :
!table !version 300 !charset WindowsLatin1 Definition Table File "planford_72.jpg" Type "RASTER" (775658.90000000002,6906910.2999999998) (2099,1811) Label "Pt 1", (775294.09999999998,6906696.2999999998) (1889,1943) Label "Pt 2", (774793.19999999995,6906647.2000000002) (1618,1982) Label "Pt 3", (775638.90000000002,6905721) (2129,2466) Label "Pt 4", (774715.90000000002,6907773.2000000002) (1549,1358) Label "Pt 5" CoordSys Earth Projection 3, 33, "m", 3, 46.5, 44, 49, 700000, 6600000 Units "m"
Quelqu'un a-t'il une idée sur la source du problème ?
D'avance, merci,
