#1 Fri 11 October 2019 10:59
- aknleo
- Lieu: Libreville
QGIS 3.4: Erreur d'execution du script au demarrage
Au démarrage de Qgis 3.4 j'ai le message suivant
Début message
Une erreur est survenue lors de l'exécution du code suivant:
qgis.utils.reloadProjectMacros()
File "", line 1, in
File "C:/PROGRA~2/QGIS3~1.4/apps/qgis-ltr/./python\qgis\utils.py", line 508, in reloadProjectMacros
exec(str(code), mod.__dict__)
File "", line 1
from qgis.PyQt.QtCore import *
IndentationError: unexpected indent
Version de Python :
3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:06:47) [MSC v.1914 32 bit (Intel)]
Version de QGIS :
3.4.12-Madeira 'Madeira', 625767347a
Chemin vers Python :
['C:/PROGRA~2/QGIS3~1.4/apps/qgis-ltr/./python', 'C:/Users/RFUDEV/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python', 'C:/Users/RFUDEV/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python/plugins', 'C:/PROGRA~2/QGIS3~1.4/apps/qgis-ltr/./python/plugins', 'C:\\Program Files (x86)\\QGIS 3.4\\bin\\python37.zip', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\DLLs', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\lib', 'C:\\Program Files (x86)\\QGIS 3.4\\bin', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\lib\\site-packages', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\lib\\site-packages\\win32', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\lib\\site-packages\\win32\\lib', 'C:\\PROGRA~2\\QGIS3~1.4\\apps\\Python37\\lib\\site-packages\\Pythonwin', 'C:/Users/RFUDEV/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python', 'E:/Mes Projets/WD24_Ttk11/Exe', 'C:/Users/RFUDEV/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python/plugins\\excel_sync\\libs\\xlrd-1.2.0-py2.py3-none-any.whl', 'C:/Users/RFUDEV/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python/plugins\\excel_sync\\libs\\xlwt-1.3.0-py2.py3-none-any.whl']
Fin message
Comment remédier à cela. Merci d'avance pour vos réponses
