Rencontres QGIS 2027
#1 Mon 26 April 2021 17:20
cachamo
QGIS: probl avec le plugin Hotspot Analysis
Bonjour à tous, lorsque je charge le pluging Hotspot analysis j'ai ce message :
Impossible de charger l'extension 'HotspotAnalysis' provoque une erreur lors de l'appel à sa méthode classFactory()
ImportError: dlopen(/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/_imaging.cpython-38-darwin.so, 2): Library not loaded: /opt/X11/lib/libxcb.1.dylib   Referenced from: /Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/_imaging.cpython-38-darwin.so   Reason: image not found
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 335, in _startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/HotspotAnalysis/__init__.py", line 34, in classFactory
    from .hotspot_analysis import HotspotAnalysis
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 799, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/HotspotAnalysis/hotspot_analysis.py", line 38, in
    import pysal
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pysal/__init__.py", line 3, in
    from . import explore
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pysal/explore/__init__.py", line 4, in
    import pointpats
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pointpats/__init__.py", line 4, in
    from .pointpattern import PointPattern
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pointpats/pointpattern.py", line 12, in
    from matplotlib import pyplot as plt
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/pyplot.py", line 36, in
    import matplotlib.colorbar
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/colorbar.py", line 44, in
    import matplotlib.contour as contour
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/contour.py", line 17, in
    import matplotlib.text as text
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/text.py", line 16, in
    from .textpath import TextPath  # Unused, but imported by others.
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/textpath.py", line 11, in
    from matplotlib.mathtext import MathTextParser
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/mathtext.py", line 27, in
    from PIL import Image
  File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/Image.py", line 94, in
    from . import _imaging as core
Version de Python : 3.8.7 (default, Feb 10 2021, 09:04:08) [Clang 12.0.0 (clang-1200.0.32.29)]
Version de QGIS : 3.18.2-Zürich Zürich, 8f0e606e1e
Chemin Python :
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/LAStools
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/clusterpoints
/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/scipy-1.5.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Rtree-0.9.4-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/affine-2.3.0-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/GDAL-3.2.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/cftime-1.2.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/numba-0.50.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/statsmodels-0.11.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Fiona-1.8.13.post1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/click_plugins-1.1.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/geopandas-0.8.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/opencv_contrib_python-4.3.0.36-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/rasterio-1.1.5-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/netCDF4-1.5.4-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pyproj-2.6.0-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/numpy-1.20.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/lib-dynload
/Applications/QGIS.app/Contents/MacOS/lib/python38.zip
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/patsy-0.5.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pandas-1.1.0-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/snuggs-1.4.7-py3.8.egg
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/mmqgis/forms
Avez-vous des solutions ou des suggestions ?
#2 Mon 26 April 2021 17:44
Pascal Boulerie
Re: QGIS: probl avec le plugin Hotspot Analysis
Peut-être réinstaller Python ?
(je ne sais pas exactement quoi vous conseiller - je ne trouve pas de détails à ce propos dans la doc QGis)
#3 Mon 26 April 2021 17:55
Pascal Boulerie
QGis a son propre Python embarqué à son bord, si je comprends bien ?
https://georezo.net/forum/viewtopic.php … 58#p266558
et sur un MacOS il faut s'assurer manuellement que c'est le bon Python au bon endroit qui appelle le bon script Python ??
try out to set QGIS paths to the package folder manually to be sure that the wanted packages are within the same python env used by QGIS (see: https://gis.stackexchange.com/questions … s-3-on-mac )
https://github.com/danioxoli/HotSpotAna … /issues/61
