#1 Mon 23 December 2019 19:15
preliator
QGIS: couches suivantes n'ont pas ete generees correctement
Je rencontre un problème avec QGis. Je souhaite lancer une application Grass, cependant j'ai systématiquement le même message d'erreur qui apparait.
QGIS version: 3.8.0-Zanzibar
QGIS code revision: 11aff65f10
Qt version: 5.11.2
GDAL version: 2.4.1
GEOS version: 3.7.2-CAPI-1.11.0 b55d2125
PROJ version: Rel. 5.2.0, September 15th, 2018
Traitement de l'algorithme…
Démarrage de l'algorithme 'v.clean'…
Paramètres en entrée:
{ '-b' : False, '-c' : False, 'GRASS_MIN_AREA_PARAMETER' : 0.0001, 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : None, 'GRASS_SNAP_TOLERANCE_PARAMETER' : -1, 'GRASS_VECTOR_DSCO' : '', 'GRASS_VECTOR_EXPORT_NOCAT' : False, 'GRASS_VECTOR_LCO' : '', 'error' : 'TEMPORARY_OUTPUT', 'input' : 'C:\\Users\\Kevin\\Desktop\\ok\\DEPART.shp|layername=DEPART', 'output' : 'TEMPORARY_OUTPUT', 'threshold' : '', 'tool' : [0], 'type' : [0,1,2,3,4,5,6] }
g.proj -c proj4="+proj=lcc +lat_1=49 +lat_2=44 +lat_0=46.5 +lon_0=3 +x_0=700000 +y_0=6600000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
v.in.ogr min_area=0.0001 snap=-1.0 input="C:\Users\Kevin\Desktop\ok\DEPART.shp" layer="DEPART" output="vector_5e0103bb4b9df5" --overwrite -o
g.region n=6162208.186928612 s=6162208.186928612 e=703146.4063816149 w=703146.4063816149
v.clean input=vector_5e0103bb4b9df5 type="point,line,boundary,centroid,area,face,kernel" tool="break" output=output01610f05d4c944b3a407e7aefeb60302 error=error01610f05d4c944b3a407e7aefeb60302 --overwrite
v.out.ogr type="auto" input="output01610f05d4c944b3a407e7aefeb60302" output="C:\Users\Kevin\AppData\Local\Temp\processing_1061c34b459649df826021e1d805ffcc\2de50cc1426842a5aef21d658ecafb5c\output.gpkg" format="GPKG" --overwrite
v.out.ogr type="auto" input="error01610f05d4c944b3a407e7aefeb60302" output="C:\Users\Kevin\AppData\Local\Temp\processing_1061c34b459649df826021e1d805ffcc\e9c26dbf60de49ae98a5621ac9e88d33\error.gpkg" format="GPKG" --overwrite
Le chemin d'accŠs sp‚cifi‚ est introuvable.
'""' n'est pas reconnu en tant que commande interne
ou externe, un programme ex‚cutable ou un fichier de commandes.
Appuyez sur une touche pour continuer...
Exécution terminée en 1.37 secondes
Résultats:
{'error': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding': 'System'}}>,
'output': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding': 'System'}}>}
Chargement des couches de résultat
Les couches suivantes n'ont pas été générées correctement.<ul><li>C:/Users/Kevin/AppData/Local/Temp/processing_1061c34b459649df826021e1d805ffcc/2de50cc1426842a5aef21d658ecafb5c/output.gpkg</li><li>C:/Users/Kevin/AppData/Local/Temp/processing_1061c34b459649df826021e1d805ffcc/e9c26dbf60de49ae98a5621ac9e88d33/error.gpkg</li></ul>Vous pouvez vérifier le Panel de messages du journal dans la fenêtre principale de QGIS pour trouver plus d'informations à propos de l'exécution de l'algorithme.
Aucun espace ni caractère spéciaux ne se trouve sur mes dossiers. Je ne comprend pas.
#2 Tue 07 January 2020 10:43
romainbh
Re: QGIS: couches suivantes n'ont pas ete generees correctement
Il y a un bug dans certaines versions qui empêche d'enregistrer des couches temporaires. Avec la dernière version de QGIS, la 3.10.1, je n'ai plus ce souci. À tester ;-)
Sinon il suffit d'indiquer un nom de fichier et un chemin pour les couches en sortie.
#3 Tue 07 January 2020 14:37
preliator
Effectivement, j'ai réussi en faisant ça smile
Merci pour votre réponse.
