#1 Fri 21 February 2020 10:40
Stéphane_MANUEL
QGIS 3.4 Madeira: Qgis Cloud connexion impossible
Je souhaite partager une carte dans mon cloud cependant un message d'erreur s'affiche systématiquement
could not connect to server: Connection timed out (0x0000274C/10060)
    Is the server running on host "db.qgiscloud.com" (136.243.87.197) and accepting
    TCP/IP connections on port 5432?
  File "C:/Users/SMANU015/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 695, in update_local_layers
    self.update_local_data_sources(local_layers,  local_raster_layers)
  File "C:/Users/SMANU015/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 737, in update_local_data_sources
    self.update_data_sources_table_names()
  File "C:/Users/SMANU015/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 884, in update_data_sources_table_names
    schema_list = self.fetch_schemas(self.ui.cbUploadDatabase.currentText())
  File "C:/Users/SMANU015/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\qgiscloudplugindialog.py", line 1058, in fetch_schemas
    conn = self.db_connections.db(db).psycopg_connection()
  File "C:/Users/SMANU015/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgiscloud\db_connection_cfg.py", line 165, in psycopg_connection
    port=self.port
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\psycopg2\__init__.py", line 130, in connect
    conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
psycopg2.OperationalError: could not connect to server: Connection timed out (0x0000274C/10060)
Je suppose qu'il faut configurer un serveur proxy mais je vous avoue que je ne sais pas comment faire si qqun à une idéee je suis preneur.
Merci par avance
