#1 Thu 19 March 2009 08:57
schummi
"relations" does not exist - Geosource
j'ai installé la version 2.0.1 de Geosource sous Apache Tomcat.
L'application marche correctement sauf quand je souhaite supprimer des fiches de métadonnées depuis un utilisateur administrateur.
Voici l'erreur rencontrée :
2009-03-19 08:38:36,356 ERROR [jeeves.service] - Exception when executing service
2009-03-19 08:38:36,356 ERROR [jeeves.service] -  (C) Exc : org.postgresql.util.PSQLException: ERROR: relation "relations" does not exist
2009-03-19 08:38:36,356 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
  <message>ERROR: relation "relations" does not exist</message>
  <class>PSQLException</class>
  <stack>
    <at class="org.postgresql.core.v3.QueryExecutorImpl" file="QueryExecutorImpl.java" line="1548" method="receiveErrorResponse" />
    <at class="org.postgresql.core.v3.QueryExecutorImpl" file="QueryExecutorImpl.java" line="1316" method="processResults" />
    <at class="org.postgresql.core.v3.QueryExecutorImpl" file="QueryExecutorImpl.java" line="191" method="execute" />
    <at class="org.postgresql.jdbc2.AbstractJdbc2Statement" file="AbstractJdbc2Statement.java" line="452" method="execute" />
    <at class="org.postgresql.jdbc2.AbstractJdbc2Statement" file="AbstractJdbc2Statement.java" line="351" method="executeWithFlags" />
    <at class="org.postgresql.jdbc2.AbstractJdbc2Statement" file="AbstractJdbc2Statement.java" line="255" method="executeQuery" />
    <at class="jeeves.resources.dbms.Dbms" file="Dbms.java" line="211" method="selectFull" />
    <at class="jeeves.resources.dbms.Dbms" file="Dbms.java" line="176" method="select" />
    <at class="org.fao.geonet.guiservices.util.GetFeatureCatalog" file="GetFeatureCatalog.java" line="80" method="getRelatedId" />
    <at class="org.fao.geonet.services.metadata.Delete" file="Delete.java" line="88" method="exec" />
  </stack>
  <request>
    <language>fr</language>
    <service>metadata.delete</service>
  </request>
</error>
2009-03-19 08:38:36,356 INFO  [jeeves.service] -    -> dispatching to error for : metadata.delete
2009-03-19 08:38:36,450 INFO  [jeeves.service] -      -> transforming with stylesheet : C:\Program Files\geosource\web\geonetwork\/xsl/error.xsl
2009-03-19 08:38:36,575 INFO  [jeeves.service] -      -> end error transformation for : metadata.delete
2009-03-19 08:38:36,575 INFO  [jeeves.service] -    -> error ended for : metadata.delete
Avez vous une idée ?
#2 Thu 19 March 2009 09:20
Bruno
Re: "relations" does not exist - Geosource
Je déplace votre message dans le forum [geolibre] où il aura sa place:
http://georezo.net/forum/search.php?sea … =geosource
Bonne journée, même si celle-ci semble mal démarrée wink
Bruno
#3 Thu 19 March 2009 09:23
Yves
Lieu: Aix-les-Bains
Soit l'install s'est mal passée et il manque une table dans la base, soit un mot-clé n'est pas protégé (j'en doute). Pouvez tenter de recommencer l'installation dans une nouvelle base, en faisant attention à tout message d'erreur !?
#4 Thu 19 March 2009 09:33
schummi
Merci Yves,
c'est parfois les gestes les plus simples les plus efficaces !!
J'ai effectivement recrée ma base et je retrouve maintenant une table relations qui était inexistante. Par contre, je ne sais pas pourquoi cette table n'avait pas été créée ...
Autre question concernant la saisie. Il y a t-il un document décrivant de façon "explicite" les messages d'erreurs résultant d'une saisie incomplète ? Par exemple, lorsque j'essaye de valider ma fiche, j'ai un retour d'erreur :
Exception in startElement: cvc-complex-type.4: Attribute 'isoType' must appear on element 'fra:FRA_DataIdentification'.
Et ce message ne me parle pas vraiment ...
Dernière modification par schummi (Thu 19 March 2009 09:34)
#5 Thu 19 March 2009 09:44
Yves
Lieu: Aix-les-Bains
Bien pour la base relations wink tu peux tenter de récupérer le schéma de la table pour la créer dans ta première base si tu as des données cela sera plus simple wink
Pour le message d'erreur, je ne sais, je n'utilise pas GeoSource ^^
#6 Thu 19 March 2009 11:02
Etienne Taffoureau
Le message d'erreur signifie qu'il manque un attribut de type 'isoType' dans la balise XML, obligatoire dans le schema ISO19139 profil France. Toutefois, il est possible que ce message apparaisse même lorsque cet attribut est présent. Dans ce cas, il vous suffit d'aller dans la vue 'XML' et de valider.
Etienne TAFFOUREAU
