#1 Mon 30 November 2009 15:07
Sortie de GDAL/OGR en version 1.6.3
GDAL/OGR vient de sortir en version 1.6.3. Ce sera sans doute la dernière de la lignée des 1.6.x, la prochaine devrait être 1.7.0
A noter que la 1.7 apportera notamment de grosses évolutions sur le driver PostGIS.
Pas d'énorme révolutions donc, principalement des corrections de bugs, assez nombreuses toutefois et toujours bonnes à prendre.
Voici l'annonce en anglais de la nouvelle version. Si l'Osgeo-fr la traduit, Yves viendra remplacer ou compléter avec la version française.
The GDAL team is pleased to announce the release of GDAL 1.6.3.
http://download.osgeo.org/gdal/gdal-1.6.3.tar.gz
http://download.osgeo.org/gdal/gdal163.zip
The following issues were addressed in this release:
General:
* r13533 (ogr postgis plugin) have been added to the stable branch only <http://trac.osgeo.org/gdal/ticket/3125>
* GRIB detection not thread safe <http://trac.osgeo.org/gdal/ticket/3209>
GDAL:
* GDALRasterizeLayers() and GDALRasterizeGeometries() segfault when passed invalid band numbers <http://trac.osgeo.org/gdal/ticket/3146>
* Patch for HDF5 block size recognition <http://trac.osgeo.org/gdal/ticket/2270>
* Gdal doesn't calculate stats correctly if it is negative number <http://trac.osgeo.org/gdal/ticket/2511>
* ERS file pointing to an ECW file is not opening when a full path name is not specified <http://trac.osgeo.org/gdal/ticket/2907>
* Keyword causing format unrecognized (PDS) <http://trac.osgeo.org/gdal/ticket/2956>
* Add support for large NITF files <http://trac.osgeo.org/gdal/ticket/2989>
* do not remove leading spaces after TRE=xxxx= metadata when writing them <http://trac.osgeo.org/gdal/ticket/3088>
* [PATCH] TSX COSAR driver and 'pixel validity mask' <http://trac.osgeo.org/gdal/ticket/3112>
* GDALDataset::BlockBasedRasterIO() does not use overviews <http://trac.osgeo.org/gdal/ticket/3124>
* SIGBUS when reading A.TOC on Solaris <http://trac.osgeo.org/gdal/ticket/3130>
* Cleanup of drivers when using ECW data is very expensive <http://trac.osgeo.org/gdal/ticket/3134>
* When PIXELTYPE=SIGNEDBYTE, band.GetStatistics returns wrong values <http://trac.osgeo.org/gdal/ticket/3151>
* HFA doesn't support reading COMPRESSED + SIGNEDBYTE <http://trac.osgeo.org/gdal/ticket/3152>
* undefined reference to ... error with gdalbuildvrt.cpp <http://trac.osgeo.org/gdal/ticket/3167>
* variation on label to image pointer (PDS) <http://trac.osgeo.org/gdal/ticket/3177>
* GDALGridCreate with NULL progress callback function <http://trac.osgeo.org/gdal/ticket/3189>
* ERS driver fails with ERSs containing relative paths to non-ERStorage rasters <http://trac.osgeo.org/gdal/ticket/3196>
* Wrong type casting in GDALGrid data metrics functions <http://trac.osgeo.org/gdal/ticket/3207>
* HDF5 driver crashes with stackoverflow on this HDF5 image <http://trac.osgeo.org/gdal/ticket/3218>
Utilities:
* Python utililities should support command-line wildcards <http://trac.osgeo.org/gdal/ticket/2783>
* gdalbuildvrt -resolution lowest/highest does not work correcty for y pixel size <http://trac.osgeo.org/gdal/ticket/3198>
* [PATCH] Part of the reprojected image is missing from GDAL 1.6.0 along 180E/180W longitude <http://trac.osgeo.org/gdal/ticket/3206>
OGR:
* OGRLayer::GetFIDColumn() and GetGeometryColumn() just return empty strings from Python bindings <http://trac.osgeo.org/gdal/ticket/2694>
* GML read failure for GDAL 1.6+ <http://trac.osgeo.org/gdal/ticket/2948>
* GML reading problems with Xerces 3.x <http://trac.osgeo.org/gdal/ticket/3156>
* OGRLayer::GetFeatureCount returns a wrong value for SOUNDG layer <http://trac.osgeo.org/gdal/ticket/3163>
* XPlane driver causes fatal memory allocation in ogrinfo/ogr2ogr <http://trac.osgeo.org/gdal/ticket/3164>
Configuration:
* libtool: /bin/sh: arg list too long (powerpc-ibm-aix5.3) <http://trac.osgeo.org/gdal/ticket/3080>
* Error when building the gdal 1.6.2 for Linux <http://trac.osgeo.org/gdal/ticket/3149>
Python:
* Add __version__ to python bindings <http://trac.osgeo.org/gdal/ticket/3137>
* ReadRaster() crashes when GDAL is built with MinGW <http://trac.osgeo.org/gdal/ticket/3173>
OGR Spatial References:
* EPSG:3785 does not support spherical mercator hack <http://trac.osgeo.org/gdal/ticket/3136>
* Add 2 NZ coordinate system definition to mitab driver <http://trac.osgeo.org/gdal/ticket/3187>
Matthieu
Découvrez la constellation de satellites RapidEye, lancée le 29 août 2008
http://www.rapideye.de
Découvrez le blog du Master TGAE et les stages que suivent ses étudiants.
http://tgae0607.free.fr
#2 Tue 01 December 2009 20:12
- rouault
Re: Sortie de GDAL/OGR en version 1.6.3
Matthieu,
Merci d'avoir relayé l'annonce. Juste quelques précisions :
* la politique des versions mineures (numéro Z dans X.Y.Z) est de stabiliser la version X.Y.0, et donc d'apporter effectivement uniquement des corrections d'anomalies, et ponctuellement quelques petites évolutions. Les grosses évolutions sont réservées au changement de Y.
* il est probable qu'une dernière version 1.6.4 soit diffusée après la sortie de la 1.7.0 (en tout cas, quelques corrections s'y sont déjà empilées depuis la sortie de la 1.6.3 ;-)). Si on prend l'exemple de l'année dernière, la version 1.5.4 était sortie après la 1.6.0.
* depuis tout à l'heure, un calendrier a été fixé pour la 1.7.0. L'objectif est qu'elle sorte avant le 31 décembre. Les testeurs des versions beta puis release candidate seront les bienvenus.
* pour ceux qui brûlent déjà de connaître les nouveautés de la 1.7.0, un premier jet des changements depuis la 1.6.0 jusqu'à l'état fin août est disponible : http://trac.osgeo.org/gdal/browser/trunk/gdal/NEWS. Dans les choses importantes qui s'y sont ajoutées depuis, il y a de nouveaux drivers raster (Rasterlite, WKTRaster, BAG) et un driver vecteur probablement très attendu : DXF en lecture/écriture, encore en développement (gestion préliminaire en lecture à l'heure actuelle).
Dernière modification par rouault (Wed 02 December 2009 00:44)
