#1 Thu 15 April 2010 23:45
- ahmedamin
Postgresql new base type
Hi
I'm writing new basic type written with C with postgresql, this is a geospatial type which contains timestamp,char * and spatial(point,linestring) attributes.
I tried the complex example and it works well on postgresql server 8.3 but when I made my type I have problems with input and output functions,
The type should be like that
typedef struct mytype
char * type;
timestamp* te;
timestamp* ts;
geometry * l;
} Mytype;
I don't what libraries should be included to get timestamp type
Datum
mytype_in(PG_FUNCTION_ARGS)
char *str = PG_GETARG_CSTRING(0);
char *l1,*te1,*ts1;
char *type1 ;
Mytype*result;
if (sscanf(str, "( %s )", type1, te1,ts1,l1) != 4)
ereport(ERROR,
(errcode(ERRCODE_INVALID_TEXT_REPRESENTATION),
errmsg("invalid input syntax for mytype: \"%s\"",
str)));
result = (Mytype*) palloc(sizeof(Mytype));
result->te = te1;
result->ts = ts1;
result->type = type1;
PG_RETURN_POINTER(result);
PG_FUNCTION_INFO_V1(mytype_out);
Datum
mytype_out(PG_FUNCTION_ARGS)
Mytype *mytype= (Mytype*) PG_GETARG_POINTER(0);
char *result;
result = (char *) palloc(1000);
snprintf(result, 100, "( %s , %s , %s , %s )",mytype ->type, mytype->te,mytype->ts,mytype->l);
PG_RETURN_CSTRING(result);
Please tell me what's wrong with this definition, there is no compilation problem, I created a table with mytype attribute insert works well but when I select data from this table postgresql server goes down and restart
Thank you in advance
Best Regards
SETHOM Ahmed Amin
Mobile: + 216 40 175 841 begin_of_the_skype_highlighting + 216 40 175 841 end_of_the_skype_highlighting
#2 Fri 16 April 2010 01:40
Re: Postgresql new base type
Hello,
I'm not sure it's the best place for asking this kind of things : you are on a francophone forum.
Moreover, most people on this forum are gis proficient but don't really do programmation.
Someone can answer you, maybe...
Have a look on the Postgis-users mailinglist ( http://postgis.refractions.net/mailman/ … tgis-users ) or on the postgresql mailinglists ( http://archives.postgresql.org/) and post your question. You will get further answers from PostgreSQL experts compare to here.
Regards
ThomasG
PS: You're always welcome but in french, please ![]()
#3 Fri 16 April 2010 09:01
- ahmedamin
Merci Thomas
J'ai bien postulé un message dabns la liste mailing de postgresql et je suis en attente d'une réponse. ![]()
