#1 Sat 27 November 2010 16:56
mfvallet
Lieu: Lanton
Mapserver/ openlayers : erreur d'affichage d'une couche WFS
Je suis en train de mettre en place un site utilisant mapserver (MS4W), openlayers, postgresql.
J'ai mis en place une vue dans postgresql pour récupérer un ensemble  de mailles en lambert 93
J'arrive à les visualiser en WMS mais impossible de le faire en WFS.
Affichage dans Firebug :
http://localhost/cgi-bin/mapserv.exe?map=chemin-vers-mapfile/monmap.map&typeName=mon-layer&srsName=EPSG%3A2154&extractAttributes=true&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A2154&BBOX=-1491848.9541556,5635344.8768792,2381648.9541556,7236955.1231208
Unsupported geometry type: Box
http://localhost/openlayers/lib/OpenLayers/Format/XML.js
Line 83
Voici le fichier php
var wfsF = new OpenLayers.Layer.WFS(
            "wfs","http://localhost/cgi-bin/mapserv.exe?map=chemin-vers-mapfile/monmap.map&",
                typeName: 'mon-layer',
                srsName: "EPSG:2154",
                extractAttributes: true
            {'reproject': true}
et une partie du mapfile
MAP
    NAME ma_carte
    SIZE 600 518
    IMAGETYPE PNG
    STATUS ON
    EXTENT -97900 1726600 893200 2274800
    UNITS METERS
    CONFIG "CGI_CONTEXT_URL" "1"
    CONFIG "MS_ERRORFILE" "chemin-vers/ms_error.txt"
    OUTPUTFORMAT ... END
    PROJECTION
        "init=epsg:2154"
    END #projection
    WEB
        IMAGEPATH "chemin-vers/tmp/"
        imageurl "chemin-vers/tmp/"
        TEMPLATE  "chemin-vers/template/template.htm"
        METADATA
            ### WMS
            "wms_title"            "wms test"
            "wms_onlineresource"      "http://localhost/cgi-bin/mapserv.exe?map=chemin-vers/mapfile/monmap.map"
            "wms_srs"                "EPSG:2154"
            "wms_format"            "image/png"
            ### WFS
            "wfs_title"                    "wfs test"
            "wfs_onlineresource"      "http://localhost/cgi-bin/mapserv.exe?map=chemin-vers/mapfile/monmap.map&"
            "wfs_version"             "1.0.0"
            "wfs_abstract"            "Carte"
            "wfs_srs"                      "EPSG:2154"
            "wfs_format"                  "image/png"
            "wfs_filter"               "GET"
        END # METADATA
    END # WEB
    LAYER
        NAME "mon-layer"
        CONNECTIONTYPE POSTGIS
        CONNECTION "host=localhost dbname=### user=### password=### port=5432"
        DATA "geom_the FROM mon-layer as foo using unique gid using SRID=2154"
        TYPE POLYGON
        STATUS ON
        METADATA
            ### WMS
            "wms_title"            "mon-layer"
                    "wms_include_items"         "all"
            ### WFS
            "wfs_title"                "mon-layer"
            "wfs_typename"            "mon-layer"
            "wfs_connectiontimeout"     "60 "
            "wfs_maxfeatures"           "100"
            "gml_featureid"             "pt_gid"
            "gml_include_items"         "all"
            "gml_geometries"        "geom_the"
        END # METADATA
        PROJECTION
            "init=epsg:2154"
        END # PROJECTION
        DUMP TRUE
        CLASS ... END # class
    END # layer
END
Je n'arrive pas à voir ce qui ne va pas.
Mon objectif est de pouvoir ensuite appliquer une requête sur la couche WFS et ne montrer qu'une partie des données.
Dernière modification par mfvallet (Sat 27 November 2010 16:58)
