GeoDataDays 2025
#1 Mon 29 August 2011 18:40
aminealaoui
demande d'aide pour un problème dans WMSGetFeatureInfo de OpenLayers
bonjour ,
cher amies j'ai besoin de votre aide je  cherche a afficher un ensemble des couches WMS de GeoServer dans une page web  grâce a OpenLayers
et lors de click sur la couche je veut charger les donnes grâce a WMSGetFeatureInfo j'ai trouvé un exemple voici le lien http://openlayers.org/dev/examples/getf … ntrol.html  j’arrive a afficher les couches mais lors de click les donnes ne sont pas charge et voci le message d'erreur qu'il me donne
#!/usr/bin/env python """This is a blind proxy that we use to get around browser restrictions that prevent the Javascript from loading pages not on the same server as the Javascript. This has several problems: it's less efficient, it might break some sites, and it's a security risk because people can use this proxy to browse the web and possibly do bad stuff with it. It only loads pages via http and https, but it can load any content type. It supports GET and POST requests.""" import urllib2 import cgi import sys, os # Designed to prevent Open Proxy type stuff. allowedHosts = ['www.openlayers.org', 'openlayers.org', 'labs.metacarta.com', 'world.freemap.in', 'prototype.openmnnd.org', 'geo.openplans.org', 'sigma.openplans.org', 'demo.opengeo.org', 'www.openstreetmap.org', 'sample.azavea.com', 'v2.suite.opengeo.org', 'v-swe.uni-muenster.de:8080', 'vmap0.tiles.osgeo.org', 'www.openrouteservice.org'] method = os.environ["REQUEST_METHOD"] if method == "POST": qs = os.environ["QUERY_STRING"] d = cgi.parse_qs(qs) if d.has_key("url"): url = d["url"][0] else: url = "http://www.openlayers.org" else: fs = cgi.FieldStorage() url = fs.getvalue('url', "http://www.openlayers.org") try: host = url.split("/")[2] if allowedHosts and not host in allowedHosts: print "Status: 502 Bad Gateway" print "Content-Type: text/plain" print print "This proxy does not allow you to access that location (%s)." % (host,) print print os.environ elif url.startswith("http://") or url.startswith("https://"): if method == "POST": length = int(os.environ["CONTENT_LENGTH"]) headers = {"Content-Type": os.environ["CONTENT_TYPE"]} body = sys.stdin.read(length) r = urllib2.Request(url, body, headers) y = urllib2.urlopen(r) else: y = urllib2.urlopen(url) # print content type header i = y.info() if i.has_key("Content-Type"): print "Content-Type: %s" % (i["Content-Type"]) else: print "Content-Type: text/plain" print print y.read() y.close() else: print "Content-Type: text/plain" print print "Illegal request." except Exception, E: print "Status: 500 Unexpected Error" print "Content-Type: text/plain" print print "Some unexpected error occurred. Error text was:", E
et Merci d'avance pour votre réponse,
#2 Mon 05 September 2011 14:16
aminealaoui
Re: demande d'aide pour un problème dans WMSGetFeatureInfo de OpenLayers
chère amie je trouve le même problème pour tous les exemple de openLayers
est ce qu'il faut faire une modification pour le fichier proxy.cgi ?? car ce message d'erreur vient de ce fichier
j’attende votre aides svp je suis vraiment bloquer et merci d’avance
