#1 Mon 12 December 2016 14:41
Ricola62
[ARCGIS 10.3.1] la fonction "SetParameterAsText"
je voudrais avoir votre avis sur cette fonction "SetparameterAsText" via le script suivant
a priori il y a des erreurs mais je me casse la tête dessus.
import arcpy, os, sys
inputTable = arcpy.GetParameterAsText(0) # This is a table loaded into ArcMap
Space = arcpy.GetParameterAsText(1)
outputname = arcpy.GetParameterAsText(2)
outputtable = os.path.join(Space, outputname)
# Get field mappings of Input Table
fieldMappings = arcpy.FieldMappings()
fieldMappings.addTable(inputTable)
# Create an empty FieldMappings Object
newFieldMappings = arcpy.FieldMappings()
# Add fields in desired order. Note field index must be known
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(4))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(8))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(10))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(11))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(12))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(7))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(14))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(15))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(13))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(5))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(0))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(6))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(1))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(2))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(9))
newFieldMappings.addFieldMap(fieldMappings.getFieldMap(3))
# Create Table
Final = arcpy.TableToTable_conversion(inputTable, Space, outputname, None, newFieldMappings)
Sortie = arcpy.SetParameterAsText(4, "Final")
Ce script permettrait de réorganiser les colonnes d'une table et ensuite intégré sur Model Builder, j'utilise la sortie pour exporter la table en excel.
#2 Fri 23 December 2016 14:47
Franck B
Lieu: PACA
Re: [ARCGIS 10.3.1] la fonction "SetParameterAsText"
Le script renvoie en paramètre de sortie la chaine de caractères "Final".
Le c ode ci-dessous permettrait de renvoyer le chemin d'accès à la table réorganiser :
Sortie = arcpy.SetParameterAsText(4, outputtable)
Franck
