#1 Wed 01 August 2007 09:38
Pierre_L
Lieu: Nogent sur Vernisson
[ArcGIS 9.2] Sortie du service pack 3
Tout ou presque est dans le titre puisqu'en effet ESRI a sorti le SP3 de la version 9.2 d'ArcGIS.
Tous les fichiers peuvent être récupérés ici :
ArcIMS: http://support.esri.com/index.cfm?fa=do … etaID=1317
ArcSDE: http://support.esri.com/index.cfm?fa=do … etaID=1316
ArcGIS: http://support.esri.com/index.cfm?fa=do … etaID=1315
Pierre.
#2 Wed 01 August 2007 10:44
Bruno
Re: [ArcGIS 9.2] Sortie du service pack 3
Merci.
Bruno
#3 Thu 02 August 2007 11:23
janyv
Lieu: Montreuil, France
Merci !
bonne journée
yvan.
Si tu ne sais pas demande, si tu sais partage smile
#4 Fri 03 August 2007 16:40
Pierre_L
Une nouvelle de dernière minute, ou plutôt deux
1 - Le lien vers le service pack 3 est désactivé
2 - Un début explication du pourquoi du retrait du lien vers le SP3
From someone important,
There is a problem in SP3 related to Desktop, Engine, and Server
developers, but it could end up on standard desktops if users have extra
components or extensions that include .NET ArcObjects-developed
customizations. This includes coding against the GP tools.
1. End-users will simply get "Runtime" errors when certain functions are
used.
2. Developers will get "incorrect data type" errors when trying to
compile.
We have since removed the download links from the support center site.
Worse, SP3 cannot be uninstalled. The new fixed SP3 will be posted
tomorrow for those who haven't installed SP3 yet. In addition, there
will be an extra download put up there which fixes the problem for
people who have already installed the SP3. For those who cannot wait
until tomorrow, rolling back will require a full uninstall/reinstall.
Bonne journée,
(sauf pour ceux qui ont déjà installé le service pack et qui se demandent ce qui va encore leur tomber dessus)
Pierre
Dernière modification par Pierre_L (Fri 03 August 2007 16:40)
#5 Mon 06 August 2007 14:27
Bruno
Des nouvelles ici.
Bruno
#6 Wed 22 August 2007 08:21
gmtc78
après avoir installé le SP3 et son supplément français, on remarque qu'il y a beaucoup plus d'instructions en anglais que dans la version précédente, notamment dans les menus Édition, Affichage et Insérer ou encore dans le menu contextuel des propriétés des tables attributaires.
Peut-être faut-il s'attendre à la sortie d'un nouveau patch correctif ?
#7 Tue 04 September 2007 07:56
gmtc78
voici la réponse d'Esri suite au problème de traduction de la version française du SP3.
"Suite à la remontée de ces problèmes de traduction par nos utilisateurs et à la reproduction de ces problèmes sur certains de nos postes, nous avons effectivement modifié  le  service pack 3 français.
Un nouveau service pack 3 français amélioré a été mis en ligne à la place de l’ancien depuis la semaine dernière sur :
http://support.esrifrance.fr/index.asp? … ArcGIS.htm
Nous vous invitons à re-télécharger ce service pack et à l’installer par-dessus le précédent.
Nous vous prions de nous excuser pour la gêne occasionnée"
#8 Tue 04 September 2007 09:22
Christophe Tourret
Pas grand chose à ajouter à l'explication du support reproduite ci-dessus. La version mise en ligne par ESRI France le 16 août dernier comportait une anomalie amenant sur certains postes de travail à une traduction incomplète. Cette version a été remplacée le 24 août dernier par une version corrigée.
Ceux d'entre vous qui ont rencontré ce problème de traduction incomplète, le correctif est de re-télécharger la VF du SP3 sur le site ESRI France, puis de l'appliquer à votre installation.
Pour être sur d'avoir installé la bonne version, vérifier dans Programmes/ArcGIS/Lisez-moi Version Française. Ce fichier doit afficher sur la deuxième ligne "mise à jour 9.2.1380.a.1"
Merci de la réactivité des premiers utilisateurs témoins du problème et toutes nos excuses pour la gêne engendrée.
Christophe Tourret
#9 Tue 18 September 2007 13:41
fredP
Lieu: Versailles
Suite à la MAJ ArcSDE et ArcGIS version 9.2, la calibration des routes (format SDE) est aléatoire (sur 300 enregistrements seulement une 100 aine sont calibrés)!!!. Par contre la calibration fonction pour les Géodatabases.
Après avoir MAJ le service pack 3, le pb est tjs présent!!!
Avez vous rencontré ce pb et avez vous une solution sachant que le support Esri n'a tjs pas trouvé d'élément de réponse.
Merci d'avance.
