#1 Mon 07 December 2009 15:49
Pierre
DesCartesPourUnMondeMeilleur
Erreur sur une boucle transformer
Je partage ma connaissance FME avec une de mes collègues et donc travaille avec elle sur un cas concret. je la guide dans la construction de son workbench. Nous devons utiliser une boucle dans celui-ci (pas de TCL, encore trop compliqué).
Mais le workbench me renvoie une erreur : 2009-12-07 15:28:29| 473.9|  0.0|ERROR |Transformer/Factory boucle_geocodage_FeatureMerger_3 is blocking and cannot be used in a loop, but was found between 'Loop to boucle_geocodage_1 Input Splitter' and 'boucle_geocodage_1 Input Splitter'
2009-12-07 15:28:29| 473.9|  0.0|STATS |Storing feature(s) to FME feature store file `E:\FME\fichiers configurations\economie/xls_ado_oracle8i2apic4_geocodage_etablist_log.ffs'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Feature Type: `boucle_geocodage_1'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `ADRESSE' has value `82 B BOULEVARD DU PRESIDENT WILSON'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `COMMUNE' has value `REIMS'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `COMPL_NUM1' has value `B'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `COMPL_NUM3' has value ` '
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `COMPL_NUM4' has value `B'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `F1' has value `etablissements'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `F40' has value `*****'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `ID_GEOCOD' has value `454729082B'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `ID_GEOCOD2' has value `454729083'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `ID_VOIE' has value `4547290'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `INSEE_CO' has value `454'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(64 bit real)      : `INSEE_DEPT' has value `51'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `INSEE_co' has value `454'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `LIBELLE' has value `DU PRESIDENT WILSON'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(32 bit integer)   : `Loop to boucle_geocodage_1 Input Splitter.BranchingFactory.Count' has value `1'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `NOM' has value `ALPHA SANTE SERVICE'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `NUMERO_POSTAL' has value `82B'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `NUM_POSTAL' has value `82B'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(64 bit real)      : `NUM_VOIE' has value `82'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `NUM_VOIE_+' has value `83'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `RIVOLI_VOIE' has value `7290'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-16le): `VOIE' has value `BD'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_count' has value `59'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_max' has value `96'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_mean' has value `54.5084745762712'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_median' has value `55'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_min' has value `13'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_mode' has value `55'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_numeric_count' has value `59'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_range' has value `83'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_stdev' has value `21.1956183511625'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `_sum' has value `3216.0'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `db_type' has value `db_none'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `fme_basename' has value `etablissement_geocodage'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `fme_dataset' has value `E:\FME\fichiers_donnees\test_economie\etablissement_geocodage.xls'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `fme_feature_type' has value `a geocoder'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `fme_type' has value `fme_no_geom'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(32 bit integer)   : `multi_reader_full_id' has value `0'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(32 bit integer)   : `multi_reader_id' has value `0'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `multi_reader_keyword' has value `XLS_ADO_1'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(string)           : `multi_reader_type' has value `XLS_ADO'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Attribute(encoded: utf-8)   : `rivoli_v' has value `7290'
2009-12-07 15:28:29| 473.9|  0.0|ERROR |Geometry Type: Unknown (0)
2009-12-07 15:28:29| 473.9|  0.0|ERROR |===========================================================================
Et j'avoue ne pas savoir ce qui ne va pas.
Qu'est ce que le 'Loop to boucle_geocodage_1 Input Splitter' et le 'boucle_geocodage_1 Input Splitter'. Je n'ai aucun transformer de ce nom, seulement un loop_to...
Quelqu'un a-t'il déjà rencontré ce problème auparavant ?
D'après la documentation, cette erreur est normale.
Dernière modification par Pierre (Wed 16 December 2009 14:20)
