#1 Wed 06 January 2010 12:19
nicolas.leclerc
openlayers et niveaux de zoom
J'essaye desesperement d'afficher mes cartes en fonctiondes niveaux de zoom avec openlayers mais sans succès, quelqu'un aurait t'il une idée ??
merci d'avance !
mon mapfile
MAP
   NAME "tutorial"
   SIZE 1020 500
   EXTENT 397718.645855151000000 172890.240151574000000    503353.752958698000000 237779.432429958000000
   UNITS METERS
   IMAGECOLOR 255 255 255
OUTPUTFORMAT
  NAME aggpng24
  DRIVER AGG/PNG
  MIMETYPE "image/png"
  IMAGEMODE RGB
  EXTENSION "png"
END
WEB
IMAGEPATH "C:/ms4w/Apache/htdocs/nl/tmp"
IMAGEURL "tmp/"
TEMPLATE "C:/ms4w/Apache/htdocs/nl/test6.php"
METADATA
    "wms_title"            "WMS"
    "wms_onlineresource"   "http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/nl/test4.map"
    "wms_srs"              "EPSG:27561"
END # Metadata
END
PROJECTION
     "init=epsg:27561"
END
#Raster
LAYER
        NAME "m_500_estuaire"
        STATUS ON
        TYPE RASTER
        DATA "C:/ms4w/Apache/htdocs/nl/raster/m_500_estuaire.ecw"
        MAXSCALEDENOM 3000000
        MINSCALEDENOM 200000
        METADATA
           "wms_title"         "m_500_estuaire"
        END
        PROJECTION
           "init=epsg:27561"    # Lambert 1 Nord
        END
    END
LAYER
        NAME "m_100_ccih"
        STATUS ON
        TYPE RASTER
        DATA "C:/ms4w/Apache/htdocs/nl/raster/m_100_ccih.ecw"
        MAXSCALEDENOM 199999
        MINSCALEDENOM 35000
        METADATA
           "wms_title"         "m_100_ccih"
        END
        PROJECTION
        END
END
LAYER
        NAME "m_025_ccih"
        STATUS ON
        TYPE RASTER
        DATA "C:/ms4w/Apache/htdocs/nl/raster/m_025_ccih.ecw"
        MAXSCALEDENOM 34999
        MINSCALEDENOM 12000
        METADATA
           "wms_title"         "m_025_ccih"
        END
        PROJECTION
        END
END
LAYER
        NAME "m_010_codah_dense"
        STATUS ON
        TYPE RASTER
        DATA "C:/ms4w/Apache/htdocs/nl/raster/m_010_codah_dense.ecw"
        MAXSCALEDENOM 11999
        MINSCALEDENOM 3000
        METADATA
           "wms_title"         "m_010_codah_dense"
        END
        PROJECTION
        END
END
LAYER
        NAME "m_002_codah_dense"
        STATUS ON
        TYPE RASTER
        DATA "C:/ms4w/Apache/htdocs/nl/raster/m_002_codah_dense.ecw"
        MAXSCALEDENOM 2999
        MINSCALEDENOM 500
        METADATA
           "wms_title"         "m_002_codah_dense"
        END
        PROJECTION
        END
END
END # mapfile
<html>
    <head>
    <script src="./javascript/OpenLayers/OpenLayers.js" type="text/javascript"></script>
    <script type="text/javascript">
           var map;
            function init() {
               map= new OpenLayers.Map('map',
               {maxExtent:new OpenLayers.Bounds(397718,172890,503353,237779),
                maxResolution: 'auto',
                units:'m',
                numZoomLevels: 11,
                scales: [1500000, 500000, 250000, 100000, 50000,
                      25000, 10000, 5000, 2000, 1000, 500],
                projection:'EPSG:27561'});
               var wms = new OpenLayers.Layer.WMS(
                    "m_500_estuaire",
                    "http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/nl/test4.map",
                    {layers: 'm_500_estuaire'}, {minScale: '200000'}, {maxScale: '3000000'}
                var wms2 = new OpenLayers.Layer.WMS(
                    "m_100_ccih",
                    {layers: 'm_100_ccih'}, {minScale: '35000'}, {maxScale: '199999'}
                var wms3 = new OpenLayers.Layer.WMS(
                    "m_025_ccih",
                    {layers: 'm_025_ccih'}, {minScale: '12000'}, {maxScale: '34999'}
                var wms4 = new OpenLayers.Layer.WMS(
                    "m_010_codah_dense",
                    {layers: 'm_010_codah_dense'}, {minScale: '11999'}, {maxScale: '3000'}
                var wms5 = new OpenLayers.Layer.WMS(
                    "m_002_codah_dense",
                    {layers: 'm_002_codah_dense'}, {minScale: '500'}, {maxScale: '2999'}
                map.addLayers([wms, wms2, wms3, wms4, wms5]);
                var overview = new OpenLayers.Control.OverviewMap();
                map.addControl(overview);
                map.addControl(new OpenLayers.Control.ScaleLine({
                div: document.getElementById("scalebar")
                map.addControl(new OpenLayers.Control.LayerSwitcher());
                map.addControl(new OpenLayers.Control.MousePosition({
                div: document.getElementById("mouseposition")
                var panel = new OpenLayers.Control.Panel({
                div: document.getElementById("panel")
                map.addControl(panel);
                var history = new OpenLayers.Control.NavigationHistory();
                map.addControl(history);
                panel.addControls([history.next, history.previous]);
                map.zoomToMaxExtent();
        </script>
    </head>
    <body onload="init()">
        <div id="map"  style="width:100%; height: 80%"></div>
        <div id="mouseposition"></div>
        <div id="panel"></div>
        <div id="scalebar"></div>
    </body>
</html>
