#1 Thu 23 July 2015 11:16
- Pierre
QGIS 2.4 : Problème en customisation
Aloha
A la lecture du post de blog http://georezo.net/blog/geolibre/2011/0 … s-simples/ J'ai décidé de personnaliser mon interface. Porblème je narrive pas à revenir en arrière.
Voici ce que j'ai essayé en ligne de commande :
C:\PROGRA~1\QGISCH~1\bin>o4w_env.bat
C:\PROGRA~1\QGISCH~1\bin>REM Make parent of this script location our current directory,
C:\PROGRA~1\QGISCH~1\bin>REM converting UNC path to drive letter if needed
C:\PROGRA~1\QGISCH~1\bin>pushd C:\PROGRA~1\QGISCH~1\bin\
C:\PROGRA~1\QGISCH~1\bin>cd ..
C:\PROGRA~1\QGISCH~1>REM set OSGEO4W_ROOT to short path version
C:\PROGRA~1\QGISCH~1>for %i in ("C:\PROGRA~1\QGISCH~1") do set OSGEO4W_ROOT=%~fsi
C:\PROGRA~1\QGISCH~1>set OSGEO4W_ROOT=C:\PROGRA~1\QGISCH~1
C:\PROGRA~1\QGISCH~1>REM start with clean path
C:\PROGRA~1\QGISCH~1>set path=C:\PROGRA~1\QGISCH~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem
C:\PROGRA~1\QGISCH~1>for %f in ("C:\PROGRA~1\QGISCH~1\etc\ini\*.bat") do call "%f"
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\gdal.bat"
C:\PROGRA~1\QGISCH~1>SET GDAL_DATA=C:\PROGRA~1\QGISCH~1\share\gdal
C:\PROGRA~1\QGISCH~1>SET GDAL_DRIVER_PATH=C:\PROGRA~1\QGISCH~1\bin\gdalplugins
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\libgeotiff.bat"
C:\PROGRA~1\QGISCH~1>SET GEOTIFF_CSV=C:\PROGRA~1\QGISCH~1\share\epsg_csv
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\libjpeg.bat"
C:\PROGRA~1\QGISCH~1>set JPEGMEM=1000000
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\msvcrt.bat"
C:\PROGRA~1\QGISCH~1>rem This is just a dummy to make sure the for loop in ..\..\osgeo4w.bat
C:\PROGRA~1\QGISCH~1>rem always has some files to process.
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\msys.bat"
C:\PROGRA~1\QGISCH~1>PATH C:\PROGRA~1\QGISCH~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISCH~1\apps\msys\bin
C:\PROGRA~1\QGISCH~1>if not defined HOME set HOME=C:\Users\pierre.muckensturm
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\proj.bat"
C:\PROGRA~1\QGISCH~1>SET PROJ_LIB=C:\PROGRA~1\QGISCH~1\share\proj
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\python-core.bat"
C:\PROGRA~1\QGISCH~1>SET PYTHONHOME=C:\PROGRA~1\QGISCH~1\apps\Python27
C:\PROGRA~1\QGISCH~1>PATH C:\PROGRA~1\QGISCH~1\apps\Python27\Scripts;C:\PROGRA~1\QGISCH~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISCH~1\apps\msys\bin
C:\PROGRA~1\QGISCH~1>call "C:\PROGRA~1\QGISCH~1\etc\ini\qt4.bat"
C:\PROGRA~1\QGISCH~1>set QT_PLUGIN_PATH=C:\PROGRA~1\QGISCH~1\apps\Qt4\plugins
C:\PROGRA~1\QGISCH~1>set QT_RASTER_CLIP_LIMIT=4096
C:\PROGRA~1\QGISCH~1>popd
C:\PROGRA~1\QGISCH~1\bin>cd..
C:\PROGRA~1\QGISCH~1>\apps\grass\grass-6.4.3\etc\env.bat
Le chemin d'accès spécifié est introuvable.
C:\PROGRA~1\QGISCH~1>cd \apps\grass\grass-6.4.3\etc\
C:\PROGRA~1\QGISCH~1>cd apps\grass\grass-6.4.3\etc\
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>env.bat
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>rem Environmental variables for GRASS OSGeo4W installer
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GISBASE=C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GRASS_SH=C:\PROGRA~1\QGISCH~1\apps\msys\bin\sh.exe
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GRASS_WISH=C:\PROGRA~1\QGISCH~1\bin\wish.exe
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GRASS_PYTHON=python
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GRASS_PROJSHARE=C:\PROGRA~1\QGISCH~1\share\proj
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GRASS_HTML_BROWSER=explorer
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set PYTHONHOME=C:\PROGRA~1\QGISCH~1\apps\Python27
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GDAL_DATA=C:\PROGRA~1\QGISCH~1\share\gdal
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set PROJ_LIB=C:\PROGRA~1\QGISCH~1\share\proj
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set GEOTIFF_CSV=C:\PROGRA~1\QGISCH~1\share\epsg_csv
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>set PATH=C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISCH~1\apps\msys\bin;C:\PROGRA~1\QGISCH~1\apps\Python27\Scripts;C:\PROGRA~1\QGISCH~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISCH~1\apps\msys\bin
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3\etc>cd..
C:\PROGRA~1\QGISCH~1\apps\grass\grass-6.4.3>cd..
C:\PROGRA~1\QGISCH~1\apps\grass>cd..
C:\PROGRA~1\QGISCH~1\apps>cd..
C:\PROGRA~1\QGISCH~1>cd bin
C:\PROGRA~1\QGISCH~1\bin>path %OSGEO4W_ROOT%\apps\qgis\bin;%OSGEO4W_ROOT%\apps\grass\grass-6.4.3\lib;%PATH%
C:\PROGRA~1\QGISCH~1\bin>set QGIS_PREFIX_PATH=%OSGEO4W_ROOT:\=/%/apps/qgis
C:\PROGRA~1\QGISCH~1\bin>set GDAL_FILENAME_IS_UTF8=YES
C:\PROGRA~1\QGISCH~1\bin>set VSI_CACHE=TRUE
C:\PROGRA~1\QGISCH~1\bin>set VSI_CACHE_SIZE=1000000
C:\PROGRA~1\QGISCH~1\bin>qgis-bin.exe -nocustomization
C:\PROGRA~1\QGISCH~1\bin>Mais j'ai toujours une interface customisée, et plus problèmatique, sans aucun menu.
Que puis-je faire ?
Merci, merci d'avance.
Réponse à moi même :
Lire ce fil http://georezo.net/forum/viewtopic.php?pid=242604
Dernière modification par Pierre (Thu 23 July 2015 16:00)
#2 Tue 28 July 2015 09:09
- Louis B
Re: QGIS 2.4 : Problème en customisation
Question bête: N'est il pas possible de tout simplement ré-installer l'application ?
Louis
