#1 Thu 14 November 2013 10:56
CRPM-SIG
QGIS 2.0 (Fedora 19) : Erreur plugin DB Manager
Sous fedora 19 et qgis 2.0, me voilà avec une erreur sur le lancement de db manager (depuis aujourd'hui!)...voici ce qu'il m'affiche :
Une erreur est apparue lors de l'exécution du code python :
  File "/usr/share/qgis/python/plugins/db_manager/db_manager_plugin.py", line 66, in run
    from db_manager import DBManager
  File "/usr/lib64/python2.7/site-packages/qgis/utils.py", line 453, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/usr/share/qgis/python/plugins/db_manager/db_manager.py", line 28, in
    from .info_viewer import InfoViewer
  File "/usr/share/qgis/python/plugins/db_manager/info_viewer.py", line 26, in
    from .db_plugins.plugin import BaseError, DbError, DBPlugin, Schema, Table
  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/__init__.py", line 69, in
    initDbPluginList()
  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/__init__.py", line 43, in initDbPluginList
    exec( u"from .%s import plugin as mod" % name )
  File "", line 1, in
  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/spatialite/plugin.py", line 24, in
    from .connector import SpatiaLiteDBConnector
  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/spatialite/connector.py", line 29, in
    from pyspatialite import dbapi2 as sqlite
  File "/usr/lib64/python2.7/site-packages/pyspatialite/dbapi2.py", line 50, in
    version_info = tuple([int(x) for x in version.split(".")])
ValueError: invalid literal for int() with base 10: '2-spatialite'
Version de Python :
2.7.5 (default, Oct  8 2013, 12:19:40)
[GCC 4.8.1 20130603 (Red Hat 4.8.1-1)]
Version de QGIS :
2.0.1-Dufour Dufour, exported
Chemin vers Python : ['/home/crpmem/.qgis2/python/plugins/processing', '/usr/share/qgis/python', '/home/crpmem/.qgis2/python', '/home/crpmem/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib64/python27.zip', '/usr/lib64/python2.7', '/usr/lib64/python2.7/plat-linux2', '/usr/lib64/python2.7/lib-tk', '/usr/lib64/python2.7/lib-old', '/usr/lib64/python2.7/lib-dynload', '/usr/lib64/python2.7/site-packages', '/usr/lib64/python2.7/site-packages/geos', '/usr/lib64/python2.7/site-packages/gst-0.10', '/usr/lib64/python2.7/site-packages/gtk-2.0', '/usr/lib64/python2.7/site-packages/wx-2.8-gtk2-unicode', '/usr/lib/python2.7/site-packages', '/usr/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg-info', '/home/crpmem/.qgis2/python/plugins/DigitizingTools/tools', '/home/crpmem/.qgis2/python/plugins/mmqgis/forms', '/usr/share/qgis/python/plugins/fTools/tools']
Merci beaucoup pour votre expertise!
Dernière modification par CRPM-SIG (Thu 14 November 2013 10:57)
#2 Fri 15 November 2013 08:14
Leyan
Re: QGIS 2.0 (Fedora 19) : Erreur plugin DB Manager
L'erreur dit qu'il n'arrive pas à lire le numéro de version de spatialite. Il suppose que c'est une suite de nombre du style 3.0.1, mais dans ton cas il y a un suffixe "-spatialite".
Une solution peut être de vérifier si spatialite a été mis à jour récemment et revenir à l'ancienne version. Sinon, on peut essayer de remplacer la ligne de code par une ligne capable de lire la version, ou juste donner un numéro de version (qui correspond à peu près à la version installée quand même), du style "version_info=(3,0,1)".
Dernière modification par Leyan (Fri 15 November 2013 08:16)
#3 Fri 15 November 2013 09:56
CRPM-SIG
Bonjour et merci pour cette réponse !
Effectivement je suis en saptialite 4.1 ! Mais j'ai pas l'impression d'avoir fait une mise à jour dernièrement...y a t-il des personnes sous fedora 19 qui rencontre cette même erreur ?
#4 Mon 18 November 2013 16:28
CRPM-SIG
un petit up
#5 Tue 19 November 2013 10:33
CRPM-SIG
"Sinon, on peut essayer de remplacer la ligne de code par une ligne capable de lire la version, ou juste donner un numéro de version (qui correspond à peu près à la version installée quand même), du style "version_info=(3,0,1)""
N'étant pas très calé sur l'architecture de Qgis, quel fichier faut-il modifier exactement ? Merci
