#1 Fri 13 December 2013 14:39
diletant2
[Mapserver]Templating/HTML image map : shpxy renvoie tjs la même coord
Désolé pour l'anglais
Hi,
I’m encountering the same issue as the one described here
http://lists.osgeo.org/pipermail/mapser … 74454.html
I’ve a map’s source with multiple points (evenly distributed, not at the same place).
When I ask MapServer for a map, they get displayed well.
But when I request the HTML imagemap based on a template, the coordinates of each point are the same !
Though the rest of the templating works fine (for other attributes than coordinates)
My template is as follow:
<area shape="circle" coords="[shpxy proj=image yf=",30" xf=","]" title="[id]" alt="[type]">
MapServer request :
http://mapserver/cgi-bin/mapserv.exe?map=mymapfile.map&qlayer=layer1&searchmap=true&mode=nquery
output (sample) :
<area shape="circle" coords="152,1664,30" title="/aaOjl9fXYN6TuHVVSud+KcjpEc=" alt="T">
<area shape="circle" coords="152,1664,30" title="/GDyi/50wFeFHMBpkmJ2lBOIM28=" alt="R">
<area shape="circle" coords="152,1664,30" title="/GxS7hWNTKpIIyyfuQf9SB6jVK8=" alt="R">
I might come from the conversion of coordinates from map’s output projection to image pixels, based on EXTENT/SIZE/RESOLUTION.
Because when I remove “proj=image” inside the template string, I got the right coordinates for each result.
But even after trying to set these values (either inside the mapfile header, or inside the request), it doesn’t solve the problem.
Thanks for your help
Dernière modification par diletant2 (Fri 13 December 2013 14:40)
#2 Fri 13 December 2013 16:23
diletant2
Re: [Mapserver]Templating/HTML image map : shpxy renvoie tjs la même coord
ça doit avoir un rapport avec la version de Mapserver car ça ne marche pas sur des 6.X
alors que ça fonctionne sur des 5.X
