#1 Fri 08 July 2016 21:12
- laurent00
QGIS: cloud error upload data
bonsoir
lorsque je tente de charger des données j'ai le message suivant
Connection to database failed server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
File "/home/laurent/.qgis2/python/plugins/qgiscloud/qgiscloudplugindialog.py", line 839, in upload_data
self.db_connections.db(db_name), data_sources_items, self.maxSize)
File "/home/laurent/.qgis2/python/plugins/qgiscloud/data_upload.py", line 68, in upload
raise RuntimeError("Connection to database failed %s" % str(e))
RuntimeError: Connection to database failed server closed the connection unexpectedly
before or while processing the request.merci d'une aide
LJ
#2 Sat 09 July 2016 14:06
- laurent00
Re: QGIS: cloud error upload data
ok a priori je tenter de charger trop de choses, couches raster ...
j'ai donc construit un projet nouveau pour publier sur le qgis cloud
sympa ... http://qgiscloud.com/LJ01/webMap
LJ
