Pages: 1
- Sujet précédent - Clip grid with polygon 'NoneType' object has no attribute 'crs' Seelog - Sujet suivant
#1 Mon 13 March 2017 21:04
- drfrangipane
Dear all,
"Clip grid with polygon" with a lower resolution dem file,
j'utilise le modeleur qgis. quand j'execute le modèle et ses geotreatments: "Clip grid with polygon" sur un fichier MNT à 250 metres, tout se passe bien, apparemment, j'obtiens les résultats attendus.
2017-03-13T17:13:43 0 Commandes d'exécution SAGA
io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Users\aquesnel\AppData\Local\Temp\processingf5dc5fb6cb7947ee8284b056942375ff\99c223ed05e24d779d2fde239cfcec3b\FRANCEMNT250L93.sgrd" -FILES "C:/Users/aquesnel/.qgis2/processing/entree/MNT250_L93_FRANCE.TIF"
shapes_grid "Clip Grid with Polygon" -INPUT "C:\Users\aquesnel\AppData\Local\Temp\processingf5dc5fb6cb7947ee8284b056942375ff\99c223ed05e24d779d2fde239cfcec3b\FRANCEMNT250L93.sgrd" -POLYGONS "C:\Users\aquesnel\AppData\Local\Temp\processingf5dc5fb6cb7947ee8284b056942375ff\d65dc3598bb64c76804f4561543f5f0b\outputALGGRASS7V.BUFFER.DISTANCE1.shp" -OUTPUT "C:\Users\aquesnel\AppData\Local\Temp\processingf5dc5fb6cb7947ee8284b056942375ff\3ccff3d96dda44e2bfe36232a5c4b971\OUTPUT.sdat"
mais j'obtiens avec le meme modèle et algorithme de la librairie saga "Clip grid with polygon" cette fois sur un MNT france à 25metres (high resolution) un message d'erreurs
Clip Grid with Polygon: could not initialize data objects
Error: Grid file could not be opened.
Error: executing tool [Clip Grid with Polygon]
F:\PROGRA~3\qgis_2.18\bin>exit
Converting outputs
Echoué
Erreur lors de l'exécution de l'algorithme Clip grid with polygon 'NoneType' object has no attribute 'crs' See log for more details
2017-03-13T17:26:27 2 Uncaught error while executing algorithm
File "F:/PROGRA~3/qgis_2.18/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py", line 205, in execute
self.convertUnsupportedFormats(progress)
File "F:/PROGRA~3/qgis_2.18/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py", line 296, in convertUnsupportedFormats
crsid = layer.crs().authid()
AttributeError: 'NoneType' object has no attribute 'crs'
2017-03-13T17:26:27 2 Erreur lors de l'exécution de l'algorithme Clip grid with polygon
j'ai lu un conseil de désactivation de keep_resolution pour un autre algorithm tiré de gdal nommé ClipByMask.
je ne sais pas comment désactiver "keep_resolution" si ce paramètre existe dans le fichier GeoAlgorithm.py
merci de votre aide précieuse
Anne
Pages: 1
