#1 Mon 24 April 2017 16:05
lamia.hamou
probléme d'affichage de la carte
salut tous le monde;
je sais pas si je suis dans la bonne section, voila je développe une plate forme sur mapserver (ms4w) je désire avoir une carte contenant mes point d'interet. pour le points je les ai généré avec QGIS puis j'ai l'export a mapserver. quand je lance l'URL:
lamiapc/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map
  j'ai en sortie une page blanche, je sais pas ou est le problème.
voici un extrait du mapfile.map:
MAP
  NAME "QGIS-MAP"
  # Map image size
  SIZE 800 800
  UNITS dd
  EXTENT -1.972955 34.946392 1.483896 36.505612
  FONTSET 'C:/ms4w/Apache/htdocs/fonts.txt'
  SYMBOLSET 'C:/ms4w/Apache/htdocs/symbols.txt'
  PROJECTION
'init=epsg:4326'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE agg
  OUTPUTFORMAT
    NAME agg
    DRIVER AGG/PNG
    IMAGEMODE RGB
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH 'C:/ms4w/tmp/ms_tmp/'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '/tmp/'
    # WMS server settings
    METADATA
     'wms_title' 'Point_interet'
     'wms_onlineresource' 'http://lamiaPC:80/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map'
     'wms_srs' 'EPSG:4326'
     'wms_enable_request' '*'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See MapServer documentation
    TEMPLATE 'C:/Users/HOME/Desktop/index_map.html'
  END
  LAYER
    NAME 'lieu_interet'
    TYPE POINT
    DUMP true
    TEMPLATE "C:/Users/HOME/Desktop/index_map.html"
    CONNECTIONTYPE postgis
    CONNECTION "dbname='map_oran' host=localhost port=5432 user='postgres' password='*****' sslmode=disable"
    DATA 'latlong FROM "lieu_interet" USING UNIQUE lieuid USING srid=4326'
    METADATA
      'wms_title' 'lieu_interet'
    END
    STATUS ON
    TRANSPARENCY 100
    PROJECTION
  'init=epsg:4326'
    END
    CLASSITEM 'categorie'
    CLASS
      NAME "categorie = bibliotheque "
      EXPRESSION "bibliotheque "
       STYLE
         SYMBOL "sym_biblio"
         SIZE 16.0
         OUTLINECOLOR 0 0 0
         COLOR 224 236 247
       END
    END
    CLASS
      NAME "categorie = centre_commercial"
       EXPRESSION "centre_commercial"
       STYLE
        SYMBOL "sym_centrecommerce"
          SIZE 16.0
         OUTLINECOLOR 0 0 0
         COLOR 213 229 244
       END
et mon HTML:
<!-- MapServer Template -->
<html>
 <head>
  <title>Une carte simple avec OpenLayers</title>
  <script src="http://www.openlayers.org/api/2.12/OpenLayers.js"></script>
  <script type="text/javascript" src="http://maps.google.com/maps/api/js?v=3&amp;sensor=true&region=DZ&key=**************"></script>
  <script type="text/javascript">
    function init() {
    // Objet map:
        var map = new OpenLayers.Map('map', {projection:new OpenLayers.Projection('EPSG:4326')});
        // Couche GoogleMaps
        var gmap = new OpenLayers.Layer.Google( "Google" , {type: google.maps.MapTypeId.NORMAL}, {isBaseLayer:true} );
        map.addLayer(gmap);
        // Notre couche en WMS créée par MapServer
       var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS", "http://lamiaPC:80/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map", {layers: 'point_interet', transparent:"true"});
       map.addLayer(wms);
        // Etendue initiale de la carte
        map.zoomToExtent(new OpenLayers.Bounds([-1.972955, 1.483896, 34.946392, 36.505612]));
        // Ajout du sélectionneur de couches
    map.addControl(new OpenLayers.Control.LayerSwitcher());
  </script>
 </head>
 <body onload="init()">
  <div style="width:100%; height:100%" id="map"></div>
 </body>
</html>
qlq'un pourra m'aider s'il vous plait?
Dernière modification par lamia.hamou (Tue 25 April 2017 00:38)
#2 Wed 26 April 2017 21:06
Bruno
Lieu: Toulouse
Re: probléme d'affichage de la carte
Le sujet mériterait d'être renommé.
#3 Thu 27 April 2017 14:34
Yves
Lieu: Aix-les-Bains
Le plus simple pour débuguer :
1 tu appelles cette url http://lamiaPC:80/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map&VERSION=1.3.0&SERVICE=WMS&REQUEST=GetCapabilities et tu regardes les messages d'erreurs et d'alerte
2. tu actives les logs (cherches sur le site de mapserver.org wink
Y.
#4 Fri 28 April 2017 15:34
lamia.hamou
salut,
merci Yves pour votre réponse, j'ai fait appelle a l'URL    http://lamiaPC:80/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map&VERSION=1.3.0&SERVICE=WMS&REQUEST=GetCapabilities, apparemment il y a aucun message d'erreur
mon problème maintenant est quand je lance  http://lamiaPC:80/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/oranmap/mapfile/mapfile.map
j'aurais 2 options:
1. google maps -> la carte s'affiche normalement
2. openlayers WMS -> mes points s'affiche mais sur un fond blanc
donc se que je désire c'est que mes points doivent être placés sur la carte!
une idée s'il vous plait
#5 Mon 01 May 2017 11:22
lamia.hamou
s'il vous plait qlqu'un pourra m'aider
#6 Sun 14 May 2017 13:03
lamia.hamou
salut,
j'ai avancé sur mon projet j'ai réussi a affiché ma carte avec mes points. mais je rencontre un problème quand je zoom la carte 4 fois les points disparaissent , une idée svp?
