#1 Thu 18 January 2018 18:06
agone
QGIS 2.18.15/Python: modules ?
Depuis de longs mois je rencontre des problèmes avec les modules python et l'intégration avec QGIS.
Je suis sous QGIS 2.18.15 et osX 10.12.6
Les dernières mises à jour n'ont pas réglé les problèmes et même aggraver les choses.
L'utilisation de modules est impossible, certaines commandes ne fonctionne pas et Qspatialite est inutilisable. C'est donc assez embêtant.
Qu'en pensez vous?
Un exemple de code erreur:
2018-01-18T16:08:04    1    Traceback (most recent call last):
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 333, in startPlugin
                plugins[packageName] = package.classFactory(iface)
              File "/Users/arthur/.qgis2/python/plugins/OSMtools/__init__.py", line 34, in classFactory
                from .osm_tools import OSMtools
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 607, in _import
                mod = _builtin_import(name, globals, locals, fromlist, level)
              File "/Users/arthur/.qgis2/python/plugins/OSMtools/osm_tools.py", line 37, in <module>
                import osm_tools_access
              File "/Users/arthur/.qgis2/python/plugins/OSMtools/osm_tools_access.py", line 15, in <module>
                import requests
            ImportError: No module named requests
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/__init__.py", line 57, in classFactory
                from resource_sharing.plugin import Plugin
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/plugin.py", line 27, in <module>
                from gui.resource_sharing_dialog import ResourceSharingDialog
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/gui/resource_sharing_dialog.py", line 39, in <module>
                from resource_sharing.gui.manage_dialog import ManageRepositoryDialog
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/gui/manage_dialog.py", line 28, in <module>
                from resource_sharing.utilities import ui_path, qgis_version
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/utilities.py", line 9, in <module>
                import jinja2
            ImportError: No module named jinja2
2018-01-18T16:08:07    1    Traceback (most recent call last):
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/__init__.py", line 29, in classFactory
                from MetaSearch.plugin import MetaSearchPlugin
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/plugin.py", line 33, in <module>
                from MetaSearch.dialogs.maindialog import MetaSearchDialog
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/dialogs/maindialog.py", line 43, in <module>
                from owslib.csw import CatalogueServiceWeb
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/owslib/csw.py", line 27, in <module>
                from owslib.util import OrderedDict
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/owslib/util.py", line 35, in <module>
                import requests
#2 Fri 19 January 2018 06:59
gvellut
Lieu: Annecy
Re: QGIS 2.18.15/Python: modules ?
D'après les messages d'erreurs, il y a des modules Python non trouvés (requests et jinja2) dont certains plugins ont besoin (qgis_resource_sharing, Metasearch, OSMTools).
Tu peux les installer à la main avec pip :
pip install jinja2
pip install requests
#3 Fri 19 January 2018 09:46
agone
Je viens de réaliser l'installation des modules indiqués via le terminal mais j'obtiens toujours plusieurs erreurs
2018-01-19T09:45:27    1    warning:/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7/pyspatialite/dbapi2.py:81: DeprecationWarning: Converters and adapters are deprecated. Please use only supported SQLite types. Any type mapping should happen in layer above this module.
              register_adapter(datetime.date, adapt_date)
            traceback:  File "<string>", line 1, in <module>
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/gui/resource_sharing_dialog.py", line 40, in <module>
                from resource_sharing.repository_manager import RepositoryManager
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/repository_manager.py", line 12, in <module>
                from resource_sharing.collection_manager import CollectionManager
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/collection_manager.py", line 19, in <module>
                from resource_sharing.resource_handler import BaseResourceHandler
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/resource_handler/__init__.py", line 4, in <module>
                from processing_handler import ProcessingScriptHandler
              File "/Users/arthur/.qgis2/python/plugins/qgis_resource_sharing/resource_sharing/resource_handler/processing_handler.py", line 6, in <module>
                from processing.script.ScriptAlgorithm import ScriptAlgorithm
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 29, in <module>
                from processing.tools.general import *              # NOQA
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/general.py", line 31, in <module>
                from processing.core.Processing import Processing
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 42, in <module>
                from processing.script.ScriptUtils import ScriptUtils
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/script/ScriptUtils.py", line 30, in <module>
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/script/ScriptAlgorithm.py", line 33, in <module>
                from processing.core.GeoAlgorithm import GeoAlgorithm
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/GeoAlgorithm.py", line 41, in <module>
                from processing.core.parameters import ParameterRaster, ParameterVector, ParameterMultipleInput, ParameterTable, Parameter
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/parameters.py", line 32, in <module>
                from processing.tools.vector import resolveFieldIndex
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/vector.py", line 47, in <module>
                from processing.tools import dataobjects, spatialite, postgis
              File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/spatialite.py", line 29, in <module>
                from pyspatialite import dbapi2 as sqlite
              File "/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7/pyspatialite/dbapi2.py", line 86, in <module>
                register_adapters_and_converters()
2018-01-19T09:45:27    1    warning:/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7/pyspatialite/dbapi2.py:82: DeprecationWarning: Converters and adapters are deprecated. Please use only supported SQLite types. Any type mapping should happen in layer above this module.
              register_adapter(datetime.datetime, adapt_datetime)
2018-01-19T09:45:27    1    warning:/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7/pyspatialite/dbapi2.py:83: DeprecationWarning: Converters and adapters are deprecated. Please use only supported SQLite types. Any type mapping should happen in layer above this module.
              register_converter("date", convert_date)
2018-01-19T09:45:27    1    warning:/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7/pyspatialite/dbapi2.py:84: DeprecationWarning: Converters and adapters are deprecated. Please use only supported SQLite types. Any type mapping should happen in layer above this module.
              register_converter("timestamp", convert_timestamp)
