Pages: 1
- Sujet précédent - Tech Windows 10: ne surtout pas faire la MaJ 1803 du 10 Avril 2018 - Sujet suivant
#1 Thu 10 May 2018 06:27
- Patrice
- Moderateur
Objet: Tech Windows 10 : ne surtout pas faire la MaJ 1803 du 10 Avril 2018
Hello
J'adore les Windows Update et surtout ceux de Windows 10 !?
https://forums.autodesk.com/t5/infrawor … -p/7980206
---- InfraWorks locks up after Windows 10 Update ---- 2018/05/04 ----
https://knowledge.autodesk.com/support/ … 1515357298
NOTE: le module HydraFlow de ACAD CIVIL est aussi TOUCHE en attendant d'autres surprises !?
GeoBye, Pat
(Autodesk Expert Elite Team)
#2 Mon 14 May 2018 14:35
Re: Tech Windows 10: ne surtout pas faire la MaJ 1803 du 10 Avril 2018
Effectivement... Message de mercredi dernier d'un BIM Manager :
Well, we started having issues yesterday. First, one person found they could not plot to PDF, "Exiting Now" error. Then, one other person could not print to PDF because of crash. By the end of the day yesterday, about 6 people had this same issue. We found that you could EXPORTPDF without issue.
BTW, this is Civil 3D.
Jeudi : contact Autodesk - Microsoft
As for this issue, we have been in contact with Microsoft and are hoping to have some sort of resolution shortly.
Vendredi : un hotfix en cours
Just to give everyone an update on this, we have a Hotfix in the works. Stay tuned for any updates. Thanks again for your patience.
Quelqu'un évoque samedi un souci avec un driver nvidia :
Actually when i uninstalled nvidia driver, civil 3D would work just fine. Haven't tested Infraworks though, because windows installed an older version of nvidia driver automatically.
My guess is that this it is an nvidia driver problem, because if i open google earth with nvidia driver it shows a blank screen, if i open it using integrated graphic card (intel) it works just fine
#3 Mon 14 May 2018 14:57
- ChristopheV
- Lieu: Ajaccio
- Site web
@Patrice : sachant que acad utilise depuis toujours les API Windows c'est là que l'on s'aperçoit de la qualité de partenariat entre Microsoft et ses plus grands partenaires ... et comme souvent un problème de driver !
Bon il y a plus dramatique, certaines MAJ te font planter tous les serveurs ... c'est sympa le lundi matin quand tu arrives au bureau. Sachant que là on est pas sur du grand public comme W10 mais sur du Pro que tu payes un bras en plus !
Christophe
Pages: 1
