#1 Wed 23 May 2018 18:50
lucanuscervus
QGIS 3.0.2 (Girona): Probl OpenStreetMap downloader
j'essaye d'installer le plugin OpenStreetMap Downloder mais impossible.
Voici le message d'erreur qui s'affiche :
Impossible de charger l'extension 'OSMDownloader' provoque une erreur lors de l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'future'
  File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 336, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/Users/thierry/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/OSMDownloader/__init__.py", line 34, in classFactory
    from .osmDownloader import OSMDownloader
  File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/Users/thierry/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/OSMDownloader/osmDownloader.py", line 31, in
    from .osmDownloader_dialog import OSMDownloaderDialog
  File "/Users/thierry/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/OSMDownloader/osmDownloader_dialog.py", line 36, in
    from .osm_downloader import OSMRequest
  File "/Users/thierry/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/OSMDownloader/osm_downloader.py", line 25, in
    from future import standard_library
Version de Python : 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 03:03:55) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
Version de QGIS : 3.0.2-Girona Girona, exported
Chemin Python :
/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
Je ne connais pas python... alors si vous avez une solution... je suis preneur !!
#2 Thu 24 May 2018 10:56
amothe
Re: QGIS 3.0.2 (Girona): Probl OpenStreetMap downloader
Certains plugins ne sont pas encore compatibles avec la version 3 de QGIS. Peut-être que c'est le cas pour celui-ci. Dans ce cas là, il vaut mieux attendre qu'il soit réadapté ou sinon télécharger QGIS 2.18.
Bonne journée!
#3 Thu 24 May 2018 12:50
JonasL
Salut lucanuscervus,
Dans QGIS 3.0.2 (Girona), le fonctionnement de OpenStreetMap est différent de celui de la version 2.18.
Pour afficher les fonds OSM ou Google (Hybrid, Terrain et Satellite), voici la marche à suivre :
Dans la barre de menus, tu vas dans "Vue", puis dans "Panneaux" et enfin "Explorateur".
Ca t'affiche l'explorateur de fichiers dans une fenêtre épinglée à gauche.
Dans l'explorateur, tu descends dans les catégories jusqu'à trouver "XYZ Tiles".
En dépliant le dossier, tu y trouveras (normalement) les couches précitées, dont OpenStreetMap !
En double cliquant dessus, tu les ajoutes facilement à ton projet.
J'espère avoir pu t'aider (si c'est cela que tu cherchais).
Bonne journée,
Jonas
#4 Tue 29 May 2018 17:14
Sylther
Lieu: Mpl
Pour compléter la réponse de Jonas :
Légére différence dans la version Liinux, il faut aller dans "Préférences ", puis dans "Panneaux" et enfin "Explorateur".
Dans mon cas, la liste ' XYZ Tiles' était vide (et je viens de regarder dans une VM windows 7, il n'y a que l'entrée d'OpenStreetMap).
Pour ajouter des sources de données, on peut utiliser ce script à lancer dans la console Python (info trouvée ici et merci à Paul pour l'info initiale)
Bonne journée,
S.
"Un.e géographe ne se perd jamais, iel cherche une nouvelle route."
