#1 Thu 27 September 2018 14:40
Patrice
[ACAD MAP 2019] Update MAP 2019.0.1
Objet: [ACAD MAP 2019] Update MAP 2019.0.1
Hello
https://forums.autodesk.com/t5/autocad- … -p/8294827
GeoBye, Pat
---- This Update Applies to the Following Releases ----
    Autodesk AutoCAD Map 3D 2019
    Autodesk Infrastructure Administrator 2019
After applying this patch, the Product Version in the About box will be listed as 22.0.022.16 Autodesk AutoCAD Map 3D 2019.0.1 Update.
Primary Issues Resolved in This Update
The following issues have been resolved in AutoCAD Map 3D 2019.0.1 Update.
Industry Models
    Map 3D 2019 crashed when re-generating graphic with the setting 'Close current drawing'.
    Relative Orientation for Utility Point label did not work well for SQLite based industry models
FDO WFS
    Map 3D could not get data from some WFS URL.
Symbolization
    The input values like line thickness, rotation would change when users change the symbol.
MAPTOACAD
    The command MAPTOACAD took quite a long time for some specific data.
    After exported to DWG, the circle symbols got stretched or compressed depending on zoom level.
Others
    This update fixed some customer error reports.
Enhancements in This Update
Industry Models
    This update adds some Autodesk.Map.IM namespaces to the Form Controls: Formula Box and Script-Programmable-Control.
Paperspace
    This update adds a new command MAPNORTHARROWDEFAULTNORTH and allows user to specify whether the North Arrow points to the default north (i.e the angle of Pi/2) or the north defined in the current coordinate system. When this command sets to 0, the North Arrow would point to the north defined in the coordinat system. When this command sets to 1, the North Arrow would point to the default north.
Others
    This update extends the FDO MySQL support to MySQL 8.0
(Autodesk Expert Elite Team)
