#1 Mon 26 November 2018 12:04
atlass218
QGIS: actualisation automatique du contenu du widget tkinter 'Text'
bonjour;
je suis entrain de finaliser un petit projet. etj'ai rencontre un probleme d'actualisation du contenu du widget tkinter "Text" de mon application cree par python 3.6
le contenu du code est comme suit :
from tkinter import *
from tkinter.ttk import Notebook
import tkinter.ttk as ttk
import time
#window
root=Tk()
root.geometry('450x350')
root.title('test')
#variables
ent_releves1=StringVar()
ent_releves2=StringVar()
#Functions:
def archiver():
    archive_monitoring={"date" : time.strftime('%d/%m/%y', time.localtime()),
                  "releves_mesure1": ent_releves1.get(),
                  "releves_mesure2": ent_releves2.get(),                            }
    if (ent_releves1.get() !="" ) :
        mon_fichier1 = open("save/monitor1.txt", "r")
        text1 = mon_fichier1.read()
        mon_fichier1.close()
        textInsert1=str(archive_monitoring["date"])+"t" +str(archive_monitoring["releves_mesure1"])+"n"
        fileW1 = open("save/monitor1.txt", "w")
        fileW1.write(textInsert1 + text1)
        fileW1.close()
    if (ent_releves2.get() !="" ) :
        mon_fichier2 = open("save/monitor2.txt", "r")
        text2 = mon_fichier2.read()
        mon_fichier2.close()
        textInsert2=str(archive_monitoring["date"])+"t" +str(archive_monitoring["releves_mesure2"])+"n"
        fileW2 = open("save/monitor2.txt", "w")
        fileW2.write(textInsert2 + text2)
        fileW2.close()
def affichage_update ():
    with open('save/monitor1.txt',"r") as monitor1, open('save/monitor2.txt',"r") as monitor2:
        s= Scrollbar(releves)
        T= Text(releves,bg='powder blue',width=450,height=350,font=('arial',14,'bold'),pady=25)
        s.pack(side=RIGHT, fill=Y)
        T.pack(side=LEFT, fill=Y)
        s.config(command=T.yview)
        T.config(yscrollcommand=s.set)
        while True:
            line1 = monitor1.readline()
            if len(line1) == 0:
                break
            line1 = line1.strip().split()
            line2 = monitor2.readline()
            line2 = line2.strip().split()
            T.insert(END, f'{line1[0]:15}t {line1[1]:10}tt {line2[1]:10}n')
    T.update_idletasks()
    T.after(500,affichage_update)
container=ttk.Notebook(root,width=450,height=350)
monitoring=Frame(container,bg='powder blue')
container.add(monitoring,text='monitor data')
releves=Frame(container,bg='powder blue')
container.add(releves,text='releves')
lbf1 = LabelFrame(monitoring, text="Lecture Monitor 1",padx=10, pady=10)
lbf1.pack(side=LEFT,padx=10, pady=10,anchor=NE)
entry_lbf1= Entry(lbf1,textvariable=ent_releves1)
entry_lbf1.pack(pady=5)
lbf2 = LabelFrame(monitoring, text="Lecture Monitor 2",padx=10, pady=10)
lbf2.pack(side=LEFT,padx=10, pady=10,anchor=NW)
entry_lbf2= Entry(lbf2,textvariable=ent_releves2)
entry_lbf2.pack(pady=5)
bt_archiver=Button(monitoring,text='Archiver',command=archiver)
bt_archiver.place(x=40,y=120)
generalites_top=Frame(releves,bg='powder blue',width=450)
generalites_top.pack(side=TOP,fill=X)
generalites_bottom=Frame(releves,bg='powder blue')
generalites_bottom.pack(side=BOTTOM)
head_axe_loc35L = ['Date', 'Monitor 1', 'Monitor 2']
lb_date=Label(generalites_top,text=f'{head_axe_loc35L[0]:15}',bg='powder blue',font=('arial',12,'bold'))
lb_date.pack(side=LEFT,padx=5,anchor=NW)
lb_monitor1=Label(generalites_top,text=f'{head_axe_loc35L[1]:10}',bg='powder blue',font=('arial',12,'bold'))
lb_monitor1.pack( side=LEFT)
lb_monitor2=Label(generalites_top,text=f'{head_axe_loc35L[2]:10}',bg='powder blue',font=('arial',12,'bold'))
lb_monitor2.pack(padx=70, side=LEFT)
    while True:
        if len(line1) == 0:
            break
container.pack(expand=1, fill='both', padx=5, pady=5)
root.mainloop()
merci d'avance pour l'aide
#2 Wed 28 November 2018 12:33
JD
Re: QGIS: actualisation automatique du contenu du widget tkinter 'Text'
sans répondre à la question car le peu d'éléments fournis (à part le code) ne le permet pas,
pourquoi passer par tkinter alors que qgis est interfacé à pyqt, quelque chose m'échappe.
#3 Wed 28 November 2018 12:41
MathieuR
Lieu: aix-en-provence
Dans votre post, nous ne nous faîtes pas part de votre message d'erreur.
Aussi, sous QGIS, c'est (py)Qt qui est utilisé pour modéliser des interfaces.
On importe les modules pyQt comme ceci, sous QGIS 3 :
from PyQt5.QtCore import *
from PyQt5.QtGui import *
