Pages: 1
- Sujet précédent - QGIS Server: qgis_mapserv.fcgi.exe was not found on this server - Sujet suivant
#1 Tue 12 February 2019 17:13
- jlavaure
Bonjour chère communauté géomaticienne,
Nous avons tenté d'installer QGIS Server pour utiliser Lizmap en local sur un PC Windows 10 Pro.
On a suivi le tutoriel mis à disposition par Lizmap pour tout installer (https://docs.lizmap.com/current/fr/install/windows.html).
Mais comme beaucoup d'entre nous, on est bloqué au test de qgis_mapserv.fcgi.exe : Error 404 : Not Found : The requested URL /qgis/qgis_mapserv.fcgi.exe was not found on this server.
Après beaucoup de recherche on a bien compris que l'installation de QGIS server sur Windows est complexe, on n'a pas trouvé de solution à notre problème.
Pour info voici nos conf pour :
- httpd.conf
# This is the main Apache HTTP server configuration file. It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# NOTE: Where filenames are specified, you must use forward slashes
# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
# If a drive letter is omitted, the drive on which httpd.exe is located
# will be used by default. It is recommended that you always supply
# an explicit drive letter in absolute paths to avoid confusion.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path. If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used. If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
Define SRVROOT "c:/webserver/Apache24"
ServerRoot "${SRVROOT}"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:logs
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
LoadModule fcgid_module modules/mod_fcgid.so
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule actions_module modules/mod_actions.so
LoadModule alias_module modules/mod_alias.so
LoadModule allowmethods_module modules/mod_allowmethods.so
LoadModule asis_module modules/mod_asis.so
LoadModule auth_basic_module modules/mod_auth_basic.so
#LoadModule auth_digest_module modules/mod_auth_digest.so
#LoadModule auth_form_module modules/mod_auth_form.so
#LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_core_module modules/mod_authn_core.so
#LoadModule authn_dbd_module modules/mod_authn_dbd.so
#LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_file_module modules/mod_authn_file.so
#LoadModule authn_socache_module modules/mod_authn_socache.so
#LoadModule authnz_fcgi_module modules/mod_authnz_fcgi.so
#LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
LoadModule authz_core_module modules/mod_authz_core.so
#LoadModule authz_dbd_module modules/mod_authz_dbd.so
#LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_host_module modules/mod_authz_host.so
#LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule autoindex_module modules/mod_autoindex.so
#LoadModule brotli_module modules/mod_brotli.so
#LoadModule buffer_module modules/mod_buffer.so
#LoadModule cache_module modules/mod_cache.so
#LoadModule cache_disk_module modules/mod_cache_disk.so
#LoadModule cache_socache_module modules/mod_cache_socache.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule cgi_module modules/mod_cgi.so
#LoadModule charset_lite_module modules/mod_charset_lite.so
#LoadModule data_module modules/mod_data.so
#LoadModule dav_module modules/mod_dav.so
#LoadModule dav_fs_module modules/mod_dav_fs.so
#LoadModule dav_lock_module modules/mod_dav_lock.so
#LoadModule dbd_module modules/mod_dbd.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule dir_module modules/mod_dir.so
#LoadModule dumpio_module modules/mod_dumpio.so
LoadModule env_module modules/mod_env.so
LoadModule expires_module modules/mod_expires.so
LoadModule ext_filter_module modules/mod_ext_filter.so
#LoadModule file_cache_module modules/mod_file_cache.so
#LoadModule filter_module modules/mod_filter.so
#LoadModule http2_module modules/mod_http2.so
LoadModule headers_module modules/mod_headers.so
#LoadModule heartbeat_module modules/mod_heartbeat.so
#LoadModule heartmonitor_module modules/mod_heartmonitor.so
LoadModule ident_module modules/mod_ident.so
#LoadModule imagemap_module modules/mod_imagemap.so
LoadModule include_module modules/mod_include.so
#LoadModule info_module modules/mod_info.so
LoadModule isapi_module modules/mod_isapi.so
#LoadModule lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
#LoadModule lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
#LoadModule ldap_module modules/mod_ldap.so
#LoadModule logio_module modules/mod_logio.so
LoadModule log_config_module modules/mod_log_config.so
#LoadModule log_debug_module modules/mod_log_debug.so
#LoadModule log_forensic_module modules/mod_log_forensic.so
#LoadModule lua_module modules/mod_lua.so
#LoadModule macro_module modules/mod_macro.so
#LoadModule md_module modules/mod_md.so
LoadModule mime_module modules/mod_mime.so
#LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule negotiation_module modules/mod_negotiation.so
#LoadModule proxy_module modules/mod_proxy.so
#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
#LoadModule proxy_connect_module modules/mod_proxy_connect.so
#LoadModule proxy_express_module modules/mod_proxy_express.so
#LoadModule proxy_fcgi_module modules/mod_proxy_fcgi.so
#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
#LoadModule proxy_hcheck_module modules/mod_proxy_hcheck.so
#LoadModule proxy_html_module modules/mod_proxy_html.so
#LoadModule proxy_http_module modules/mod_proxy_http.so
#LoadModule proxy_http2_module modules/mod_proxy_http2.so
#LoadModule proxy_scgi_module modules/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module modules/mod_proxy_uwsgi.so
#LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
#LoadModule ratelimit_module modules/mod_ratelimit.so
#LoadModule reflector_module modules/mod_reflector.so
#LoadModule remoteip_module modules/mod_remoteip.so
#LoadModule request_module modules/mod_request.so
#LoadModule reqtimeout_module modules/mod_reqtimeout.so
LoadModule rewrite_module modules/mod_rewrite.so
#LoadModule sed_module modules/mod_sed.so
#LoadModule session_module modules/mod_session.so
#LoadModule session_cookie_module modules/mod_session_cookie.so
#LoadModule session_crypto_module modules/mod_session_crypto.so
#LoadModule session_dbd_module modules/mod_session_dbd.so
LoadModule setenvif_module modules/mod_setenvif.so
#LoadModule slotmem_plain_module modules/mod_slotmem_plain.so
#LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
#LoadModule socache_dbm_module modules/mod_socache_dbm.so
#LoadModule socache_memcache_module modules/mod_socache_memcache.so
#LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
#LoadModule speling_module modules/mod_speling.so
LoadModule ssl_module modules/mod_ssl.so
#LoadModule status_module modules/mod_status.so
#LoadModule substitute_module modules/mod_substitute.so
#LoadModule unique_id_module modules/mod_unique_id.so
#LoadModule userdir_module modules/mod_userdir.so
#LoadModule usertrack_module modules/mod_usertrack.so
#LoadModule version_module modules/mod_version.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule watchdog_module modules/mod_watchdog.so
#LoadModule xml2enc_module modules/mod_xml2enc.so
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User daemon
Group daemon
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed. This address appears on some server-generated pages, such
# as error documents. e.g. admin@your-domain.com
ServerAdmin admin@example.com
# ServerName localhost gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName localhost www.example.com:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
AllowOverride none
# Require all denied
Require all granted
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "${SRVROOT}/htdocs"
<Directory "${SRVROOT}/htdocs">
# Possible values for the Options directive are "None", "All",
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
# The Options directive is both complicated and important. Please see
# http://httpd.apache.org/docs/2.4/mod/core.html#options
# for more information.
Options Indexes FollowSymLinks
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# AllowOverride FileInfo AuthConfig Limit
AllowOverride None
# Controls who can get stuff from this server.
Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule fcgid_module>
AddHandler fcgid-script .fcgi .exe
</IfModule>
<IfModule dir_module>
DirectoryIndex index.html index.php
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "logs/error.log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
<IfModule logio_module>
# You need to enable mod_logio.c to use %I and %O
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
</IfModule>
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here. Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
CustomLog "logs/access.log" common
# If you prefer a logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
#CustomLog "logs/access.log" combined
</IfModule>
<IfModule alias_module>
# Redirect: Allows you to tell clients about documents that used to
# exist in your server's namespace, but do not anymore. The client
# will make a new request for the document at its new location.
# Example:
# Redirect permanent /foo http://www.example.com/bar
# Alias: Maps web paths into filesystem paths and is used to
# access content that does not live under the DocumentRoot.
# Example:
# Alias /webpath /full/filesystem/path
# If you include a trailing / on /webpath then the server will
# require it to be present in the URL. You will also likely
# need to provide a <Directory> section to allow access to
# the filesystem path.
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the target directory are treated as applications and
# run by the server when requested rather than as documents sent to the
# client. The same rules about trailing "/" apply to ScriptAlias
# directives as to Alias.
ScriptAlias /cgi-bin/ "${SRVROOT}/cgi-bin/"
</IfModule>
<IfModule cgid_module>
# ScriptSock: On threaded servers, designate the path to the UNIX
# socket used to communicate with the CGI daemon of mod_cgid.
#Scriptsock cgisock
</IfModule>
# "${SRVROOT}/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "${SRVROOT}/cgi-bin">
AllowOverride None
Options None
Require all granted
</Directory>
<IfModule headers_module>
# Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
# backend servers which have lingering "httpoxy" defects.
# 'Proxy' request header is undefined by the IETF, not listed by IANA
RequestHeader unset Proxy early
</IfModule>
<IfModule mime_module>
# TypesConfig points to the file containing the list of mappings from
# filename extension to MIME-type.
TypesConfig conf/mime.types
# AddType allows you to add to or override the MIME configuration
# file specified in TypesConfig for specific file types.
#AddType application/x-gzip .tgz
# AddEncoding allows you to have certain browsers uncompress
# information on the fly. Note: Not all browsers support this.
#AddEncoding x-compress .Z
#AddEncoding x-gzip .gz .tgz
# If the AddEncoding directives above are commented-out, then you
# probably should define those extensions to indicate media types:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
# AddHandler allows you to map certain file extensions to "handlers":
# actions unrelated to filetype. These can be either built into the server
# or added with the Action directive (see below)
# To use CGI scripts outside of ScriptAliased directories:
# (You will also need to add "ExecCGI" to the "Options" directive.)
#AddHandler cgi-script .cgi
# For type maps (negotiated resources):
#AddHandler type-map var
# Filters allow you to process content before it is sent to the client.
# To parse .shtml files for server-side includes (SSI):
# (You will also need to add "Includes" to the "Options" directive.)
#AddType text/html .shtml
#AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type. The MIMEMagicFile
# directive tells the module where the hint definitions are located.
#MIMEMagicFile conf/magic
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files. This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile on
# Supplemental configuration
# The configuration files in the conf/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
#Include conf/extra/httpd-mpm.conf
# Multi-language error messages
#Include conf/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
#Include conf/extra/httpd-autoindex.conf
# Language settings
#Include conf/extra/httpd-languages.conf
# User home directories
#Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include conf/extra/httpd-info.conf
# Virtual hosts
Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include conf/extra/httpd-dav.conf
# Various default settings
#Include conf/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include conf/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include conf/extra/httpd-ssl.conf
# Note: The following must must be present to support
# starting without SSL on platforms with no /dev/random equivalent
# but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
<IfModule mod_deflate.c>
SetOutputFilter DEFLATE
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\\.0[678] no-gzip
BrowserMatch \\bMSIE !no-gzip !gzip-only-text/html
SetEnvIfNoCase Request_URI \\.(?:gif|jpe?g|png|rar|zip)$ no-gzip dont-vary
Header append Vary User-Agent env=!dont-vary
</IfModule>- httpd-vhosts.conf
# Virtual Hosts
# Required modules: mod_log_config
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/2.4/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ServerName or ServerAlias in any <VirtualHost> block.
#<VirtualHost *:80>
# ServerAdmin webmaster@dummy-host.example.com
# DocumentRoot "${SRVROOT}/docs/dummy-host.example.com"
# ServerName dummy-host.example.com
# ServerAlias www.dummy-host.example.com
# ErrorLog "logs/dummy-host.example.com-error.log"
# CustomLog "logs/dummy-host.example.com-access.log" common
#</VirtualHost>
#<VirtualHost *:80>
# ServerAdmin webmaster@dummy-host2.example.com
# DocumentRoot "${SRVROOT}/docs/dummy-host2.example.com"
# ServerName dummy-host2.example.com
# ErrorLog "logs/dummy-host2.example.com-error.log"
# CustomLog "logs/dummy-host2.example.com-access.log" common
#</VirtualHost>
<VirtualHost *:80>
Include conf/extra/php-5.6.40.conf
DocumentRoot "C:/webserver/lizmap/"
<Directory "C:/webserver/lizmap">
Options -Indexes +FollowSymLinks +ExecCGI
AllowOverride All
Require all granted
</Directory>
CustomLog "logs/lizmap-access.log" common
ErrorLog "logs/lizmap-error.log"
</VirtualHost>
#Ajout des virtualhost
<VirtualHost *:80>
# Lizmap Production
DocumentRoot "C:/webserver/lizmap/prod/"
<Directory "C:/webserver/lizmap/prod">
AllowOverride All
Require all granted
</Directory>
# LizMap Pré-production
Alias /preprod/ "C:/webserver/lizmap/preprod/"
<Directory "C:/webserver/lizmap/preprod">
AllowOverride All
Require all granted
</Directory>
Alias /qgis/ "C:/OSGeo4W64/apps/qgis/bin/"
<Directory "C:/OSGeo4W64/apps/qgis/bin/">
SetHandler fcgid-script
Options +ExecCGI
AllowOverride All
Require all granted
</Directory>
</VirtualHost>- php-5.6.40.php
#FcgidInitialEnv PHPRC "C:\\webserver\\php-5.6.40"
<FilesMatch \\.php$>
AddHandler fcgid-script .php
FcgidWrapper "C:/webserver/php-5.6.40/php-cgi.exe" .php
</FilesMatch>
FcgidInitialEnv PATH "C:\OSGeo4W64\bin;C:\OSGeo4W64\apps\qgis\bin;C:\OSGeo4W64\apps\grass\grass-7.6.0\lib;C:\OSGeo4W64\apps\grass\grass-7.6.0\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\wbem"
FcgidInitialEnv QT_PLUGIN_PATH "C:\OSGeo4W64\apps\qgis\qtplugins;C:\OSGeo4W64\apps\Qt5\plugins"
FcgidInitialEnv PYTHONHOME "C:\OSGeo4W64\apps\Python27"
FcgidInitialEnv PYTHONPATH "C:\OSGeo4W64\apps\qgis\.\python;C:\OSGeo4W64\apps\qgis\.\python\plugins;C:\OSGeo4W64\apps\Python27\DLLs;C:\OSGeo4W64\apps\Python27\Lib;C:\OSGeo4W64\bin;C:\OSGeo4W64\apps\Python27;C:\OSGeo4W64\apps\Python27\Lib\site-packages"
FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
FcgidInitialEnv QGIS_SERVER_LOG_FILE "C:\\webserver\\Apache24\\logs\\qgis_server.log"
FcgidIOTimeout 120
FcgidInitialEnv LC_ALL "en_US.UTF-8"
FcgidInitialEnv PYTHONIOENCODING UTF-8
FcgidInitialEnv LANG "en_US.UTF-8"
FcgidInitialEnv QGIS_DEBUG 1
FcgidInitialEnv QGIS_SERVER_LOG_FILE "C:\\webserver\Apache24\logs\\qgis_server.log"
FcgidInitialEnv QGIS_PLUGINPATH "C:\OSGeo4W64\apps\qgis\python\plugins"
SetEnvIf Request_URI ^/qgis QGIS_PREFIX_PATH "C:\OSGeo4W64\apps\qgis"
SetEnvIf Request_URI ^/qgis TEMP "C:\Windows\Temp"
SetEnvIf Request_URI ^/qgis GDAL_DATA "C:\OSGeo4W64\share\gdal"
SetEnvIf Request_URI ^/qgis GDAL_DRIVER_PATH "C:\OSGeo4W64\bin"
SetEnvIf Request_URI ^/qgis PDAL_DRIVER_PATH "C:\OSGeo4W64\bin"
SetEnvIf Request_URI ^/qgis GDAL_SKIP "JP2ECW"
SetEnvIf Request_URI ^/qgis PROJ_LIB "C:\OSGeo4W64\share\proj"On comprend vraiment pas où ça bug, nous avons bien vérifié que tout est en 64bits, une histoire de libfcgi.dll, tout est ok niveau autorisation, on a bien vérifié l'installation de QGIS et tout semble normal, il n'y a pas de fichier manquant ....
Avez-vous des idées à nous soumettre ?
Merci d'avance pour votre retour, J.
#2 Wed 20 February 2019 15:12
- jlavaure
Re: QGIS Server: qgis_mapserv.fcgi.exe was not found on this server
Bonjour à tout le monde,
Je me permet de remonter le sujet, nous n'avons pas encore trouvé de solution.
Qu'en pensez-vous ?
J.
#3 Wed 20 February 2019 16:58
- Blaise Picinbono
- Site web
Bonjour;
Pouvez-vous vérifier que vous avez bien le fichier qgis_mapserv.fcgi.exe dans le répertoire cgi-bin du serveur apache ?
#4 Wed 20 February 2019 17:11
- jlavaure
Merci pour votre réponse.
Il n'y était pas, mais je l'ai rajouté et j'ai testé, mais toujours la même erreur : "The requested URL /qgis/qgis_mapserv.fcgi.exe was not found on this server."
#5 Wed 20 February 2019 17:28
- Blaise Picinbono
- Site web
Je penche pour une mauvaise configuration d'apache.
Regardez ce tuto:
https://www.sigterritoires.fr/index.php … indows-10/
notamment la partie concernant la configuration d'apache, et essayez d'adapter en fonction de votre arborescence.
#6 Fri 22 February 2019 09:13
- jlavaure
J'ai essayé avec la tuto de sigterritoires, mais même en modifiant certaines lignes qui n'étaient pas mentionnées sur le site de Lizmap (ScriptAlias ou Directory), ça ne fonctionne pas.
Cette fois ci c'est une autre erreur : "500 : Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at admin@example.com to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log."
Je pense que la meilleure solution sera de passer sur un PC Linux.
D'ailleurs savez-vous si on peut installer Qgis Serveur, Apache, PostgreSQL sur Ubuntu Mate ?
J.
#7 Fri 22 February 2019 12:03
- dominique.lys
- Site web
L’environnement de bureau de votre machine Linux (Mate, KDE, Gnome, Cinnamon...) a peu d'importance ici. Pour vos tests choisissez une distribution qui colle à ce que vous aurez sur votre serveur. Vous pouvez prendre une distribution basée sur Debian type Ubuntu ou Mint c'est ce que l'on rencontre le plus souvent, cela vous garantira des paquets qgis à jour et une ressource documentaire plus abondante.
Par ailleurs dans votre fichier de conf Apache je vois deux vhost qui pointent sur localhost avec la même racine, à mon avis vous pouvez supprimer le premier.
Pour votre erreur, il faut consulter les logs d'Apache pour voir quelle requête a été passé et pourquoi ça a planté.
#8 Fri 22 February 2019 12:16
- jlavaure
Merci dominique.lys pour cette réponse.
Enfaîte l'idée était d'utiliser un Raspberry Pi pour essayer d'installer Lizmap sur un environnement plus propice que Windows. N'étant pas un grand informaticien, je voulais éviter Raspbian pour installer tout le package nécessaire. Depuis peu Ubuntu Mate s'installe sur un Raspberry Pi.
A votre avis je peux donc tester sur Ubuntu Mate ?
Pour les logs, voici ce que ça donne :
- lizmap-error :
End of script output before headers: qgis_mapserv.fcgi.exe
- error :
[Fri Feb 22 09:05:09.435116 2019] [ssl:warn] [pid 4200:tid 628] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache] [Fri Feb 22 09:05:09.435116 2019] [mpm_winnt:notice] [pid 4200:tid 628] AH00455: Apache/2.4.38 (Win64) mod_fcgid/2.3.9 OpenSSL/1.0.2q configured -- resuming normal operations [Fri Feb 22 09:05:09.436114 2019] [mpm_winnt:notice] [pid 4200:tid 628] AH00456: Apache Lounge VC11 Server built: Jan 21 2019 13:25:29 [Fri Feb 22 09:05:09.436114 2019] [core:notice] [pid 4200:tid 628] AH00094: Command line: 'C:\\webserver\\Apache24\\bin\\httpd.exe -d C:/webserver/Apache24' [Fri Feb 22 09:05:09.440166 2019] [mpm_winnt:notice] [pid 4200:tid 628] AH00418: Parent: Created child process 13612 AH00558: httpd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::dff:9e5b:32d7:e7fc. Set the 'ServerName' directive globally to suppress this message AH00558: httpd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::dff:9e5b:32d7:e7fc. Set the 'ServerName' directive globally to suppress this message [Fri Feb 22 09:05:09.903895 2019] [ssl:warn] [pid 13612:tid 496] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache] [Fri Feb 22 09:05:10.018614 2019] [mpm_winnt:notice] [pid 13612:tid 496] AH00354: Child: Starting 64 worker threads. [Fri Feb 22 09:05:11.019611 2019] [mpm_winnt:notice] [pid 12960:tid 552] AH00364: Child: All worker threads have exited.
Mais je comprend pas vraiment l'origine du problème.
J.
#9 Fri 22 February 2019 12:27
- dominique.lys
- Site web
oui sans problème, c'est une variante d'Ubuntu avec un bureau Mate
Pages: 1
