#1 Fri 07 June 2019 06:02
- Abdoulayi111
QGIS 2.18.25: Impossible de charger PyQt ?
Impossible de charger PyQt.
Le support Python va être désactivé.
File "", line 1, in
RuntimeError: the sip module implements API v10.0 but the PyQt4.QtCore module requires API v11.2
Version de QGIS :
2.18.25 'Las Palmas', cbd7adecf2
Chemin vers Python :
['C:/PROGRA~1/QGIS2~1.18/apps/qgis-ltr/./python', u'C:/Users/Abdoulayi.SOUMARE/.qgis2/python', u'C:/Users/Abdoulayi.SOUMARE/.qgis2/python/plugins', 'C:/PROGRA~1/QGIS2~1.18/apps/qgis-ltr/./python/plugins', 'C:\PROGRA~1\QGIS2~1.18\bin\python27.zip', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\DLLs', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\plat-win', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\lib-tk', 'C:\PROGRA~1\QGIS2~1.18\bin', 'C:\Users\Abdoulayi.SOUMARE\AppData\Roaming\Python\Python27\site-packages', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\jinja2-2.7.2-py2.7.egg', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\markupsafe-0.23-py2.7-win-amd64.egg', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\win32', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\win32\lib', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\Pythonwin', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\Shapely-1.2.18-py2.7-win-amd64.egg', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\wx-2.8-msw-unicode', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\xlrd-0.9.2-py2.7.egg', 'C:\PROGRA~1\QGIS2~1.18\apps\Python27\lib\site-packages\xlwt-0.7.5-py2.7.egg']
#2 Fri 07 June 2019 07:15
- Patrice
- Moderateur
Re: QGIS 2.18.25: Impossible de charger PyQt ?
Comment allez vous ?
GeoBye, Pat
(Autodesk Expert Elite Team)
#3 Fri 07 June 2019 09:28
- Abdoulayi111
Désolé mon message était parti sans que je ne puisse ajouter des commentaires supplémentaires.
Actuellement, je n'arrive plus à utiliser Qgis convenablement. A chaque démarrage de Qgis, le message d'erreur, ci-dessous, apparait.
Ainsi, la plupart des fonctionnalités de Qgis deviennent indisponibles, inutilisables.
J'ai QGis 2.18 et aussi 2.14. Je ne souhaite pas passer à Qgis 3, pour rester en conformité avec mes collègues qui utilise tous, Qgis 2.14.18.
Je désinstalle entièrement Qgis et Python et et ses modules, mais mes problèmes persistent encore.
Merci de votre aide.
#4 Fri 07 June 2019 09:54
- Abdoulayi111
Enfin; mon problème a été résolu.
Le module sip faisait référence au répertoire C:\Users\~\AppData\Roaming\Python que je n'avais pas supprimé.
Après la suppression de ce répertoire, tout fonctionne.
En espérant que cette solution sera utile dans l'avenir à d'autres personnes.
Bonne journée
