#1 Mon 26 April 2021 17:20
- cachamo
QGIS: probl avec le plugin Hotspot Analysis
Bonjour à tous, lorsque je charge le pluging Hotspot analysis j'ai ce message :
Impossible de charger l'extension 'HotspotAnalysis' provoque une erreur lors de l'appel à sa méthode classFactory()
ImportError: dlopen(/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/_imaging.cpython-38-darwin.so, 2): Library not loaded: /opt/X11/lib/libxcb.1.dylib Referenced from: /Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/_imaging.cpython-38-darwin.so Reason: image not found
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 335, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File "/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/HotspotAnalysis/__init__.py", line 34, in classFactory
from .hotspot_analysis import HotspotAnalysis
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 799, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/HotspotAnalysis/hotspot_analysis.py", line 38, in
import pysal
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pysal/__init__.py", line 3, in
from . import explore
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pysal/explore/__init__.py", line 4, in
import pointpats
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pointpats/__init__.py", line 4, in
from .pointpattern import PointPattern
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pointpats/pointpattern.py", line 12, in
from matplotlib import pyplot as plt
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/pyplot.py", line 36, in
import matplotlib.colorbar
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/colorbar.py", line 44, in
import matplotlib.contour as contour
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/contour.py", line 17, in
import matplotlib.text as text
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/text.py", line 16, in
from .textpath import TextPath # Unused, but imported by others.
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/textpath.py", line 11, in
from matplotlib.mathtext import MathTextParser
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg/matplotlib/mathtext.py", line 27, in
from PIL import Image
File "/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg/PIL/Image.py", line 94, in
from . import _imaging as core
Version de Python : 3.8.7 (default, Feb 10 2021, 09:04:08) [Clang 12.0.0 (clang-1200.0.32.29)]
Version de QGIS : 3.18.2-Zürich Zürich, 8f0e606e1e
Chemin Python :
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/LAStools
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/clusterpoints
/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/scipy-1.5.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Rtree-0.9.4-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/affine-2.3.0-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/GDAL-3.2.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/cftime-1.2.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/numba-0.50.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/statsmodels-0.11.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/Fiona-1.8.13.post1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/click_plugins-1.1.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/geopandas-0.8.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/opencv_contrib_python-4.3.0.36-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/rasterio-1.1.5-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/netCDF4-1.5.4-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pyproj-2.6.0-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/numpy-1.20.1-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/lib-dynload
/Applications/QGIS.app/Contents/MacOS/lib/python38.zip
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/patsy-0.5.1-py3.8.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/pandas-1.1.0-py3.8-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.8/site-packages/snuggs-1.4.7-py3.8.egg
/Users/pierreguillemot/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/mmqgis/forms
Avez-vous des solutions ou des suggestions ?
#2 Mon 26 April 2021 17:44
- Pascal Boulerie
- Lieu: France
- Site web
Re: QGIS: probl avec le plugin Hotspot Analysis
Peut-être réinstaller Python ?
(je ne sais pas exactement quoi vous conseiller - je ne trouve pas de détails à ce propos dans la doc QGis)
#3 Mon 26 April 2021 17:55
- Pascal Boulerie
- Lieu: France
- Site web
QGis a son propre Python embarqué à son bord, si je comprends bien ?
https://georezo.net/forum/viewtopic.php … 58#p266558
et sur un MacOS il faut s'assurer manuellement que c'est le bon Python au bon endroit qui appelle le bon script Python ??
try out to set QGIS paths to the package folder manually to be sure that the wanted packages are within the same python env used by QGIS (see: https://gis.stackexchange.com/questions … s-3-on-mac )
