#1 Wed 15 March 2023 16:07
- image95
QGIS Server: Installation sur Debian ?
Je souhaite installer Qgis server sur mon serveur Linux Debian. Pour le moment, ca ne fonctionne pas.
Pour info, j'ai déjà un serveur apache fonctionnel et utilisé pour geoserver et geonetwork.
J'ai suivi la doc/tuto Qgis server :
https://docs.qgis.org/3.22/fr/docs/trai … stall.html
https://docs.qgis.org/3.22/fr/docs/serv … ed-systems
Pour info,quand je test l'executable, voici le message. Il m'a récupéré qgis 3.1 (et non la 3.22). Et le message du status est 200 et non 400.
root@XXXXXXXXXX:/usr/lib/cgi-bin# /usr/lib/cgi-bin/qgis_mapserv.fcgi --version Application path not initialized Application path not initialized Application path not initialized QStandardPaths: runtime directory '/run/user/1001' is not owned by UID 0, but a directory permissions 0700 owned by UID 1001 GID 1001 Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment variable. Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment variable. Initializing server modules from "/usr/lib/qgis/server" "Checking /usr/lib/qgis/server for native services modules" "Loading native module /usr/lib/qgis/server/libdummy.so" "Loading native module /usr/lib/qgis/server/libwcs.so" "Loading native module /usr/lib/qgis/server/libwfs.so" "Loading native module /usr/lib/qgis/server/libwfs3.so" "Loading native module /usr/lib/qgis/server/libwms.so" "Loading native module /usr/lib/qgis/server/libwmts.so" <string>:1: DeprecationWarning: setapi() is deprecated Logged warning: Loading a file that was saved with an older version of qgis (saved in 0.0.0, loaded in 3.10.14-A Coruña). Problems may occur. Content-Length: 206 Content-Type: text/xml; charset=utf-8 [b]Server: Qgis FCGI server - QGis version 3.10.14-A Coruña Status: 200 <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" version="1.3.0"> <ServiceException code="Service configuration error">Service unknown or unsupported</ServiceException> </ServiceExceptionReport>
[/b]
J'ai bien installé mod_fcgid.
Vu que j'ai dejà Apache d'installer. Que dois je faire ? J'aimerais pouvoir faire cohabiter geoserver, geonetwork et qgis server. J'aimerais pouvoir ajouter pour qgis server un https://SERVEUR_NAME/qgis_server.
J'ai quand meme créé un fichier qgis.demo.conf sous etc/apache2/sites-available. J'ai simplement remplacé ServerName par l'IP de mon server. Je n'ai rien modifié d'autre. Vu mon besoin et environnement de travail, devrais je modifier la premiere ligne du fichier ? :
<VirtualHost *:80>
J'ai créé les répertoires qui stockeront les logs du serveur QGIS et ceux de la base de données d’authentification :
mkdir -p /var/log/qgis/ chown www-data:www-data /var/log/qgis mkdir -p /home/qgis/qgisserverdb chown www-data:www-data /home/qgis/qgisserverdb
J'ai activé fgcid mode et l'hote virtuel. Mais après avoir un restart d'apache, je n'ai rien.
root@XXXXXXXXXXXXXXXX:/etc# curl http://XXXXXXX.fr/cgi-bin/qgis_mapserv.fcgi <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>301 Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The document has moved <a href="https://XXXXXXXXXXXcgi-bin/qgis_mapserv.fcgi">here</a>.</p> <hr> <address>Apache/2.4.54 (Debian) Server at XXXXXXX.fr Port 80</address> </body></html>
Via le navigateur, lorsque je tente XXXXX.fr/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
Il est indiqué Site inaccessible.
Si une personne pouvait m'aider? Merci.
Dernière modification par image95 (Wed 15 March 2023 16:13)
#2 Fri 17 March 2023 11:32
- image95
Re: QGIS Server: Installation sur Debian ?
Apres avoir remplacé au sein du fichier qgis.demo.conf la valeur de l'IP par le nom du serveur. Voici ce les messages que j'obtiens :
root@XXXXX:/etc/apache2/sites-available# curl XXXX.fr/cgi-bin/qgis_mapserv.fcgi
<ServerException>Project file error</ServerException>
root@XXXXXX:/etc/apache2/sites-available# a2ensite XXXXXXXX
ERROR: Site XXXXXX does not exist!
Si une personne pense avoir une piste ?
#3 Tue 21 March 2023 18:42
- tumasgiu
- Lieu: Ajaccio
les virtual host permettent à apache de servir different contenus selon le nom dns avec lequel celui-ci est contacté.
Votre serveur peut avoir plusieurs enregistrements dns qui le referencere, par exemple avec des sous-domaines :
* geonetwork.monserveur.local
* qserv.monserveur.local
* geoserver.monserveur.local
Ca donnerait :
Listen 80
<VirtualHost *:80>
DocumentRoot "/www/geonetwork/"
ServerName geonetwork.monserveur.local
# Autres directives ici
</VirtualHost>
<VirtualHost *:80>
DocumentRoot "/www/qgisserver"
ServerName qserv.monserveur.local
</VirtualHost>
<VirtualHost *:80>
DocumentRoot "/www/geonetwork"
# configuration pour geonetwork
</VirtualHost>https://httpd.apache.org/docs/2.4/vhosts/examples.html
#4 Thu 23 March 2023 14:52
- image95
J'ai désinstallé tout ce que j'avais installé (depuis le depot Debian) jusqu'à maintenant qui proposait uniquement la version qgis server 3.10.
J'ai ajouté le depot qgis officiel qui a permis de recuperer/d'installer la version de qgis server 3.30. La toute dernière. Par contre, le projet qgis que j'essaie de servir est de version 3.28 et non 3.30.
Voici le message d'erreur que j'obtiens désormais :
root@SERVEUR_NAME:/home/qgis/projects# curl http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION= 1.3.0&REQUEST=GetCapabilities [1] 395943 [2] 395944 root@SERVEUR_NAME:/home/qgis/projects# <?xml version="1.0" encoding="UTF-8"?> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" version="1.3.0"> <ServiceException code="OperationNotSupported">Please add or check the value of the REQUEST parameter</ServiceExcept ion> </ServiceExceptionReport> ^C [1]- Fini curl http://SERVEUR_NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS [2]+ Fini VERSION=1.3.0
Une personne saurait m'aider ? Merci.
Dernière modification par image95 (Thu 23 March 2023 14:53)
#5 Mon 27 March 2023 08:41
- image95
Probleme résolu. Il y avait une grosse typo dans la doc officielle :
https://lists.osgeo.org/pipermail/qgis- … 52763.html
Comment signaler cette erreur qui personnellement m'a fait tres mal ? ;-)
