Pages: 1
- Sujet précédent - QGIS/Plugin spectral-libraries: message d'erreur installation - Sujet suivant
#1 Tue 31 October 2023 18:21
- image95
Je travaille avec Qgis 3.32.2-Lima sur Ubuntu.
J'aimerais pouvoir utiliser ce plugin :
https://plugins.qgis.org/plugins/spectral_libraries/
Mais il semble obsolète ?
En tout cas, lorsque j'essaie de l'intaller via qgis, j'ai un message d'erreur (ci dessous).
Si ce plugin n'est plus fonctionnel, connaitriez vous des alternatives ?
Impossible de charger l'extension 'spectral_libraries' provoque une erreur lors de l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'mock'
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/__init__.py", line 14, in classFactory
from spectral_libraries.spectral_libraries_plugin import SpectralLibrariesPlugin
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/spectral_libraries_plugin.py", line 29, in
from spectral_libraries.interfaces.spectral_library_gui import SpectralLibraryWidget
File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/interfaces/spectral_library_gui.py", line 34, in
initResources()
File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/__init__.py", line 154, in initResources
from .testing import initResourceFile
File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/testing.py", line 40, in
import mock
ModuleNotFoundError: No module named 'mock'Hors ligne
Pages: 1
