#1 Mon 04 December 2023 04:59
Phildefer
QGIS LTR / Plugin H3: Probleme d'installation
J'essaye d'installer (sur un Mac) le plugin H3. Lors de l'installation j'ai le message suivant : H3 Toolkit plugin: H3 library not found. Je regarde dans l'aide qui conseille d'installer H3 dans python via pip.Ce que je fais dans la partie python de Qgis et non le Python installé sur mon Mac puisque a priori Qts embarque son propre Python.
Hélas j'ai le message d'erreur suivant :
Collecting H3
  Using cached h3-3.7.6.tar.gz (178 kB)
  Installing build dependencies ... error
  error: subprocess-exited-with-error
  × pip subprocess to install build dependencies did not run successfully.
  │ exit code: 1
  ╰─> [12 lines of output]
      Collecting scikit-build
        Using cached scikit_build-0.17.6-py3-none-any.whl.metadata (14 kB)
      Collecting cython
        Using cached Cython-3.0.6-cp312-cp312-macosx_10_9_x86_64.whl.metadata (3.2 kB)
      Collecting cmake
        WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))': /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata
        WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))': /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata
        WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))': /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata
        WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))': /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata
        WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))': /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata
      ERROR: Could not install packages due to an OSError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Max retries exceeded with url: /packages/44/a5/b1bfcb76e2309fa2fb63a2e71f9749ce304112086c8c3c9065ee6a7aa098/cmake-3.27.9-py2.py3-none-macosx_10_10_universal2.macosx_10_10_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)')))
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
Si quelqu'un a une idée... Merci.
#2 Tue 05 December 2023 16:51
Phildefer
Re: QGIS LTR / Plugin H3: Probleme d'installation
Apparemment il s'agissait d'un problème de VPN qui bloquait le téléchargement. Par contre ayant réussi a installé H3 toolkit dans Qgis et H3 dans Python j'ai toujours le message : H3 Toolkit plugin: H3 library not found.
Je ne comprends pas pourquoi.
Si quelqu'un pouvait m'eclairer ...
Merci.
#3 Fri 22 December 2023 16:48
Phildefer
Je me permets de remonter ce post car je ne trouve aucune solution.
A votre bon coeur :-)
#4 Fri 22 December 2023 17:25
Pascal Boulerie
Ouvrir un ticket sur le site de ce plugin ?
https://github.com/arongergely/qgis-h3- … gin/issues
#5 Fri 22 December 2023 18:00
Phildefer
Merci pour votre lien, c'est effectivement une option. Toutefois, si quelqu'un ayant un Mac avec Qgis avait expérimenté avec succès l'installation, cela pourrait aussi m'orienter vers une solution. Il n'y a peut etre pas de bug juste une mauvaise manip de ma part.
#6 Sat 23 December 2023 09:01
dave31
Le plugin fonctionne sur macOS High Sierra.
1- installer H3 via le Terminal
/Applications/QGIS-LTR.app/Contents/MacOS/bin/pip3 install H3
2- installer le plugin H3 Toolkit dans QGIS.
Le réinstaller s’il a été installé avant H3.
Dernière modification par dave31 (Sat 23 December 2023 09:02)
#7 Sat 23 December 2023 19:45
Phildefer
Merci Dave, c'est effectivement ce que j'ai fait. H3 est installé dans le bon répertoire mais pourtant aucun des plugins qui en ont besoin H3 density ou h3 toolkit ne semblent y avoir accès.
