#1 Tue 19 December 2023 09:57
- Mathieu_44
QGIS/Extension Cadastre: Probl Import
je viens vers vous car je n'arrive pas à importe un cadastre fichier EDIGEO sur mon projet QGIS.
A la fin de l'import une boite de dialogue s'affiche indiquant :
Une erreur est survenue lors de l'exécution du code Python :
CHAPITRE 1. UnboundLocalError: local variable 'sql' referenced before assignment
File "C:Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/pluginscadastrecadastre_import.py", line 1489, in importEdigeoVecToDatabase
c.executemany(query, [(item[0], item[1], item[2]) for item in l])
sqlite3.OperationalError: no such table: edigeo_rel
During handling of the above exception, another exception occurred:
File "C:Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/pluginscadastredialogsimport_dialog.py", line 327, in processImport
qi.importEdigeo()
File "C:Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/pluginscadastrecadastre_import.py", line 713, in importEdigeo
self.importAllEdigeoToDatabase()
File "C:Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/pluginscadastrecadastre_import.py", line 1336, in importAllEdigeoToDatabase
self.importEdigeoVecToDatabase(vec)
File "C:Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/pluginscadastrecadastre_import.py", line 1492, in importEdigeoVecToDatabase
self.qc.updateLog('Erreurs pendant la requête : %s' % sql)
Version de Python : 3.9.5 (tags/v3.9.5:0a7dcbd, May 3 2021, 17:27:52) [MSC v.1928 64 bit (AMD64)]
Version de QGIS : 3.28.13-Firenze Firenze, 3b4db4f561
Chemin Python :
• C:/PROGRA~1/QGIS32~1.13/apps/qgis-ltr/./python
• C:/Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python
• C:/Users/mpiedeleu/AppData/Roaming/QGIS/QGIS3profilesdefault/python/plugins
• C:/PROGRA~1/QGIS32~1.13/apps/qgis-ltr/./python/plugins
• C:PROGRA~1QGIS32~1.13appsgrassgrass83etcpython
• C:UsersmpiedeleuDocuments
• C:Program FilesQGIS 3.28.13binpython39.zip
• C:PROGRA~1QGIS32~1.13appsPython39DLLs
• C:PROGRA~1QGIS32~1.13appsPython39lib
• C:PROGRA~1QGIS32~1.13appsPython39libsite-packages
• C:PROGRA~1QGIS32~1.13appsPython39libsite-packageswin32
• C:PROGRA~1QGIS32~1.13appsPython39libsite-packageswin32lib
• C:PROGRA~1QGIS32~1.13appsPython39libsite-packagesPythonwin
R/A-Assainissement/OCE-A23-32 - BEAUVOIR SUR MER - Bassin tampon/Etudes/00-DONNEES-RECUES/04_Réseau SIG
Si quelqu'un à déjà eu ce problème je suis interessé pour connaitre la solution, Bonne journée.
#2 Tue 19 December 2023 10:22
- Pascal Boulerie
- Lieu: France
- Site web
Re: QGIS/Extension Cadastre: Probl Import
Peut-être qu'il y a déjà eu des cas assez similaires ?
https://georezo.net/forum/search.php
UnboundLocalError AND cadastre
> 04_Réseau SIG
Est-ce que le nom du chemin ou du fichier peut comporter un caractère accentué ?
