Pour sa 21ème année, l’association GeoRezo a toujours besoin de vous !
10€ = 1 mois de frais bancaires ; 15€ = 12 mois de nom de domaine ; 30€ = 1 semaine de location des serveurs …
Faire un don
Retrouver nos membres bienfaiteurs
#1 Thu 19 December 2024 09:03
Mojtaba.E
[STAGE] Analyse de l'empreinte carbone à l'aide d'un SIG
Adresse de l'expéditeur : meslahi@texte-a-enlever.estp.fr
Analysis of the carbon footprint in the building and construction sector using GIS
Description:
The carbon footprint is the sum of greenhouse gases, in particular carbon dioxide and methane, that result from our activities. The building and construction sector is the greatest source of greenhouse gases. This sector is responsible for 37% of global emissions. The materials produced and used, such as cement, steel, and aluminum, have a significant carbon footprint. The aim here is to create a GIS map to monitor the construction sector's carbon footprint in France. This will help us to prepare the basis for a greener, more sustainable environment, in line with our climate policy objectives.
Objectives of the internship:
This internship aims to use GIS to analyze the carbon footprint and the results of its reduction. The Geographic Information System allows the exploration of spatial patterns and relations of carbon emissions and their sources. This helps us to identify the areas and sectors with the greatest reduction potential. The first step in using GIS for carbon reduction is to measure and track historical and actual carbon emissions in the relevant area. GIS makes it possible to obtain and integrate data from different sources, such as satellite imagery, remote sensing, ground sensors, and surveys. It is also useful for identifying opportunities to reduce carbon emissions, and for developing and implementing carbon reduction plans.
Missions:
- Research into the carbon footprint of the construction sector
- Development of a GIS model for carbon footprint analysis and identification of carbon emission reduction opportunities
Profile
Level: Master 2 or last year of engineering school Specialty: Geomatics, Geoinformatics, Environmental Engineering, Civil Engineering, Urban Engineering
Required Skills: Computer programming, Geomatics (knowledge on Python, C++, BIM, GIS)
Analyse de l'empreinte carbone dans le secteur du bâtiment et de la construction à l'aide d'un SIG
Description :
L'empreinte carbone est la somme des gaz à effet de serre, en particulier le dioxyde de carbone et le méthane, qui résultent de toutes nos activités. Le secteur du bâtiment et de la construction représente la plus grande source de gaz à effet de serre. Ce secteur est à l'origine de 37 % des émissions mondiales. Les matériaux produits et utilisés, tels que le ciment, l'acier et l'aluminium, ont une empreinte carbone importante. L'objectif ici est de créer une carte SIG pour suivre l'empreinte carbone du secteur de la construction en France. Cela nous aidera à préparer les bases d'un environnement plus vert et plus durable, en accord avec les objectifs de la politique climatique.
Objectifs du stage :
Le stage vise à utiliser les SIG pour analyser l'empreinte carbone et les résultats de sa réduction. Le système d'information géographique permet d'explorer les modèles et les relations spatiales des émissions de carbone et de leurs sources. Il permet d'identifier les zones et les secteurs présentant le plus grand potentiel de réduction. La première étape de l'utilisation des SIG pour la réduction du carbone consiste à mesurer et à suivre les émissions de carbone effectives et historiques dans la zone concernée. Les SIG permettent d'obtenir et d'intégrer des données provenant de différentes sources, telles que l'imagerie satellite, la télédétection, les capteurs terrestres et les études. Il est également pratique pour identifier les possibilités de réduction des émissions de carbone et pour élaborer et mettre en œuvre des plans de réduction des émissions de carbone.
Missions :
- Effectuer des recherches sur l'empreinte carbone du secteur de la construction
- Mise en place d'un modèle SIG pour l'analyse de l'empreinte carbone et l'identification des opportunités de réduction des émissions de carbone
Profil
Niveau : Master 2 ou dernière année d'école d'ingénieur Spécialité : Géomatique, géoinformatique, génie environnemental, génie civil, génie urbain
Compétences requises :  Programmation informatique, Géomatique (Maîtrise de Python, C++, BIM, SIG)
Date limite de candidature : 01/02/2025
Prise de fonction : 15/02/2024
