#1 Wed 29 November 2006 12:44
fanjabe
Lieu: Moramanga
Arcmap et système d'horloge de l'ordinateur
Je ne sais pas ce qui est arrivé à mon Arcmap 9.1 mais depuis la semaine dernière la phrase suivante s'affiche dès que je veux le démarrer "The system clock has been set back to the past. This is not allowed"
Avant, il marchait très bien et maintenant il ne demarre que si je change l'année de mon ordi en 2007.
Si quelqu'un peut m'aider pour résoudre ce problème
Merci d'avance pour votre réponse.
Fanja
Technicien SIG,
DYNATEC Madagascar
#2 Wed 29 November 2006 21:44
Miniopterine
Re: Arcmap et système d'horloge de l'ordinateur
J'ai trouvé ca sur le support ESRI:
Error:  The System Clock has been set back to the past. This is not allowed!
  Article ID: 24575 Software:  *ArcGIS - ArcEditor* 8.1, 8.1.2, 8.2, 8.3,
9.0, 9.1 *ArcGIS - ArcInfo* 8.0.1, 8.0.2, 8.1, 8.1.2, 8.2, 8.3, 9.0,
9.1 *ArcGIS
- ArcView* 8.1, 8.1.2, 8.2, 8.3, 9.0, 9.1 *ArcInfo Workstation* 7.2.1, 8.0.1,
8.0.2, 8.1, 8.1.2, 8.2, 8.3, 9.0, 9.1 Platforms:  *Windows* NT 4.0,
2000, XP Error
Message Starting an ESRI software product may return the following error:
"The System Clock has been set back to the past. This is not allowed!"
Cause Any action that puts future-dated files on the license manager server
results in this error message. Setting the system clock to the past, setting
the clock ahead and then back to the present, or getting future-dated files
from another source are all examples of such an action. Having future-dated
files on a machine with ArcView and ArcEditor Single Use also causes the
same error.
Solution or Workaround Follow the steps below.
   1. Verify that the date and time on the system are correct. Also
   verify that AM or PM is set properly. -show
me-
     Select Start > Settings > Control Panel > Date/Time.
    [image: [O-Image] System Clock]
   2. Verify the time zone is correct. -show
me-
     *Windows NT and 2000:*
   1. Select Start > Settings > Control Panel > Date/Time.
   2. Select the Time Zone tab.
   *Windows XP:*
   1. Select Start > Control Panel > Date and Time.
     3. Reboot the computer and start ArcMap. If problem persists, move
   to Step 4.
   4. Verify that there are no hidden files and folders. -show
me-
     *Windows NT:*
   1. Right click the My Computer icon on the desktop and select Explore.
   2. Select View > Options.
   3. On the View tab verify that:
   · "Show all files" is selected.
   · "Hide files of these types" is unselected.
   · "Hide file extensions for known file types" is unselected.
   4. Click Apply and OK.
   *Windows 2000:*
   2. Select Tools > Folder Options.
   · "Show hidden files and folders" is selected.
   · "Hide file extensions for known file types" is unchecked.
   · "Hide protected operating system files (Recommended)" is unchecked.
   4. Click Yes when prompted.
   5. Click Apply and OK.
   *Windows XP:*
     5. Search the computer's hard drive for files with future file
   dates. -show me-
     *Windows NT:*
   1. Select Start > Find > Files or Folders.
   2. Select the Date Modified tab and choose Select between.
   3. Type in tomorrow's date and 12/31/2099.
   4. Click Find Now.
   *Windows 2000:*
   1. Select Start > Search > For Files or Folders.
   2. Select Search Options.
   3. Check the Date box and select Between.
   4. Type in tomorrow's date and 12/31/2098.
   5. Click Search Now.
   *Windows XP:*
   1. Select Start > Search.
   2. Choose All Files and Folders.
   3. Select Search Options.
   4. Check 'When was it modified?' and select Specify Dates.
   5. Type in tomorrow's date and 12/31/2098.
   6. Click Search Now.
     6.
    WARNING: The instructions below include making changes to essential
   parts of your operating system. It is recommended that you backup your
   operating system and files, including the registry, before proceeding.
   Consult with a qualified computer systems professional, if necessary.
   ESRI cannot guarantee results from incorrect modifications while
   following these instructions. Therefore, use caution and proceed at your own
   risk.
   Remove all files and folders whose time/date stamp is greater than 4
   hours ahead of the current system time and date. This may require moving
   them onto another workstation, reloading applications, or in the case of
   system files, it may be necessary to reinstall the operating system.
    Though alternatives may be available, ESRI Technical Support cannot
   provide or support the use of them. If there are further questions regarding
   the information in this article contact ESRI Technical Support, otherwise
   direct all other inquiries to an ESRI regional representative.
Dernière modification par Miniopterine (Wed 08 August 2007 22:59)
#3 Thu 30 November 2006 11:34
Forestis
Lieu: Aniane (Hérault)
Nous avons eu le même problème et il se trouve que la réponse du support
d'esri a été :
Utilisé l'utilitaire "Attribut changer" (google est ton ami) pour modifier la date de tous les fichiers qui ont une date supérieur a la date actuelle.
Si ça marche pas (et nous ça n'avais pas marcher) il faut ... (attention tenez vous bien)... FORMATER ! :-s et a la fin il a rajouter : "Bon courage"
Si si c'est ce qu'il m'ont dit...et c'est effectivement ce qu'il a
fallut je fasse (par chance j'avais un ghost de ma partition)
"Bon courage"(citation du support d'esri)
[Matthieu Pette]
[Matthieu Pette - Ad Terram] (@Ad_Terram sur le PiouPiou bleu)
~Géomaticien Indépendant~
#4 Fri 01 December 2006 06:04
Franck B
Lieu: PACA
Il faut tout de même être optimiste, j'ai eu le même problème de date dernièrement et l'outil "Attribute Changer" (pour le télécharger)m'a permis de résoudre le problème.
Dernière modification par Franck B (Fri 01 December 2006 06:05)
#5 Fri 01 December 2006 09:20
rantanplan
Lieu: Limoges
J'ai eu le même problème que j'ai résolu en remettant l'horloge à l'heure...
#6 Thu 14 December 2006 09:50
Vincent_Dumortier
Le probleme vient du fait que pour une raison qui vous est propre vous avez modifiez la date de votre PC. Or, parallèlement à l'instalation d'Arcview (en tout cas c'était encore comme ca avec la version 8.3) Esri installe un logiciel qui s'appelle "sentinel" (c'est le petit message à l'installation : "Arcview a detecté des composantes non a jour de Windows") qui a pour fonction de controler les modification e date du PC.
J'ai eu le problème... le plus "simple": désinstaller Arcview et "Sentinel System driver" via: menu démarrer - panneau configuration - ajout/suppresion de programme (Attention de bien conserver vos fichier de registration). Ensuite réinstaller AV et prendre soin de ne plus modifier la date de votre PC (je pense que la tolérance de sentinel est de 2 jours maximum)
Bien à vous
#7 Thu 22 December 2011 11:28
PaulH
Lieu: Nantes
Je remets à jour ce post car j'ai le même problème...quand je lance ArcGis celui me marque The system clock has been set back to the past. This is not allowed".
J'ai essayé de le désinstaller/réinstaller mais ça ne marche pas. Je ne vois pas non plus de logiciel "Sentinel System driver" et le lien vers le liend de Franck B est mort..
Si quelqu'un avait une solution svp..merci bcp !!
Paul Hedin
ex-luern
#8 Thu 22 December 2011 13:48
Franck B
Lieu: PACA
Le lien de 2006 ne fonctionne effectivement plus mais l'outil est téléchargeable ici maintenant : http://www.petges.lu/
Franck
#9 Thu 22 December 2011 16:50
PaulH
Lieu: Nantes
Merci pour le lien. J'ai effectivement téléchargé l'outil mais je ne suis pas sur de l'exécuter correctement car après avoir sélectionné mon répertoire ArcGis et être allé dans "Modifier les propriétés", l'heure et la date de mes fichiers sont les mêmes que ma pendule windows...Il n'y a aucune différence donc je ne comprends pas d'où viendrait le bug...
quelqu'un aurait-il une solution?
Sachant que j'ai désinstallé/reinstallé ArcGis au moins 3 fois...
Dernière modification par luern (Fri 23 December 2011 11:00)
Paul Hedin
ex-luern
