Rencontres QGIS 2025
#1 Wed 07 February 2007 17:59
n314
[ArcView 3.x] Envoyer un mail en avenue
je cherche à envoyer, depuis avenue, un mail contenant du texte et une pièce jointe. Le support esri mentionne deux possibilités:
1)
Utiliser un programme externe
Citation:
GBMailer (from http://members.xoom.com/gboban.index.htm) is a small free stand-alone mailing program which you can use to mail a textfile.
malheureusement
Citation:
GBMailer is command-line mailer wich will send an text file as mail.
It is written to be executed from CGI-scripts, but it can be ussed for
any other purpose.
See history.txt for changes in this revision.
NOTE: Be sure to read Bugs section (section 2.) of this readme file
before mailing bug reports or questions about using GBMailer
USAGE:
gbmail [-v] -to <address list...> [-file <filename>] [-h <smtp.server.name>]
[-p <port_number>] [-from <address>] [-cc <address list...>]
[-bcc <address list>] [-s <Subject>] [-t <timeout>]
OPTIONS:
-v verbose output.
-file Name of text file to send as message body.
(This is not required since version 1.12)
-h Name of SMTP server to connect. If this option is not set
GBMailer will assume 'localhost'.
-p Port number for SMTP protocol. Port is set to 25 by default.
-from An optional e-mail ddress of sender. If not set GBMailer
will try to assume an e-mail address by combinating name of
current user and name of local machine.
You should set this option in most cases.
-to REQUIRED E-mail addres (or addresses) of recipient(s).
At least one address must cast after -to switch.
-cc (carbon copy) E-mail addresses of recipients which will be listed
in Cc: field.
-bcc (blind carbon copy) E-mail addresses of recipients which you don't
want to be listed in message which will be sent.
-s Subject of message.
-t Timeout for socket operations (in seconds). Set to 300 secs by
default.
il n'y a apparemment pas de gestion des pièces jointes....
2) utiliser une dll
-> la solution 2 me satisfaisant moyennement, quelqu'un connaitrait il un équivalent à GBMailer gérant les pièces jointes ?
n314
