#1 Tue 29 May 2007 22:43
jean Guy
conversion .map en .tab
Quelqu'un pourrait-il me dire s'il existe un moyen de lire des cartes en .png avec un fichier de referencement en .map sous mapinfo. Les fichiers dont je dispose sont lisible sous oziexplorer mais je souhaiterais les lire sous mapinfo donc convertir le fichier de referencement en .tab.
#2 Tue 29 May 2007 23:23
Maurice
Re: conversion .map en .tab
Suivant ce qu'on trouve dans ces map (si ce sont des fichiers texte) c'est possible
On peut voir à quoi ressemble un map ??
#3 Tue 29 May 2007 23:58
jean Guy
Voila un exemple d'un fichier .map ouvert avec un éditeur de texte :
OziExplorer Map Data File Version 2.1
1, Map Code,
WGS 84,WGS 84,   0.0000,   0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Latitude/Longitude,PolyCal,No,AutoCalOnly,No,BSBUseWPX,Yes
Point01,xy,     0,     0,in, deg,  41, 49.41557636,N,   9,  4.94262986,E, grid,   ,           ,           ,N
Point02,xy,  4000,     0,in, deg,  41, 48.95166483,N,   9, 12.08806597,E, grid,   ,           ,           ,N
Point03,xy,  4000,  4000,in, deg,  41, 43.53328369,N,   9, 11.45483290,E, grid,   ,           ,           ,N
Point04,xy,     0,  4000,in, deg,  41, 43.99642980,N,   9,  4.32027413,E, grid,   ,           ,           ,N
Point05,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point06,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point07,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point08,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point09,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point10,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point11,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point12,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point13,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point14,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point15,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point16,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point17,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point18,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point19,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point20,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point21,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point22,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point23,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point24,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point25,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point26,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point27,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point28,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point29,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Point30,xy,     ,     ,in, deg,    ,        ,N,    ,        ,E, grid,   ,           ,           ,N
Projection Setup,    45.000000000,     5.000000000,     0.999600000,            0.00,            0.00,    49.000000000,    45.000000000,,,
Map Feature = MF ; Map Comment = MC     These follow if they exist
Track File = TF      These follow if they exist
Moving Map Parameters = MM?    These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2, 4000,0
MMPXY,3, 4000, 4000
MMPXY,4,0, 4000
MMPLL,1,  9.08237716, 41.82359294
MMPLL,2,  9.20146777, 41.81586108
MMPLL,3,  9.19091388, 41.72555473
MMPLL,4,  9.07200457, 41.73327383
MM1B,2.471979
MOP,Map Open Position,1500,1700
IWH,Map Image Width/Height, 4000, 4000
#4 Wed 30 May 2007 08:48
Maurice
Avec les dernières lignes et l'information sur la projection en début de fichier on peut construire le TAB suivant:
!table
!version 300
!charset WindowsLatin1
Definition Table
  File "nom_image.suffixe"
  Type "RASTER"
  (9.08237716, 41.82359294) (0,0) Label "Pt 1",
  (9.20146777, 41.81586108) (4000,0) Label "Pt 2",
  (9.19091388, 41.72555473) (4000,4000) Label "Pt 3",
  (9.07200457, 41.73327383) (0,4000) Label "Pt 4"
  CoordSys Earth Projection 1,104
  Units  "degree"
ps: pas sûr que la dernière ligne soit indispensable...
#5 Fri 01 June 2007 18:17
jean Guy
Merci pour l'info, ca marche bien, mais n'existe-t-il pas un petit utilitaire pour convertir ce fichier pour aller plus rappidement ?
#6 Fri 01 June 2007 19:23
Maurice
Je vais essayer de trouver le temps de rajouter cette fonctionnalité à mon outil UT4RT
Pouvez vous m'envoyer sur mon mail quelques exemples de ces fichiers et me dire si comme les worldfiles ces *.map portent le même nom que l'image qu'ils référencent ??
#7 Tue 05 June 2007 21:02
jean Guy
Les .map possède le même nom que l'image à laquelle il est associé.
Par exemple: Carte1.map + Carte1.png
#8 Thu 18 October 2007 20:24
Sylvain M.
Bonjour !
J'ai la même requête que Jean Guy, mais il ne semble pas que la fonctionnalité ait été ajoutée à UT4RT.
Avez-vous trouvé une possibilité pour automatiser la conversion de MAP en TAB ?
Merci pour votre aide !
Sylvain
Sylvain M.
#9 Thu 18 October 2007 21:12
Maurice
J'arrive !! Le temps que cette fichue grippe me lâche sad
#10 Thu 15 November 2007 22:23
Sylvain M.
Bonsoir !
Alors, cette grippe vous a-t-elle enfin lâchée ? wink
Si vous avez la solution, cela me serait toujours utile !
Merci d'avance et bon rétablissement si la grippe est tenace... sad
Sylvain
[Edit : s'il le faut, je peux vous envoyer les MAP (OziExplorer Map Data File Version 2.1) par e-mail]
Dernière modification par montagnersylvain (Thu 15 November 2007 22:33)
Sylvain M.
#11 Fri 30 May 2008 13:44
J-Yves
Simplement pour savoir si l'outil UT4RT a été modifié pour remplir cette fonctionnalité automatiquement, sinon existe t-il d'autres outils ? Merci
#12 Sun 01 June 2008 22:30
Maurice
UT4RT a évolué dans ce sens...mais j'avais oublié de faire la mise à jour. Désolé !!
#13 Mon 02 June 2008 18:24
J-Yves
Bonjour Maurice,
Merci pour cette mise à jour
Je vais essayer.
#14 Mon 01 December 2008 20:46
soulsurfer
je suis à la recherche d'un outil convertissant  créant à partir de metadonnées bdortho (fichiers .tab + . grf)  un fichier .map exploitable par le logiciel oziexplorer.
#15 Mon 01 December 2008 22:09
Maurice
C'est faisable...mais c'est pas mal de boulot, tout ça pour encourager la dissidence smile
Si j'ai le temps...
OziExplorer ne sait pas s'arranger d'image + tab ?? ou image + tfw (si c'est du tif, jgw si c'est du jpg, etc...) ??
#16 Tue 02 December 2008 11:15
NicolasGeorge
La version complète PC sait traiter les world files (au moins les tfw, et les geotiff aussi je crois), mais si c'est pour utiliser dans la verion pour PPC (OziCE) là pas le choix il faut des .map.
J'avais écrit une moulinette en perl qui faisait ça, mais seulement pour une seule projection (Lambert 2 étendu je crois, faut que j'y redéterre si ça intéresse quelqu'un...).
