#1 Tue 16 October 2007 18:21
- tiyan34
- Lieu: Montpellier
Probleme de projection
j'ai à nouveau un probleme de projection sur une de mes tables (j'avais dejà posté un message à ce sujet il y a quelques semaines, mais cette fois la table ne provient pas de la meme source)
lorsque j'ouvre le MIF j'ai :
CoordSys NonEarth Units "m" Bounds (-40030154.7425, -9669522.72867) (40030154.7425, 10007538.6856)
Columns 1
id Integer
Data
Region 1
84
750774.999 162887.212
750766.433 162777.985
750771.797 162750.142
750802.86 162713.739
750836.045 162661.27
750872.473 162619.506
750897.091 162573.461
750901.375 162518.848
750906.739 162466.379
750929.195 162407.485
750933.479 162363.586
750991.322 162317.541
751021.305 162297.195
751050.207 162252.223
751055.571 162223.308
751079.108 162161.207
751089.836 162136.572
751103.767 162077.678
751119.819 162050.907
751147.64 162003.801
751157.287 161977.03
751179.784 161939.545
751188.351 161911.712
751196.917 161871.02
751229.021 161806.764
751262.967 161765.197
751311.604 161676.01
751335.942 161627.359
751340.826 161617.638
751283.662 161539.068
751283.662 161513.369
751252.599 161484.454
751267.57 161463.045
751277.578 161445.749
751292.149 161421.428
751308.361 161377.647
751319.73 161329.005
751340.826 161280.354
751355.397 161228.465
751378.094 161166.847
751398.229 161127.886
751370.368 161128.949
751321.131 161131.093
751307.2 161137.518
751225.819 161148.222
751199.039 161287.428
751184.067 161349.538
751186.189 161385.941
751210.848 161420.208
751192.634 161443.772
751172.299 161429.85
751158.368 161418.073
751136.952 161404.152
751125.183 161453.404
751105.889 161528.363
751043.802 161714.685
751006.294 161823.903
750966.704 161915.992
750945.288 161967.388
750924.912 162058.404
750907.779 162116.235
750900.294 162152.638
750884.242 162163.342
750863.906 162176.191
750839.248 162239.374
750817.832 162288.626
750811.427 162307.9
750785.727 162414.982
750761.109 162503.864
750744.977 162523.019
750733.728 162565.551
750720.999 162610.523
750708.309 162656.479
750699.022 162701.451
750695.78 162742.645
750695.78 162755.504
750700.063 162767.28
750696.86 162784.409
750691.496 162796.186
750688.294 162837.951
750689.335 162852.944
750682.93 162864.721
750679.728 162880.788
Pen (1,2,65535)
Brush (18,65535)
Center 751058.253 162001.124
et lorsque j'ouvre cette table dans mapinfo et que je vais voir la projection de la table elle est en "non terrestre"
j'ai essayé de la transformer en lambert2 etendu et là le polygone de cette table a à peu pres ces coordonnées :
x : 1 589 000
y : - 3 290 450
Quelqu'un pourrait m'aider à retrouver la projection d'origine de cette table?
Yannick
#2 Tue 16 October 2007 21:33
- Maurice
- Lieu: Montpellier
Re: Probleme de projection
Bonjour;
Ces X,Y ressemblent bien à du Lambert 3 Sud (du côté de Vergeze - origine de Perrier, pour ceux qui l'ignorent
La clause CoordSys peut donc être remplacée par
CoordSys Earth Projection 3, 1002, "m", 0, 44.1, 43.199291275544, 44.996093814511, 600000, 200000 Bounds (0, -100000) (1200000, 1100000)
Les Bounds pouvent être ignorés: ils ne sont là que pour apporter une précision de 0,6 mm sur France entière. Si on les ignore on "retombe" à la précision par défaut de 11 cm environ.
#3 Wed 17 October 2007 10:28
- tiyan34
- Lieu: Montpellier
Merci Maurice ça a marché pour la table en question!
Par contre j'ai un autre probleme de projection pour cette table ci :
Version 300
Charset "WindowsLatin1"
Delimiter ","
CoordSys Earth Projection 1, 0
Columns 2
Num Integer
Classe_enjeux Char(25)
Data
Point 6.759906 1.456178
Symbol (39,255,18,"MapInfo Real Estate",256,0)
Point 6.759833 1.455306
Symbol (67,255,36,"MapInfo Miscellaneous",256,0)
Point 6.759376 1.454441
Symbol (83,16711680,18,"MapInfo Transportation",256,0)
qui devrait logiquement se trouver à Vergeze aussi
et là aussi je n'arrive pas à la replacer...
Merci beaucoup
Yannick
#4 Wed 17 October 2007 11:09
- Maurice
- Lieu: Montpellier
Plus dur...![]()
On devrait être en longitude latitude avec des X,Y en degrés décimaux ...mais les valeurs dans le MIF sont aberrantes
Elles devraient être de l'ordre de 4,22 ° en X et 43,75° en Y ...et je ne vois pas bien la relation avec les valeurs présentes
Tout ça ne viendrait-il pas de GeoConcept ??
#5 Wed 17 October 2007 11:56
- tiyan34
- Lieu: Montpellier
Logiquement ce n'est pas du Geoconcept, j'ai recontacté la personne qui m'a envoyé la table pour voir si il n'y avait pas une erreur et elle est en train de regarder, la table que j'ai reçu etait peut etre bien erronée
#6 Wed 17 October 2007 12:17
- tiyan34
- Lieu: Montpellier
En fait pour la meme table j'ai maintenant des coordonnées qui ressemblent à ça (dans le MIF):
Version 300
Delimiter ","
Columns 2
Num Integer
Data
Point 6.760787 1.458151
Symbol (59,16711680,24,"MapInfo Real Estate",0,0)
Point 6.760917 1.453063
Symbol (36,255,18,"MapInfo Real Estate",0,0)
Point 6.760126 1.457132
Point 6.760159 1.456888
Je ne suis pas + avancé....
#7 Wed 17 October 2007 13:11
- Maurice
- Lieu: Montpellier
En effet : ce sont plus des valeurs genre Golfe de Guinée, au large de la Côte d'Ivoire, que dans l'Ouest du Gard !!
#8 Wed 17 October 2007 14:33
- tiyan34
- Lieu: Montpellier
y'aurait une possibilité de les replacer "automatiquement"? ou alors il va falloir que je les replace "à la main" moi même sur la carte?
#9 Wed 17 October 2007 15:44
- Maurice
- Lieu: Montpellier
Peut être, après importation puis reprojection en Lambert 3 Sud (par "enregistrer sous...") est-il possible de faire subir aux points la même translation (en X et Y, par menu Objets->Déplacement) telle que si l'un d'entre eux est bien situé, tous les autres le sont aussi ??
Faut-il encore connaître leur "bonne position" ...
Le plus "simple" serait de demander au fournisseur la liste des X,Y dans une projection connue (
) dans un tableau, et de passer par le menu Table->Créer points
#10 Wed 17 October 2007 17:38
- tiyan34
- Lieu: Montpellier
Je les ai replacés un à un en fait, je pense que c'etait plus rapide de faire comme ça (pour cette fois du moins car les points n'etaient pas nombreux et j'avais un jpeg qui m'indiquait leur emplacement)...
Merci en tout cas ![]()
Bonne soiree!
Yannick
