#1 Fri 21 December 2007 17:52
anismouali
Lieu: Tunis
Class java pour se connecter facilement à PostGIS
je passe une class java qui peut servir ceux qui se connectent beaucoup de fois à postgis dans leur applications j'espaire que ça sera utile
import java.sql.*;
import javax.swing.*;
import javax.swing.JOptionPane;
public  class ConnPG {
private static Statement stmt;
private static Connection connexion;
private static ResultSet rs;
public ConnPG(String db,int port)
Connect(db, port);
private static void Connect(String datab,int _port){
      try
           Class.forName("org.postgresql.Driver");
           String url = "jdbc:postgresql://localhost:"+_port+"/"+datab;
           connexion = DriverManager.getConnection(url, "postgres", "141209");
           ((org.postgresql.PGConnection)connexion).addDataType("geometry", "org.postgresql.PGConnection");
           ((org.postgresql.PGConnection)connexion).addDataType("box3d","org.postgis.PGbox3d");
      }catch ( SQLException E)
          JOptionPane.showMessageDialog(new JFrame(), E.getMessage() );
          JOptionPane.showMessageDialog(new JFrame(), E.getSQLState() );
          System.out.println("VendorError:  " + E.getErrorCode());
      catch ( ClassNotFoundException E)
            E.printStackTrace();
      catch ( NullPointerException E)
          JOptionPane.showMessageDialog(new JFrame(),E.toString());
                          }//fin connect()
public static void setQuery(String query){
try {
/*Statement*/     stmt = connexion.createStatement();
         rs = stmt.executeQuery(query);
    }catch (SQLException E){
        JOptionPane.showMessageDialog(new JFrame(),  E.getMessage());
        JOptionPane.showMessageDialog(new JFrame(), E.getSQLState());
                           }//end catch
public static void setBolQuery(String query){
    try {
         boolean    isexe = stmt.execute(query);
         if(!isexe) JOptionPane.showMessageDialog(new JFrame(),"Données enregistrées!");
         else JOptionPane.showMessageDialog(new JFrame(),"Données non enregistrées!","Erreure",JOptionPane.ERROR_MESSAGE);
                               }//end catch
public static ResultSet getResultSet(){
    return rs;
                                      }//fin de la classe getResultSet()
public static void disConnectDB(){
    try{stmt.close();
     try {
            connexion.close();
        catch(SQLException e)      {
            JOptionPane.showMessageDialog(new JFrame(),"Impossible de fermer la connexion");
         }catch(SQLException sqle){JOptionPane.showMessageDialog(new JFrame(),"Erreur liée au base de données(fermeture de Statement)!");}
                            }//fin de la methode de disConnectDB()
anismouali
#2 Tue 25 December 2007 15:50
Yves
Lieu: Aix-les-Bains
Re: Class java pour se connecter facilement à PostGIS
Merci pour ta contribution.
Joyeux noël,
Y.
#3 Tue 25 December 2007 16:08
anismouali
Lieu: Tunis
à vous de même Yves et à tout les ami(e)s du GeoRezo
Geo_JAVA_noël
anismouali
