Rencontres QGIS 2025
#1 Fri 28 March 2008 12:41
Pierre
DesCartesPourUnMondeMeilleur
ListSearcher : Bad ARE
Aloha
J'utilise cette ARE dans l'outil ListSearcher :
^C_ASS_AXE|C_ASSEP_AVALOIR|C_ASSEP_GRILLE|C_ASS_REGARD|C_ASSEP_REGARD|C_ASSEP_RESEAU|C_ASSEU_REGARD|C_ASSEU_RESEAU|C_CIR_ABRI_BUS|C_CIR_BARRIERE_SECU|C_CIR_GLISSIERE_SECU|C_CIR_HORODATEUR|C_CIR_MARQUAGE_BORDURE|C_CIR_MAT_BUS|C_CIR_MAT_JALONNEMENT|C_CIR_PANNEAU|C_CIR_PANNEAU|C_CIR_WC_PUBLIQUES|C_DIV_ARMOIRE|C_DIV_BOUCHE|C_DIV_CORBEILLE|C_DIV_DEPOT_ORDURES|C_DIV_DIVERS_HACHURE|C_DIV_LIGNE|C_DIV_GRILLE|C_DIV_GRILLE_VENTILATION|C_DIV_POMPE_ESSENCE|C_DIV_POTEAU|C_DIV_REGARD|C_DIV_TEXTE|C_VOI_LIMIT_PROPRIETE|C_CAD_LIMITE_PARCELLAIRE|C_EAU_BORNE_FONT|C_EAU_BOUCHE_CLE|C_EAU_BOUCHE_ARROSAGE|C_EAU_BOUCHE_INC|C_EAU_BOUCHE_LAV|C_EAU_COFFRET|C_EAU_POTEAU_INCENDIE|C_EAU_REGARD|C_ECP_ARMOIRE|C_ECP_COFFRET|C_ECP_REGARD|C_ECP_AERIEN|C_ECP_SUPPORT|C_EDF_ARMOIRE|C_EDF_COFFRET|C_EDF_POSTE|C_EDF_POTEAU|C_EDF_PYLONE|C_EDF_REGARD|C_ESP_AGRES|C_ESP_ARBRE|C_ESP_BANC|C_ESP_BARRIERE|C_ESP_BORDURETTE|C_ESP_CLOTURE|C_ESP_FILET|C_ESP_GRILLE_ARBRE|C_ESP_JARDINIERE|C_ESP_JEU|C_ESP_TRACE|C_ESP_ZONE_ARBUSTES|C_ESP_ZONE_ECORCE|C_ESP_ZONE_ENROBE|C_ESP_ZONE_FLEURS|C_ESP_ZONE_GAZON|C_ESP_ZONE_HACHURES|C_ESP_ZONE_HAIE|C_ESP_ZONE_MASSIF|C_ESP_ZONE_PAVAGE|C_ESP_ZONE_ROSIERS|C_ESP_ZONE_SABLE|C_ESP_ZONE_STABILISE|C_ESP_ZONE_TAPIS|C_ESP_ZONE_BETON|C_FT_ARMOIRE|C_FT_BORNE_RACC|C_FT_CABINE_TELEPHONE|C_FT_POTEAU|C_FT_REGARD|C_GDF_BOUCHE|C_GDF_COFFRET|C_GDF_POSTE_DET|C_GDF_REGARD|C_BL_REGARD|C_TOP_COURBE_NIV|C_TOP_EMPRISE_LEVE|C_TOP_POINT_NIV|C_TOP_POLYGONAL|C_ST_ARMOIRE|C_ST_BORNE|C_ST_REGARD|C_ST_POTEAU|C_ST_PIETON|C_VOI_BORD_CANIVEAU|C_VOI_BORD_BATEAU|C_VOI_BORD_DEFENSE|C_VOI_CRETE_TALUS|C_VOI_ENTR_PIETON|C_VOI_FACADE|C_VOI_FOND_FOSSE|C_VOI_GARGOUILLE|C_ESP_HAIE|C_VOI_MUR|C_VOI_MUR_SOUT|C_VOI_NUMERO|C_VOI_OUVRAGE|C_VOI_PIED_TALUS|C_VOI_SORT_GARAGE|C_ST_POTENCE|C_VOI_SOUPIRAIL|C_TOP_POLYGONAL|TopoAlt)$
Search type est mis à "1st regular expression found", mais j'obtiens ce message d'erreur : [BADRE] Attempt to use invalid regular expression, avec arrêt de FME.
Si j'essaie avec ^(TopoAlt|toto)$, celà fonctionne.
C'est une ARE que j'utilise par ailleurs dans un GREPPER avec succès.
Que puis-je faire ? Une idée ?
D'avance, merci,
#2 Fri 28 March 2008 13:00
Matthieu-VEREMES
Re: ListSearcher : Bad ARE
Je ne vois pas la parenthèse ( après ^.
Matthieu Ambrosy
Veremes : support FME & version française
support at veremes point com
#3 Fri 28 March 2008 14:42
MUCKENSTURM Pierre
Corrigé et pourtant cela ne fonctionne pas
^(C_ASS_AXE|C_ASSEP_AVALOIR|C_ASSEP_GRILLE|C_ASS_REGARD|C_ASSEP_REGARD|C_ASSEP_RESEAU|C_ASSEU_REGARD|C_ASSEU_RESEAU|C_CIR_ABRI_BUS|C_CIR_BARRIERE_SECU|C_CIR_GLISSIERE_SECU|C_CIR_HORODATEUR|C_CIR_MARQUAGE_BORDURE|C_CIR_MAT_BUS|C_CIR_MAT_JALONNEMENT|C_CIR_PANNEAU|C_CIR_PANNEAU|C_CIR_WC_PUBLIQUES|C_DIV_ARMOIRE|C_DIV_BOUCHE|C_DIV_CORBEILLE|C_DIV_DEPOT_ORDURES|C_DIV_DIVERS_HACHURE|C_DIV_LIGNE|C_DIV_GRILLE|C_DIV_GRILLE_VENTILATION|C_DIV_POMPE_ESSENCE|C_DIV_POTEAU|C_DIV_REGARD|C_DIV_TEXTE|C_VOI_LIMIT_PROPRIETE|C_CAD_LIMITE_PARCELLAIRE|C_EAU_BORNE_FONT|C_EAU_BOUCHE_CLE|C_EAU_BOUCHE_ARROSAGE|C_EAU_BOUCHE_INC|C_EAU_BOUCHE_LAV|C_EAU_COFFRET|C_EAU_POTEAU_INCENDIE|C_EAU_REGARD|C_ECP_ARMOIRE|C_ECP_COFFRET|C_ECP_REGARD|C_ECP_AERIEN|C_ECP_SUPPORT|C_EDF_ARMOIRE|C_EDF_COFFRET|C_EDF_POSTE|C_EDF_POTEAU|C_EDF_PYLONE|C_EDF_REGARD|C_ESP_AGRES|C_ESP_ARBRE|C_ESP_BANC|C_ESP_BARRIERE|C_ESP_BORDURETTE|C_ESP_CLOTURE|C_ESP_FILET|C_ESP_GRILLE_ARBRE|C_ESP_JARDINIERE|C_ESP_JEU|C_ESP_TRACE|C_ESP_ZONE_ARBUSTES|C_ESP_ZONE_ECORCE|C_ESP_ZONE_ENROBE|C_ESP_ZONE_FLEURS|C_ESP_ZONE_GAZON|C_ESP_ZONE_HACHURES|C_ESP_ZONE_HAIE|C_ESP_ZONE_MASSIF|C_ESP_ZONE_PAVAGE|C_ESP_ZONE_ROSIERS|C_ESP_ZONE_SABLE|C_ESP_ZONE_STABILISE|C_ESP_ZONE_TAPIS|C_ESP_ZONE_BETON|C_FT_ARMOIRE|C_FT_BORNE_RACC|C_FT_CABINE_TELEPHONE|C_FT_POTEAU|C_FT_REGARD|C_GDF_BOUCHE|C_GDF_COFFRET|C_GDF_POSTE_DET|C_GDF_REGARD|C_BL_REGARD|C_TOP_COURBE_NIV|C_TOP_EMPRISE_LEVE|C_TOP_POINT_NIV|C_TOP_POLYGONAL|C_ST_ARMOIRE|C_ST_BORNE|C_ST_REGARD|C_ST_POTEAU|C_ST_PIETON|C_VOI_BORD_CANIVEAU|C_VOI_BORD_BATEAU|C_VOI_BORD_DEFENSE|C_VOI_CRETE_TALUS|C_VOI_ENTR_PIETON|C_VOI_FACADE|C_VOI_FOND_FOSSE|C_VOI_GARGOUILLE|C_ESP_HAIE|C_VOI_MUR|C_VOI_MUR_SOUT|C_VOI_NUMERO|C_VOI_OUVRAGE|C_VOI_PIED_TALUS|C_VOI_SORT_GARAGE|C_ST_POTENCE|C_VOI_SOUPIRAIL|C_TOP_POLYGONAL|TopoAlt)$
